I’m having issues when trying to install Nvidia drivers via repository. I was able to do it previously with no issues. However, I just reformatted PC and am having issues this time around despite installing same drivers from same repository with same commands.
Attached is the output of nvidia-bug-report.sh
nvidia-bug-report.log.gz (86.4 KB)
┌──(name㉿host)-[~]
└─$ apt search nvidia-driver
Sorting... Done
Full Text Search... Done
nvidia-driver/kali-rolling,now 470.94-1 amd64 [installed]
NVIDIA metapackage
┌──(name㉿host)-[~]
└─$ nvidia-smi
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
┌──(name㉿host)-[~]
└─$ lspci -s 1:00.0 -v 9 ⨯
01:00.0 VGA compatible controller: NVIDIA Corporation GA104M [GeForce RTX 3070 Mobile / Max-Q] (rev a1) (prog-if 00 [VGA controller])
Subsystem: ASUSTeK Computer Inc. GA104M [GeForce RTX 3070 Mobile / Max-Q]
Physical Slot: 0
Flags: fast devsel, IRQ 255, IOMMU group 11
Memory at fb000000 (32-bit, non-prefetchable) [disabled] [size=16M]
Memory at fc00000000 (64-bit, prefetchable) [disabled] [size=8G]
Memory at fe00000000 (64-bit, prefetchable) [disabled] [size=32M]
I/O ports at e000 [disabled] [size=128]
Expansion ROM at fc000000 [disabled] [size=512K]
Capabilities: <access denied>
Kernel modules: nvidia
