Nvv4l2decoder: output last input result
GPU T4
• DeepStream Version
deepstream-5.1
• TensorRT Version
tensorrt-7.2.2.3
NVIDIA-SMI 470.57.02 Driver Version: 470.57.02 CUDA Version: 11.4
bugs
I listen a http port to receive jpg image , then use appsrc send to the pipeline, the pipeline dot as follow:
when I use appsrc send the first jpg image to pipeline, the nvv4l2decoder not src anything when I probe src buffer .
when I use appsrc send the second jpg image to pipeline, the nvv4l2decoder src the first
jpg image decode data .
Please help me that’s why and how to resolve .
There is appsrc sample in deepstream sample codes. Please refer to deepstream-appsrc-test.
https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_C_Sample_Apps.html
the demo I tried , If send the first buffer, the nvv4l2decoder only create src task
GST_PADS gstpad.c:6154:gst_pad_start_task:<nvv4l2decoder:src> created task 0x564198357830
if probe the nvv4l2decoder src buffer, there is no callback .
when I send the second buffer, the first buffer callback run .
or I send EOS to the pipeline line , the first buffer callback run .
the first buffer send log
0:00:05.375277852  3238 0x5593a3c18de0 ERROR                   v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:05.375316293  3238 0x5593a3c18de0 ERROR                   v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:05.375323894  3238 0x5593a3c18de0 ERROR                   v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:05.375376611  3238 0x5593a3c18de0 ERROR                   v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:05.375385462  3238 0x5593a3c18de0 ERROR                   v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:05.375419566  3238 0x5593a3c18de0 ERROR                   v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:05.375428031  3238 0x5593a3c18de0 ERROR                   v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:05.375471660  3238 0x5593a3c18de0 ERROR                   v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:05.375480121  3238 0x5593a3c18de0 ERROR                   v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:05.375526429  3238 0x5593a3c18de0 ERROR                   v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:05.375535126  3238 0x5593a3c18de0 ERROR                   v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:05.375566514  3238 0x5593a3c18de0 ERROR                   v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:05.375574617  3238 0x5593a3c18de0 ERROR                   v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:05.375605746  3238 0x5593a3c18de0 ERROR                   v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:05.375613588  3238 0x5593a3c18de0 ERROR                   v4l2 gstv4l2object.c:2077:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:05.375719703  3238 0x5593a3c18de0 INFO                    v4l2 gstv4l2object.c:4490:gst_v4l2_object_probe_caps:<nvv4l2decoder:src> probed caps: image/jpeg, framerate=(fraction)[ 0/1, 2147483647/1 ], width=(int)1920, height=(int)1088, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string){ bt601, smpte240m, bt709, 2:4:5:2, 2:4:5:3, 1:4:7:1, 2:4:7:1, 2:4:12:8, bt2020, 2:0:0:0 }; video/x-raw, format=(string)NV12, framerate=(fraction)[ 0/1, 2147483647/1 ], width=(int)1920, height=(int)1088, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string){ progressive, interleaved }, colorimetry=(string){ bt601, smpte240m, bt709, 2:4:5:2, 2:4:5:3, 1:4:7:1, 2:4:7:1, 2:4:12:8, bt2020, 2:0:0:0 }; video/mpeg, mpegversion=(int)4, systemstream=(boolean)false, framerate=(fraction)[ 0/1, 2147483647/1 ], width=(int)1920, height=(int)1088, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string){ bt601, smpte240m, bt709, 2:4:5:2, 2:4:5:3, 1:4:7:1, 2:4:7:1, 