have an issue when trying to build the kernel for Tegra TX2 using make ARCH=arm64 O=KERNEL_OUT CROSS_COMPILE={CROSS_COMPILE}
Get the following error
sudo make ARCH=arm64 O=KERNEL_OUT CROSS_COMPILE={CROSS_COMPILE} -j12
make[1]: Entering directory ‘/home/alphi/nvidia/nvidia_sdk/JetPack_4.2_Linux_P2888/Linux_for_Tegra/sources/kernel/kernel-4.9/build’
CHK include/config/kernel.release
GEN ./Makefile
CHK include/generated/uapi/linux/version.h
make[2]: *** No rule to make target ‘dtbs’. Stop.
arch/arm64/Makefile:124: recipe for target ‘dtbs’ failed
make[1]: *** [dtbs] Error 2
make[1]: *** Waiting for unfinished jobs…
make[1]: Leaving directory ‘/home/alphi/nvidia/nvidia_sdk/JetPack_4.2_Linux_P2888/Linux_for_Tegra/sources/kernel/kernel-4.9/build’
Makefile:170: recipe for target ‘sub-make’ failed
make: *** [sub-make] Error 2
The file is located here:
/home/alphi/nvidia/nvidia_sdk/JetPack_4.2_Linux_P2888/Linux_for_Tegra/sources/hardware/nvidia/platform/t19x/galen/kernel-dts/tegra194-p2888-0001-p2822-0000.dts
though it appears to be looking in the following directory …/kernel-4.9/arch/arm64/boot/dts where it is not located. Not sure why it cant find it. Even when i copied the dts files over to the directory …/kernel-4.9/arch/arm64/boot/dts. I still get the same error message above
