I am encountering an issue with my Riva setup, specifically related to Docker logs and memory consumption during the Riva server startup. I have been troubleshooting this problem, but I am unable to resolve it, so I would appreciate any assistance or insights.
Environment Details:
Riva Version : riva_quickstart_arm64_v2.19
Docker Version : 28.0.4.5 LTS
OS : ubuntu 22.04
Model : jetson orin nano developer kit
Issue:
- Docker Logs : When attempting to retrieve Docker logs for the
riva-speech
container, I am not getting any output, even though I have confirmed that Docker is running in the background. This behavior is similar to a past issue where the Docker service wasn’t running, but I have verified that it is operational now.
- Memory Consumption : Normally, when starting the Riva server, it consumes a large amount of memory (80-90%). However, this time, I am only seeing a modest increase of about 5-10%. This is unusual, and I suspect that it might indicate an underlying issue with the model or the server itself.
Troubleshooting Steps Taken:
- Confirmed that Docker is running.
- Verified that no issues were found with the Docker service.
- Checked memory usage during Riva server startup.
- Attempted to access the
riva-speech
Docker logs without success.
Questions:
Could the lack of memory consumption during startup indicate that the model hasn’t loaded properly into memory?
Could this behavior be related to an issue with the model itself?
What additional steps can I take to further diagnose and resolve the issue?
Could you share the detailed steps you used?
Do you follow Jetson-container?
Following up on the health check failure, I’ve identified some errors in the riva_start.sh
script.
jetson@ubuntu:~/riva_quickstart_arm64_v2.19.0$ bash riva_start.sh
Starting Riva Speech Services. This may take several minutes depending on the number of models deployed.
Performing health check for Riva server on port 50051...
Attempt 1/30: Checking server health...
[WARN] Health probe failed on attempt 1. Exit code: 1
[DEBUG] grpc_health_probe output:
Error response from daemon: container 345ca4dafe96f805c1ddd88db1b9da9cb77fa6b900312e56e88cf7fde6f61bc3 is not running
This indicates that the Docker container isn’t running. When attempting to manually run the container, I encountered the following error:
jetson@ubuntu:~/riva_quickstart_arm64_v2.19.0$ docker ps -a
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
345ca4dafe96 [nvcr.io/nvidia/riva/riva-speech:2.19.0-l4t-aarch64](http://nvcr.io/nvidia/riva/riva-speech:2.19.0-l4t-aarch64) "start-riva --riva-u…" 11 minutes ago Created riva-speech
28684827e309 hello-world "/hello" 49 minutes ago Exited (0) 49 minutes ago elastic_sanderson
jetson@ubuntu:~/riva_quickstart_arm64_v2.19.0$ docker run 345ca4dafe96
Unable to find image '345ca4dafe96:latest' locally
docker: Error response from daemon: pull access denied for 345ca4dafe96, repository does not exist or may require 'docker login': denied: requested access to the resource is denied.
See 'docker run --help'.
It seems like there might be an issue with pulling the Docker image or accessing the repository. Could you please provide any insights or suggestions on how to address this?