2:4:12:8, bt2020, 2:0:0:0 }; video/mpeg, mpegversion=(int)2, framerate=(fraction)[ 0/1, 2147483647/1 ], width=(int)1920, height=(int)1088, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string){ bt601, smpte240m, bt709, 2:4:5:2, 2:4:5:3, 1:4:7:1, 2:4:7:1, 2:4:12:8, bt2020, 2:0:0:0 }; video/x-vp9, framerate=(fraction)[ 0/1, 2147483647/1 ], width=(int)1920, height=(int)1088, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string){ bt601, smpte240m, bt709, 2:4:5:2, 2:4:5:3, 1:4:7:1, 2:4:7:1, 2:4:12:8, bt2020, 2:0:0:0 }; video/x-vp8, framerate=(fraction)[ 0/1, 2147483647/1 ], width=(int)1920, height=(int)1088, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string){ bt601, smpte240m, bt709, 2:4:5:2, 2:4:5:3, 1:4:7:1, 2:4:7:1, 2:4:12:8, bt2020, 2:0:0:0 }; video/x-h265, stream-format=(string)byte-stream, alignment=(string)au, framerate=(fraction)[ 0/1, 2147483647/1 ], width=(int)1920, height=(int)1088, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string){ bt601, smpte240m, bt709, 2:4:5:2, 2:4:5:3, 1:4:7:1, 2:4:7:1, 2:4:12:8, bt2020, 2:0:0:0 }; video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, framerate=(fraction)[ 0/1, 2147483647/1 ], width=(int)1920, height=(int)1088, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string){ bt601, smpte240m, bt709, 2:4:5:2, 2:4:5:3, 1:4:7:1, 2:4:7:1, 2:4:12:8, bt2020, 2:0:0:0 }
0:00:05.375897641  3238 0x5593a3c18de0 INFO               GST_EVENT gstevent.c:814:gst_event_new_caps: creating caps event video/x-raw(memory:NVMM), format=(string)NV12, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)1/1
0:00:05.375973925  3238 0x5593a3c18de0 INFO               GST_EVENT gstevent.c:814:gst_event_new_caps: creating caps event video/x-raw(memory:NVMM), format=(string)NV12, width=(int)1920, height=(int)1080, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, framerate=(fraction)1/1, batch-size=(int)1, num-surfaces-per-frame=(int)1
0:00:05.376177095  3238 0x5593a3c18de0 INFO                    task gsttask.c:457:gst_task_set_lock: setting stream lock 0x5593a3c1cda0 on task 0x5593a3c1f710
0:00:05.376199800  3238 0x5593a3c18de0 INFO                GST_PADS gstpad.c:6154:gst_pad_start_task:<stream-muxer:src> created task 0x5593a3c1f710
0:00:05.376395297  3238 0x5593a3c18de0 INFO                    v4l2 gstv4l2object.c:3152:gst_v4l2_object_setup_pool:<nvv4l2decoder:src> accessing buffers via mode 2
0:00:05.376517142  3238 0x5593a3c18de0 INFO          v4l2bufferpool gstv4l2bufferpool.c:826:gst_v4l2_buffer_pool_set_config:<nvv4l2decoder:pool:src> increasing minimum buffers to 2
0:00:05.376536176  3238 0x5593a3c18de0 INFO          v4l2bufferpool gstv4l2bufferpool.c:833:gst_v4l2_buffer_pool_set_config:<nvv4l2decoder:pool:src> increasing minimum buffers to 4
0:00:05.376546758  3238 0x5593a3c18de0 INFO          v4l2bufferpool gstv4l2bufferpool.c:839:gst_v4l2_buffer_pool_set_config:<nvv4l2decoder:pool:src> reducing maximum buffers to 32
0:00:05.376559556  3238 0x5593a3c18de0 INFO          v4l2bufferpool gstv4l2bufferpool.c:850:gst_v4l2_buffer_pool_set_config:<nvv4l2decoder:pool:src> can't allocate, setting maximum to minimum
0:00:05.376574253  3238 0x5593a3c18de0 INFO          v4l2bufferpool gstv4l2bufferpool.c:855:gst_v4l2_buffer_pool_set_config:<nvv4l2decoder:pool:src> adding needed video meta
0:00:05.376768882  3238 0x5593a3c18de0 INFO          v4l2bufferpool gstv4l2bufferpool.c:839:gst_v4l2_buffer_pool_set_config:<nvv4l2decoder:pool:src> reducing maximum buffers to 32
0:00:05.376785807  3238 0x5593a3c18de0 INFO          v4l2bufferpool gstv4l2bufferpool.c:850:gst_v4l2_buffer_pool_set_config:<nvv4l2decoder:pool:src> can't allocate, setting maximum to minimum
