Thanks for your patience.
Here are some of the suggestions:
1.
The input physical address for io_remap_pfn_range should be address of struct page on Jetson.
Please ensure to compile the sources with the Jetson version of nv-p2p.h.
Something like:
#if (defined(CONFIG_ARM64) && defined(CONFIG_ARCH_TEGRA))
dmachan->reader_addr[j] = page_to_pfn((struct page*)nvp);
#else
dmachan->reader_addr[j] = (uint32_t*)(nvp->physical_address + offset);
#endif
It looks like the nv-p2p.h header has different page_table struct fields for desktop and Jetson:
Desktop:
typedef
struct nvidia_p2p_page {
uint64_t physical_address;
union nvidia_p2p_request_registers {
struct {
uint32_t wreqmb_h;
uint32_t rreqmb_h;
uint32_t rreqmb_0;
uint32_t reserved[3];
} fermi;
} registers;
} nvidia_p2p_page_t;
typedef
struct nvidia_p2p_page_table {
uint32_t version;
uint32_t page_size; /* enum nvidia_p2p_page_size_type */
struct nvidia_p2p_page **pages;
uint32_t entries;
uint8_t *gpu_uuid;
} nvidia_p2p_page_table_t;
Jetson:
typedef struct nvidia_p2p_page_table {
u32 version;
u32 page_size;
u64 size;
u32 entries;
struct page **pages;
u64 vaddr;
u32 mapped;
struct mm_struct *mm;
struct mmu_notifier mn;
struct mutex lock;
void (*free_callback)(void *data);
void *data;
2.
Ensure to follow “Modification to Kernel API” from https://developer.nvidia.com/blog/gpudirect-rdma-nvidia-jetson-agx-xavier/.
The mapping size should be multiple of 4K, Write combine requirement while remapping.
