Jetson-Inference docker problem
Good morning ! I am trying to run the Jetson-Inference examples , but it looks like docker is complaining a bit …
Error when I execute
docker/run.sh
root@pieter-classensLegion:/development/docker/jetson-inference/jetson-inference# docker/run.sh
ARCH: x86_64
localuser:root being added to access control list
CONTAINER_IMAGE: dustynv/jetson-inference:22.06
DATA_VOLUME: --volume /development/docker/jetson-inference/jetson-inference/data:/jetson-inference/data --volume /development/docker/jetson-inference/jetson-inference/python/training/classification/data:/jetson-inference/python/training/classification/data --volume /development/docker/jetson-inference/jetson-inference/python/training/classification/models:/jetson-inference/python/training/classification/models --volume /development/docker/jetson-inference/jetson-inference/python/training/detection/ssd/data:/jetson-inference/python/training/detection/ssd/data --volume /development/docker/jetson-inference/jetson-inference/python/training/detection/ssd/models:/jetson-inference/python/training/detection/ssd/models --volume /development/docker/jetson-inference/jetson-inference/python/www/recognizer/data:/jetson-inference/python/www/recognizer/data
V4L2_DEVICES: --device /dev/video0 --device /dev/video1
DISPLAY_DEVICE: -e DISPLAY=:0 -v /tmp/.X11-unix/:/tmp/.X11-unix
docker: Error response from daemon: could not select device driver “” with capabilities: [[gpu]]
Which environment do you use?
Based on the log, do you run it on an x86 device?
Apologies - that screenshot was on my Notebook’s Linux distro – oops :) – following this article now → “can't install nvidia-driver-toolkit on Ubuntu 20.04 LTS - needs uninstallable package - Ask Ubuntu” - will let you know if we are happy …
Okay - made super sure I was on the correct terminal this time - actually also run the command on the physical unit itself to double check :)
Output from ./Step1_installation.sh
root@DanielJetSon:/development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install# ./Step1_installation.sh
Hit:1 https://download.docker.com/linux/ubuntu jammy InRelease
Hit:2 http://ports.ubuntu.com/ubuntu-ports jammy InRelease
Hit:3 http://ports.ubuntu.com/ubuntu-ports jammy-updates InRelease
Ign:4 https://ppa.launchpadcontent.net/relan/exfat/ubuntu jammy InRelease
Hit:5 http://ports.ubuntu.com/ubuntu-ports jammy-backports InRelease
Err:6 https://ppa.launchpadcontent.net/relan/exfat/ubuntu jammy Release
  404  Not Found [IP: 185.125.190.80 443]
Hit:7 http://ports.ubuntu.com/ubuntu-ports jammy-security InRelease
Reading package lists... Done
E: The repository 'https://ppa.launchpadcontent.net/relan/exfat/ubuntu jammy Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
Building dependency tree... Done
Reading state information... Done
Calculating upgrade... Done
Get more security updates through Ubuntu Pro with 'esm-apps' enabled:
  python2.7-minimal exo-utils libzvbi-common libzbar0 libiperf0
  libjs-jquery-ui libopenexr25 python3-scipy libpostproc55 libopencv-core4.5d
  libavcodec58 libgstreamer-plugins-bad1.0-0 iperf3 libpython2.7 libavutil56
  libswscale5 xrdp libexo-2-0 gir1.2-gst-plugins-bad-1.0 libswresample3
  libavformat58 libzvbi0 gstreamer1.0-plugins-bad libgstreamer-opencv1.0-0
  libpmix-dev python2.7 libde265-0 libpython2.7-minimal libpmix2
  libpython2.7-stdlib libexo-common libgstreamer-plugins-bad1.0-dev
  libavfilter7
Learn more about Ubuntu Pro at https://ubuntu.com/pro
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
cmake is already the newest version (3.22.1-1ubuntu1.22.04.2).
git is already the newest version (1:2.34.1-1ubuntu1.15).
libpython3-dev is already the newest version (3.10.6-1~22.04.1).
python3-numpy is already the newest version (1:1.21.5-1ubuntu22.04.1).
fatal: destination path 'jetson-inference' already exists and is not an empty directory.
mkdir: cannot create directory ‘build’: File exists
CMake Deprecation Warning at CMakeLists.txt:2 (cmake_minimum_required):
  Compatibility with CMake < 2.8.12 will be removed from a future version of
  CMake.
