Issue with using nppiCompressMarkerLabels after nppiLabelMarkersUF
I used example provided here to calculate bounding boxes of connected components:
https://stackoverflow.com/a/57487119
Then I modified the code to make use of new nppiLabelMarkersUF function which promises speed-up.
I checked the result of nppiLabelMarkersUF and it seems to be ok.
The problem is that nppiCompressMarkerLabels returns an error (so if you run attached code it should stop at the second assert).
Note that I set
nStartingNumber = source_roi.width * source_roi.height
as is written here: https://docs.nvidia.com/cuda/npp/group__image__filter__compress__marker__labels.html
Could you help to resolve the issue?
#include <stdio.h>
#include <nppi_filtering_functions.h>
#include <assert.h>
#define WIDTH 16
#define HEIGHT 16
template <typename T>
void my_print(T * data, int w, int h) {
	for (int i = 0; i < h; i++)
		for (int j = 0; j < w; j++)
			if (data[i * w + j] == 255) printf("  *");
			else printf("%3hd", data[i * w + j]);
		printf("\n");
__global__ void bb(const T* __restrict__ i, int* __restrict__ maxh, int* __restrict__ minh, int* __restrict__ maxw, int* __restrict__ minw, int height, int width) {
	int idx = threadIdx.x + blockDim.x * blockIdx.x;
	int idy = threadIdx.y + blockDim.y * blockIdx.y;
	if ((idx < width) && (idy < height)) {
		T myval = i[idy * width + idx];
		if (myval > 0) {
			atomicMax(maxw + myval - 1, idx);
			atomicMin(minw + myval - 1, idx);
			atomicMax(maxh + myval - 1, idy);
			atomicMin(minh + myval - 1, idy);
int main() {
	Npp8u host_src[WIDTH * HEIGHT] =
	0, 0, 0, 0, 0, 0, 0, 0,255, 0, 0, 0, 0, 0, 0, 0,
	0, 255,255,255, 0, 0,255,255,255, 0, 0, 0, 0, 0, 0, 0,
	0, 255,255,255, 0, 0,255,255,255,255, 0, 0,255, 0, 0, 0,
	0, 0, 0, 0, 0, 0, 0,255,255,255, 0, 0, 0,255,255,255,
	0, 0, 0, 0, 0, 0, 0, 0,255, 0, 0, 0, 0,255,255,255,
	0, 0, 0,255, 0, 0, 0, 0, 0, 0, 0, 0, 0,255,255,255,
	0, 255,255, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
	0, 255,255,255, 0, 0, 0, 0,255, 0, 0, 0, 0, 0, 0, 0,
	0, 255,255,255,255, 0, 0,255,255,255, 0, 0, 0, 0, 0, 0,
	0, 0,255,255,255, 0,255,255,255,255,255, 0, 0, 0, 0, 0,
	0, 0, 0,255, 0, 0, 0,255,255,255, 0, 0, 0, 0, 0, 0,
	0, 255,255,255, 0, 0, 0, 0, 0, 0, 0, 0, 0,255,255,255,
	0, 255,255,255, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0
	Npp8u* device_src;
	Npp32u* device_dst;
	cudaMalloc((void**)& device_src, sizeof(Npp8u) * WIDTH * HEIGHT);
	cudaMalloc((void**)& device_dst, sizeof(Npp32u) * WIDTH * HEIGHT);
	cudaMemcpy(device_src, host_src, sizeof(Npp8u) * WIDTH * HEIGHT, cudaMemcpyHostToDevice);
	int buffer_size;
	NppiSize source_roi = { WIDTH, HEIGHT };
	NppStatus e = nppiLabelMarkersUFGetBufferSize_32u_C1R(source_roi, &buffer_size);
	assert(e == NPP_NO_ERROR);
	Npp8u* buffer;
	cudaMalloc((void**)& buffer, buffer_size);
	int bs;
	e = nppiCompressMarkerLabelsGetBufferSize_16u_C1R(1, &bs);
	if (bs > buffer_size) {
		buffer_size = bs;
		cudaFree(buffer);
		cudaMalloc(&buffer, buffer_size);
	int max;
	e = nppiLabelMarkersUF_8u32u_C1R(device_src, sizeof(Npp8u) * WIDTH, device_dst, sizeof(Npp32u) * WIDTH, source_roi, nppiNormInf, buffer);