0:00:05.376804599  3238 0x7faba40034f0 INFO               GST_EVENT gstevent.c:895:gst_event_new_segment: creating segment event time segment start=0:00:00.000000000, offset=0:00:00.000000000, stop=99:99:99.999999999, rate=1.000000, applied_rate=1.000000, flags=0x00, time=0:00:00.000000000, base=0:00:00.000000000, position 0:00:00.000000000, duration 99:99:99.999999999
0:00:05.376868624  3238 0x5593a3c18de0 WARN            v4l2videodec gstv4l2videodec.c:1673:gst_v4l2_video_dec_decide_allocation:<nvv4l2decoder> Duration invalid, not setting latency
0:00:05.376977022  3238 0x5593a3c18de0 WARN          v4l2bufferpool gstv4l2bufferpool.c:1066:gst_v4l2_buffer_pool_start:<nvv4l2decoder:pool:src> Uncertain or not enough buffers, enabling copy threshold
0:00:05.377247522  3238 0x5593a3c18de0 INFO                    task gsttask.c:457:gst_task_set_lock: setting stream lock 0x5593a3c1cb50 on task 0x5593a3c1f830
0:00:05.377278048  3238 0x5593a3c18de0 INFO                GST_PADS gstpad.c:6154:gst_pad_start_task:<nvv4l2decoder:src> created task 0x5593a3c1f830
the second buffer send log
start feed
send buffer success,frame=2,size=119669
0:00:10.378290484  3238 0x5593a3c18de0 INFO             JA_STREAMER metric.cpp:21:metric_probe: element app-source pad src received,buffer=0x7faba4026e80,size=119669,pts=40000000
0:00:10.378345295  3238 0x5593a3c18de0 INFO             JA_STREAMER metric.cpp:21:metric_probe: element jpegparse0 pad sink received,buffer=0x7faba4026e80,size=119669,pts=40000000
0:00:10.378896654  3238 0x5593a3c18de0 INFO             JA_STREAMER metric.cpp:21:metric_probe: element jpegparse0 pad src received,buffer=0x7faba4026e80,size=119669,pts=40000000
0:00:10.378926113  3238 0x5593a3c18de0 INFO             JA_STREAMER metric.cpp:21:metric_probe: element nvv4l2decoder pad sink received,buffer=0x7faba4026e80,size=119669,pts=40000000
0:00:10.379494580  3238 0x5593a3c19320 WARN          v4l2bufferpool gstv4l2bufferpool.c:1513:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder:pool:src> Driver should never set v4l2_buffer.field to ANY
0:00:10.379775119  3238 0x5593a3c19320 INFO            videodecoder gstvideodecoder.c:3201:gst_video_decoder_clip_and_push_buf:<nvv4l2decoder> First buffer since flush took 0:00:10.117007518 to produce
0:00:10.379814495  3238 0x5593a3c19320 INFO             JA_STREAMER metric.cpp:21:metric_probe: element nvv4l2decoder pad src received,buffer=0x7faba4026930,size=64,pts=0
0:00:10.380003753  3238 0x7faba40034f0 INFO             JA_STREAMER metric.cpp:21:metric_probe: element stream-muxer pad src received,buffer=0x7faba4026600,size=64,pts=-1
0:00:10.380068660  3238 0x7faba40034f0 INFO             JA_STREAMER metric.cpp:21:metric_probe: element fakesink pad sink received,buffer=0x7faba4026600,size=64,pts=-1
0:00:10.380161383  3238 0x7faba40034f0 INFO              GST_STATES gstbin.c:3424:bin_handle_async_done:<dstest-appsrc-pipeline> committing state from READY to PAUSED, old pending PLAYING
0:00:10.380180451  3238 0x7faba40034f0 INFO              GST_STATES gstbin.c:3453:bin_handle_async_done:<dstest-appsrc-pipeline> continue state change, pending PLAYING
0:00:10.380201899  3238 0x7faba40034f0 INFO              GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<dstest-appsrc-pipeline> notifying about state-changed READY to PAUSED (PLAYING pending)
0:00:10.380551029  3238 0x7fab88004a80 INFO              GST_STATES gstbin.c:3250:gst_bin_continue_func:<dstest-appsrc-pipeline> continue state change PAUSED to PLAYING, final PLAYING
0:00:10.380854344  3238 0x7fab88004a80 INFO               GST_EVENT gstevent.c:1388:gst_event_new_latency: creating latency event 0:00:00.000000000
0:00:10.380928001  3238 0x7fab88004a80 INFO                     bin gstbin.c:2783:gst_bin_do_latency_func:<dstest-appsrc-pipeline> configured latency of 0:00:00.000000000
0:00:10.380980450  3238 0x7fab88004a80 INFO              GST_STATES gstbin.c:2506:gst_bin_element_set_state:<fakesink> current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:10.381011946  3238 0x7fab88004a80 INFO              GST_STATES gstelement.c:2676:gst_element_continue_state:<fakesink> completed state change to PLAYING
0:00:10.381031284  3238 0x7fab88004a80 INFO              GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<fakesink> notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:10.381066985  3238 0x7fab88004a80 INFO              GST_STATES gstbin.c:2954:gst_bin_change_state_func:<dstest-appsrc-pipeline> child 'fakesink' changed state to 4(PLAYING) successfully
0:00:10.381092954  3238 0x7fab88004a80 INFO              GST_STATES gstbin.c:2506:gst_bin_element_set_state:<stream-muxer> current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:10.381625765  3238 0x7fab88004a80 INFO              GST_STATES gstelement.c:2676:gst_element_continue_state:<stream-muxer> completed state change to PLAYING
0:00:10.381648383  3238 0x7fab88004a80 INFO              GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<stream-muxer> notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:10.381684929  3238 0x7fab88004a80 INFO              GST_STATES gstbin.c:2954:gst_bin_change_state_func:<dstest-appsrc-pipeline> child 'stream-muxer' changed state to 4(PLAYING) successfully
0:00:10.381705615  3238 0x7fab88004a80 INFO              GST_STATES gstbin.c:2506:gst_bin_element_set_state:<nvv4l2decoder> current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:10.381722085  3238 0x7fab88004a80 INFO              GST_STATES gstelement.c:2676:gst_element_continue_state:<nvv4l2decoder> completed state change to PLAYING
0:00:10.381734845  3238 0x7fab88004a80 INFO              GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<nvv4l2decoder> notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:10.381763571  3238 0x7fab88004a80 INFO              GST_STATES gstbin.c:2954:gst_bin_change_state_func:<dstest-appsrc-pipeline> child 'nvv4l2decoder' changed state to 4(PLAYING) successfully
0:00:10.381782109  3238 0x7fab88004a80 INFO              GST_STATES gstbin.c:2506:gst_bin_element_set_state:<jpegparse0> current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:10.381800298  3238 0x7fab88004a80 INFO              GST_STATES gstelement.c:2676:gst_element_continue_state:<jpegparse0> completed state change to PLAYING
0:00:10.381812453  3238 0x7fab88004a80 INFO              GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<jpegparse0> notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:10.381840231  3238 0x7fab88004a80 INFO              GST_STATES gstbin.c:2954:gst_bin_change_state_func:<dstest-appsrc-pipeline> child 'jpegparse0' changed state to 4(PLAYING) successfully
0:00:10.381858889  3238 0x7fab88004a80 INFO              GST_STATES gstbin.c:2506:gst_bin_element_set_state:<app-source> current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:10.381873009  3238 0x7fab88004a80 INFO              GST_STATES gstelement.c:2676:gst_element_continue_state:<app-source> completed state change to PLAYING
0:00:10.381884878  3238 0x7fab88004a80 INFO              GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<app-source> notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:10.381912387  3238 0x7fab88004a80 INFO              GST_STATES gstbin.c:2954:gst_bin_change_state_func:<dstest-appsrc-pipeline> child 'app-source' changed state to 4(PLAYING) successfully
0:00:10.381932074  3238 0x7fab88004a80 INFO              GST_STATES gstelement.c:2676:gst_element_continue_state:<dstest-appsrc-pipeline> completed state change to PLAYING
0:00:10.381944034  3238 0x7fab88004a80 INFO              GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<dstest-appsrc-pipeline> notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
Can you send your code for us to reproduce the problem?