  Update the VERSION argument <min> value or use a ...<max> suffix to tell
  CMake that the project does not need compatibility with older versions.
Note:  this project uses git submodules in the source tree.
       if you haven't already, run the following command from
       the project's root directory:
           git submodule update --init
-- distro ID:       Ubuntu
-- distro version:  22.04
-- distro codename: jammy
-- using patched FindCUDA.cmake
-- Could NOT find CUDA (missing: CUDA_CUDART_LIBRARY) (found version "12.6")
-- CUDA version: 12.6
-- CUDA 12.6 detected (aarch64), enabling SM_53 SM_62
-- CUDA 12.6 detected (aarch64), enabling SM_72
-- CUDA 12.6 detected (aarch64), enabling SM_87
-- OpenCV version:  4.8.0
-- OpenCV version >= 3.0.0, enabling OpenCV
CMake Warning at CMakeLists.txt:106 (find_package):
  Could not find a configuration file for package "VPI" that is compatible
  with requested version "2.0".
  The following configuration files were considered but not accepted:
    /usr/lib/cmake/vpi3/vpi-config.cmake, version: 3.2.4
-- didn't find VPI on system, disabling VPI
-- system arch:  aarch64
-- output path:  /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/build/aarch64
-- BUILD_EXPERIMENTAL disabled
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/c/actionNet.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/c/backgroundNet.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/c/calibration/randInt8Calibrator.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/c/depthNet.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/c/detectNet.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/c/imageNet.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/c/modelDownloader.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/c/poseNet.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/c/segNet.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/c/tensorConvert.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/c/tensorNet.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/c/tracking/objectTracker.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/c/tracking/objectTrackerIOU.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/c/tracking/objectTrackerKLT.h
-- Could NOT find Doxygen (missing: DOXYGEN_EXECUTABLE)
CMake Deprecation Warning at tools/camera-capture/CMakeLists.txt:2 (cmake_minimum_required):
  CMake.
-- found Qt5Widgets version:  5.15.3
-- found Qt5Widgets defines:  -DQT_WIDGETS_LIB;-DQT_GUI_LIB;-DQT_CORE_LIB
-- found Qt5Widgets library:  Qt5::Widgets
-- found Qt5Widgets include:  /usr/include/aarch64-linux-gnu/qt5/;/usr/include/aarch64-linux-gnu/qt5/QtWidgets;/usr/include/aarch64-linux-gnu/qt5/QtGui;/usr/include/aarch64-linux-gnu/qt5/QtCore;/usr/lib/aarch64-linux-gnu/qt5//mkspecs/linux-g++
-- camera-capture:  building as submodule of /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/tools
CMake Deprecation Warning at utils/CMakeLists.txt:2 (cmake_minimum_required):
  CMake.
-- jetson-utils:  building as submodule, /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference
-- nvbuf_utils:  NVBUF_UTILS-NOTFOUND
-- NVMM zero-copy memory:  ENABLE_NVMM=OFF
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/alphanum.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/camera/gstCamera.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/camera/v4l2Camera.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/codec/gstBufferManager.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/codec/gstDecoder.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/codec/gstEncoder.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/codec/gstUtility.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/codec/gstWebRTC.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/codec/nvbuf_utils.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/commandLine.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/csvReader.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/csvReader.hpp
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/csvWriter.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/csvWriter.hpp
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/cuda/cudaAlphaBlend.cuh
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/cuda/cudaBayer.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/cuda/cudaColormap.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/cuda/cudaColorspace.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/cuda/cudaCrop.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/cuda/cudaDraw.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/cuda/cudaFilterMode.cuh
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/cuda/cudaFilterMode.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/cuda/cudaFont.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/cuda/cudaGrayscale.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/cuda/cudaMappedMemory.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/cuda/cudaMath.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/cuda/cudaNormalize.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/cuda/cudaOverlay.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/cuda/cudaPointCloud.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/cuda/cudaRGB.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/cuda/cudaResize.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/cuda/cudaUtility.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/cuda/cudaVector.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/cuda/cudaWarp.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/cuda/cudaYUV.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/display/glBuffer.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/display/glCamera.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/display/glDisplay.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/display/glEvents.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/display/glTexture.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/display/glUtility.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/display/glWidget.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/filesystem.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/image/imageFormat.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/image/imageFormat.inl
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/image/imageIO.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/image/imageLoader.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/image/imageWriter.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/image/loadImage.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/input/devInput.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/input/devJoystick.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/input/devKeyboard.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/json.hpp
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/logging.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/mat33.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/network/Endian.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/network/IPv4.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/network/IPv6.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/network/Networking.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/network/RTSPServer.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/network/Socket.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/network/URI.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/network/WebRTCServer.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/pi.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/rand.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/threads/Event.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/threads/Event.inl
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/threads/Mutex.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/threads/Mutex.inl
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/threads/Process.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/threads/RingBuffer.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/threads/RingBuffer.inl
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/threads/Thread.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/timespec.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/video/videoOptions.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/video/videoOutput.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/video/videoSource.h
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/xml.h
-- trying to build Python bindings for Python versions:  3.10
-- detecting Python 3.10...
