Issues using appsrc and nvjpegdec
Xavier AGX
Deepstream 6.3
Jetpack 5.1.1
The current pipeline, which works, is
appsrc → nvvideoconvert → nvstreammux → nvinfer …
I’m given a stream of jpeg file locations which inside of the appsrc callback I decode and copy the pixel data into a gstreamer buffer and send it to the pipeline. This works fine but I wanted to experiment with using nvjpegdec to maybe speed up that part a bit.
appsrc → nvjpegdec → nvvideoconvert → nvstreammux → nvinfer
Now inside the appsrc callback I load the bytes into memory and put that in a buffer and send it. Making sure to update the caps of appsrc to “image/jpeg”. The pipeline runs fine but only one image is ever sent. Like, if I process 20 different jpegs all the results are identical to the first jpeg. Which is really weird. I can’t share the code here but wanted to ask if this approach would even work? I dug up one previous discussion about this approach and the conclusion was to do my first approach Nvjpegdec lost buffer nvds meta - #12 by Fiona.Chen but why does it kind of work? That’s the confusing part.
Thank you
yes, nvjpegdec can decode jpg files. please refer to this pipeline.
gst-launch-1.0 multifilesrc  location=/opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-can-orientation-app/data/sample1/"test_sample_%04d.jpg" ! nvjpegdec gpu-id=2 ! mux.sink_0 nvstreammux name=mux ! nvinferserver config-file-path=$MODEL_CONFIG ! fakesink
can you use the following simplified pipeline to check if the output is fine.
appsrc → nvjpegdec  -> nv3dsink
After some more trial and error I’ve found a specific example
appsrc -> jpegparse -> jpegdec -> nvvideoconvert → nvstreammux → nvinfer ....
works as expected. If I send 20 images through I get 20 different results from nvinfer
appsrc -> jpegparse -> nvjpegdec -> nvvideoconvert → nvstreammux → nvinfer ....
and
appsrc -> nvjpegdec -> nvvideoconvert → nvstreammux → nvinfer ....
and
appsrc -> jpegparse -> nvv4l2decoder -> nvvideoconvert → nvstreammux → nvinfer ....
All have the same issue where only the first image is processed and all results after that are just copies of the first.
I will try to get a minimal repro working this weekend.
What I was seeing was one bug and one expected expected and documented behavior.
  1. NvJPEGDecoder generates the same output if called twice with different input buffer
Nvjpegdec is indeed returning the same image when used to decode a series of images. A fix is available but upgrading the Jetpack version I’m using isn’t an option for now.
  1. Frequently Asked Questions — DeepStream 6.3 Release documentation
mjpeg support needs to be explicitly enabled to support this use case. I didn’t understand what mjpeg was and didn’t think my use case applied but it did. So I’m able to use nvv4l2decoder to decode jpeg images.
Sorry for the confusion, thanks for the help.
