I’m install Stable diffusion on new installed Jetson AGX orin based on below link.
But get error after ./run.sh $(./autotag stable-diffusion-webui)
It seems something wrong about “/tmp/.docker.xauth” but docker status also failed.
Please advice me how to solve this issue.
xxx@ubuntu:~/Desktop/jetson-containers$ ./run.sh $(./autotag stable-diffusion-webui)
Namespace(packages=[‘stable-diffusion-webui’], prefer=[‘local’, ‘registry’, ‘build’], disable=[‘’], user=‘dustynv’, output=‘/tmp/autotag’, quiet=False, verbose=False)
– L4T_VERSION=36.2.0 JETPACK_VERSION=6.0 CUDA_VERSION=12.2.140
– Finding compatible container image for [‘stable-diffusion-webui’]
[sudo] password for xxx:
File “/usr/lib/python3.10/runpy.py”, line 196, in _run_module_as_main
return _run_code(code, main_globals, None,
File “/usr/lib/python3.10/runpy.py”, line 86, in _run_code
exec(code, run_globals)
File “/home/taroi/Desktop/jetson-containers/jetson_containers/tag.py”, line 58, in
image = find_container(args.packages[0], prefer_sources=args.prefer, disable_sources=args.disable, user=args.user, quiet=args.quiet)
File “/home/taroi/Desktop/jetson-containers/jetson_containers/container.py”, line 512, in find_container
local_images = find_local_containers(package, **kwargs)
File “/home/taroi/Desktop/jetson-containers/jetson_containers/container.py”, line 424, in find_local_containers
local_images = get_local_containers()
File “/home/taroi/Desktop/jetson-containers/jetson_containers/container.py”, line 352, in get_local_containers
status = subprocess.run(cmd, stdout=subprocess.PIPE, stderr=subprocess.PIPE,
File “/usr/lib/python3.10/subprocess.py”, line 526, in run
raise CalledProcessError(retcode, process.args,
subprocess.CalledProcessError: Command ‘[‘sudo’, ‘docker’, ‘images’, ‘–format’, "’{{json . }}‘"]’ returned non-zero exit status 1.
– Error: return code 1
localuser:root being added to access control list
xauth: file /tmp/.docker.xauth does not exist
- sudo docker run --runtime nvidia -it --rm --network host --volume /tmp/argus_socket:/tmp/argus_socket --volume /etc/enctune.conf:/etc/enctune.conf --volume /etc/nv_tegra_release:/etc/nv_tegra_release --volume /tmp/nv_jetson_model:/tmp/nv_jetson_model --volume /var/run/dbus:/var/run/dbus --volume /var/run/avahi-daemon/socket:/var/run/avahi-daemon/socket --volume /var/run/docker.sock:/var/run/docker.sock --volume /home/taroi/Desktop/jetson-containers/data:/data --device /dev/snd --device /dev/bus/usb -e DISPLAY=:1 -v /tmp/.X11-unix/:/tmp/.X11-unix -v /tmp/.docker.xauth:/tmp/.docker.xauth -e XAUTHORITY=/tmp/.docker.xauth
“docker run” requires at least 1 argument.
See ‘docker run --help’.
Usage: docker run [OPTIONS] IMAGE [COMMAND] [ARG…]
Create and run a new container from an image
xxx@ubuntu:~/Desktop/jetson-containers$ sudo systemctl status docker
× docker.service - Docker Application Container Engine
Loaded: loaded (/lib/systemd/system/docker.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Thu 2024-03-07 18:55:39 JST; 18min ago
TriggeredBy: × docker.socket
Docs: https://docs.docker.com
Process: 2440 ExecStart=/usr/bin/dockerd -H fd:// --containerd=/run/containerd/containerd.sock (code=exited, status=1/FAILURE)
Main PID: 2440 (code=exited, status=1/FAILURE)
CPU: 203ms
Mar 07 18:55:39 ubuntu systemd[1]: docker.service: Scheduled restart job, restart counter is at 3.
Mar 07 18:55:39 ubuntu systemd[1]: Stopped Docker Application Container Engine.
Mar 07 18:55:39 ubuntu systemd[1]: docker.service: Start request repeated too quickly.
Mar 07 18:55:39 ubuntu systemd[1]: docker.service: Failed with result ‘exit-code’.
Mar 07 18:55:39 ubuntu systemd[1]: Failed to start Docker Application Container Engine.
Regards,