-- found Python version:  3.10 (3.10.12)
-- found Python include:  /usr/include/python3.10
-- found Python library:  /usr/lib/aarch64-linux-gnu/libpython3.10.so
-- CMake module path:  /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/cuda;/development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/python/bindings
-- NumPy ver. 2.2.6 found (include: /usr/local/lib/python3.10/dist-packages/numpy/_core/include)
-- found NumPy version:  2.2.6
-- found NumPy include:  /usr/local/lib/python3.10/dist-packages/numpy/_core/include
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/python/examples/cuda-array-interface.py
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/python/examples/cuda-examples.py
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/python/examples/cuda-from-cv.py
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/python/examples/cuda-from-numpy.py
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/python/examples/cuda-from-pytorch.py
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/python/examples/cuda-streams.py
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/python/examples/cuda-to-cv.py
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/python/examples/cuda-to-numpy.py
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/python/examples/cuda-to-pytorch.py
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/python/examples/test-cuda.sh
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/python/examples/test-display.py
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/python/examples/test-logging.py
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/python/examples/test-video.py
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/python/examples/video-viewer.py
-- CMake module path:  /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/utils/cuda;/development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/python/bindings;/development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/python/bindings/../../utils/python/bindings
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/python/examples/actionnet.py
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/python/examples/backgroundnet.py
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/python/examples/depthnet.py
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/python/examples/depthnet_utils.py
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/python/examples/detectnet-snap.py
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/python/examples/detectnet.py
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/python/examples/imagenet.py
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/python/examples/my-detection.py
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/python/examples/my-recognition.py
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/python/examples/posenet.py
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/python/examples/segnet.py
-- Copying /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/python/examples/segnet_utils.py
-- linking jetson-inference with OpenCV 4.8.0
-- Configuring done
-- Generating done
-- Build files have been written to: /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/build
[  6%] Building NVCC (Device) object utils/CMakeFiles/jetson-utils.dir/cuda/jetson-utils_generated_cudaDraw.cu.o
[  6%] Building NVCC (Device) object utils/CMakeFiles/jetson-utils.dir/cuda/jetson-utils_generated_cudaGrayscale.cu.o
[  6%] Building NVCC (Device) object utils/CMakeFiles/jetson-utils.dir/cuda/jetson-utils_generated_cudaFont.cu.o
[  6%] Building NVCC (Device) object utils/CMakeFiles/jetson-utils.dir/cuda/jetson-utils_generated_cudaCrop.cu.o
[  6%] Building NVCC (Device) object utils/CMakeFiles/jetson-utils.dir/cuda/jetson-utils_generated_cudaYUV-YV12.cu.o
[  6%] Building NVCC (Device) object utils/CMakeFiles/jetson-utils.dir/cuda/jetson-utils_generated_cudaFilterMode.cu.o
[  6%] Building NVCC (Device) object utils/CMakeFiles/jetson-utils.dir/cuda/jetson-utils_generated_cudaColormap.cu.o
[  7%] Building NVCC (Device) object utils/CMakeFiles/jetson-utils.dir/cuda/jetson-utils_generated_cudaNormalize.cu.o
CMake Error at jetson-utils_generated_cudaYUV-YV12.cu.o.cmake:219 (message):
  Error generating
  /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/build/utils/CMakeFiles/jetson-utils.dir/cuda/./jetson-utils_generated_cudaYUV-YV12.cu.o
CMake Error at jetson-utils_generated_cudaFont.cu.o.cmake:219 (message):
  Error generating
  /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/build/utils/CMakeFiles/jetson-utils.dir/cuda/./jetson-utils_generated_cudaFont.cu.o
CMake Error at jetson-utils_generated_cudaCrop.cu.o.cmake:219 (message):
  Error generating
  /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/build/utils/CMakeFiles/jetson-utils.dir/cuda/./jetson-utils_generated_cudaCrop.cu.o
make[2]: *** [utils/CMakeFiles/jetson-utils.dir/build.make:189: utils/CMakeFiles/jetson-utils.dir/cuda/jetson-utils_generated_cudaYUV-YV12.cu.o] Error 1
make[2]: *** Waiting for unfinished jobs....
