Stable Diffusion on Jetson AGX Orin and Xavier
Hi all,
I came up with a Dockerfile to run Stable Diffusion inside a contianer on Jetson.
Jetson AGX Orin and Jetson AGX Xavier with big VRAM space make it pretty straight forward to run Stable Diffusion, so have a try if you happen to have the hardware.
“Robots marching down a street in Japan”
grid-0001
Really cool, thanks for sharing @lekto!
Hi @lekto . I tried this on my Jetson Nano but got the error bellow with “./docker/run.sh”. I am working on this now but it would be nice if you can point out what is wrong here.
With only 4GB for RAM, I think it is almost impossible to run Stable Diffusion on Jetson Nano.
Yes, thank you for your information @lekto . I just want to run some tests with it.
Hi @lekto and @dusty_nv Would it be possible to use the xformers to speedup your image generation on Orin in a Docker container? Xformers · AUTOMATIC1111/stable-diffusion-webui Wiki · GitHub
Hi @lphung, if you check @lekto’s Dockerfile, that container image was built against JetPack 5.0:
So you would probably need to rebuild it against the version of JetPack you are on with Nano (JetPack 4.x)
Hi @seflands, I’m not entirely sure if this is applicable or not, but here’s also this optimized version of DALL-E Mini for PyTorch:
what about Jetson TX2? Does anybody tried to run Stable Diffusion there?
@dusty_nv how to rebuild the container for jetpack 5.1 , i am trying to run stable diffusion on xavier nx development kit
@lekto where u able to run the stable diffusion on xavier nx if so what are the packages and its version used can you please mention it here
@abhigoku10 you can find instructions for building containers from jetson-containers here:
The container images on DockerHub for stable-diffusion-webui are a month old: dustynv/stable-diffusion-webui:r35.4.1
@dusty_nv
Q1. thanks for sharing the link , i was able to setup the packages as mentioned by @lekto and was getting the following error
Is it related the the packages not downloading properly or something else ?
Q2. did u try running the GitHub - kuprel/min-dalle: min(DALL·E) is a fast, minimal port of DALL·E Mini to PyTorch at ur end was it successful ??
Q3 I am trying to any LLM and Stable diffusion models in Jetson Xavier , do u have any suggestions