	e = nppiCompressMarkerLabels_32u_C1IR(device_dst, sizeof(Npp32u) * WIDTH, source_roi, source_roi.width * source_roi.height, &max, buffer);
	int* maxw, * maxh, * minw, * minh, * d_maxw, * d_maxh, * d_minw, * d_minh;
	maxw = new int[max];
	maxh = new int[max];
	minw = new int[max];
	minh = new int[max];
	cudaMalloc(&d_maxw, max * sizeof(int));
	cudaMalloc(&d_maxh, max * sizeof(int));
	cudaMalloc(&d_minw, max * sizeof(int));
	cudaMalloc(&d_minh, max * sizeof(int));
	for (int i = 0; i < max; i++) {
		maxw[i] = 0;
		maxh[i] = 0;
		minw[i] = WIDTH;
		minh[i] = HEIGHT;
	cudaMemcpy(d_maxw, maxw, max * sizeof(int), cudaMemcpyHostToDevice);
	cudaMemcpy(d_maxh, maxh, max * sizeof(int), cudaMemcpyHostToDevice);
	cudaMemcpy(d_minw, minw, max * sizeof(int), cudaMemcpyHostToDevice);
	cudaMemcpy(d_minh, minh, max * sizeof(int), cudaMemcpyHostToDevice);
	dim3 block(32, 32);
	dim3 grid((WIDTH + block.x - 1) / block.x, (HEIGHT + block.y - 1) / block.y);
	bb << <grid, block >> > (device_src, d_maxh, d_minh, d_maxw, d_minw, HEIGHT, WIDTH);
	cudaMemcpy(maxw, d_maxw, max * sizeof(int), cudaMemcpyDeviceToHost);
	cudaMemcpy(maxh, d_maxh, max * sizeof(int), cudaMemcpyDeviceToHost);
	cudaMemcpy(minw, d_minw, max * sizeof(int), cudaMemcpyDeviceToHost);
	cudaMemcpy(minh, d_minh, max * sizeof(int), cudaMemcpyDeviceToHost);
	Npp32u* dst = new Npp32u[WIDTH * HEIGHT];
	cudaMemcpy(dst, device_dst, sizeof(Npp32u) * WIDTH * HEIGHT, cudaMemcpyDeviceToHost);
	printf("*******INPUT************\n");
	my_print(host_src, WIDTH, HEIGHT);
	printf("******OUTPUT************\n");
	my_print(dst, WIDTH, HEIGHT);
	printf("compressed max: %d\n", max);
	printf("bounding boxes:\n");
		printf("label %d, maxh: %d, minh: %d, maxw: %d, minw: %d\n", i + 1, maxh[i], minh[i], maxw[i], minw[i]);
Seems like I found a fix, line 82 should be:
e = nppiCompressMarkerLabelsGetBufferSize_32u_C1R(WIDTH*HEIGHT, &bs);
Also line 117 should be:
bb << <grid, block >> > (device_dst, d_maxh, d_minh, d_maxw, d_minw, HEIGHT, WIDTH);
Now I noticed that due to the fact that nStartingNumber is much bigger, overall performance got worse.
I.e. nppiLabelMarkersUF is much faster than nppiLabelMarkers but nppiCompressMarkerLabels is even more slower, such that on image 1000x1000 I got 10x worse performance.
Any suggestions on how to improve nppiCompressMarkerLabels?
Hi @aslyansky.m
Did you (or anyone) solve this problem? I am seeing similar results.
Thanks,
Gary
Hi @gary.ballantyne,
There is no fix, the function just has poor performance. I’ve spent some time trying to implement faster compression by myself and it worked.
But eventually since I was interested only in computing bounding boxes I calculated them for all the possible labels and then filtering empty indices which gave better performance.
In the end, ironically, I couldn’t use this new algorithm at all because it comes with cuda 10.1 which is not yet available for Jetson.
So I used one of the algorithms here:
https://github.com/prittt/YACCLAB
Performance was even better because you can choose the best algorithm based on properties of your problem (after benchmarking).
Also you can probably find there a faster code ccl compression.
Regards