make[2]: *** [utils/CMakeFiles/jetson-utils.dir/build.make:84: utils/CMakeFiles/jetson-utils.dir/cuda/jetson-utils_generated_cudaCrop.cu.o] Error 1
make[2]: *** [utils/CMakeFiles/jetson-utils.dir/build.make:105: utils/CMakeFiles/jetson-utils.dir/cuda/jetson-utils_generated_cudaFont.cu.o] Error 1
CMake Error at jetson-utils_generated_cudaGrayscale.cu.o.cmake:219 (message):
  Error generating
  /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/build/utils/CMakeFiles/jetson-utils.dir/cuda/./jetson-utils_generated_cudaGrayscale.cu.o
CMake Error at jetson-utils_generated_cudaFilterMode.cu.o.cmake:219 (message):
  Error generating
  /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/build/utils/CMakeFiles/jetson-utils.dir/cuda/./jetson-utils_generated_cudaFilterMode.cu.o
CMake Error at jetson-utils_generated_cudaColormap.cu.o.cmake:219 (message):
  Error generating
  /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/build/utils/CMakeFiles/jetson-utils.dir/cuda/./jetson-utils_generated_cudaColormap.cu.o
CMake Error at jetson-utils_generated_cudaDraw.cu.o.cmake:219 (message):
  Error generating
  /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/build/utils/CMakeFiles/jetson-utils.dir/cuda/./jetson-utils_generated_cudaDraw.cu.o
make[2]: *** [utils/CMakeFiles/jetson-utils.dir/build.make:112: utils/CMakeFiles/jetson-utils.dir/cuda/jetson-utils_generated_cudaGrayscale.cu.o] Error 1
make[2]: *** [utils/CMakeFiles/jetson-utils.dir/build.make:98: utils/CMakeFiles/jetson-utils.dir/cuda/jetson-utils_generated_cudaFilterMode.cu.o] Error 1
make[2]: *** [utils/CMakeFiles/jetson-utils.dir/build.make:77: utils/CMakeFiles/jetson-utils.dir/cuda/jetson-utils_generated_cudaColormap.cu.o] Error 1
make[2]: *** [utils/CMakeFiles/jetson-utils.dir/build.make:91: utils/CMakeFiles/jetson-utils.dir/cuda/jetson-utils_generated_cudaDraw.cu.o] Error 1
CMake Error at jetson-utils_generated_cudaNormalize.cu.o.cmake:219 (message):
  Error generating
  /development/helloaiworld/jetson-inference/AGX_Orin_Demos/1_Install/jetson-inference/build/utils/CMakeFiles/jetson-utils.dir/cuda/./jetson-utils_generated_cudaNormalize.cu.o
make[2]: *** [utils/CMakeFiles/jetson-utils.dir/build.make:119: utils/CMakeFiles/jetson-utils.dir/cuda/jetson-utils_generated_cudaNormalize.cu.o] Error 1
make[1]: *** [CMakeFiles/Makefile2:663: utils/CMakeFiles/jetson-utils.dir/all] Error 2
make: *** [Makefile:136: all] Error 2
[  1%] Building NVCC (Device) object utils/CMakeFiles/jetson-utils.dir/cuda/jetson-utils_generated_cudaYUV-YV12.cu.o
  Error generating
Trying this now - so far so good :) → Error while compiling Jetson Inference
We recommend using JetPack 6.0 for the jetson-inference due to the TensorRT compatibility issue.
The installation steps can be found in the link below:
