Running Speech Recognition (Nividia Riva) on my Jetson
Hey all!
I’m trying very hard to get text-to-speech working locally on my Jetson Orin Nano via Nvidia Riva.
After going through the installation steps and finally running sudo bash riva_start.sh my system gets stuck on: Waiting for Riva server to load all models...retrying in 10 seconds until eventually erroring out.
What’s frustrating is that when I try to check the logs with docker logs riva-speech I get no output, error or otherwise.
I’ve tried this on Jetpack 6.2 and 6.1. Do you think I should try it on 6.0?
I’ve also tried running riva_clean and reinstalling with riva_init.
Please help!
-Wes
Could you try if the riva from the jetson-container works?
Update: I tried on Jetpack 6.0 and same issue.
What do you mean by run from the docker container? I believe that’s what I’m doing. I’ve been following this tutorial.
It utilizes docker, and at the end “docker logs riva-speech” is the recommended command to debug the failure. But it doesn’t provide an output, like I was saying before.
Thanks for the reply - please help!!!
I would like to try this. I do think it’s different from what the quickstart was telling me. Could you explain how? I have not done this before with jetson-containers
Which container do you use?
Jetson-container is built for the Jetson environment so the image should work on Jetson.
Could you share your installation steps with us as well?
Do you follow the RIVA document below?
What command do I run to run the image on Jetson?
docker run --rm -it dustynv/riva-client:python-r36.2.0 bash
This seems to have at least run the docker container successfully though when I ran one of the provided Python test scripts, it couldn’t detect my USB microphone. My microphone does work outside of the Docker container.
@AastaLLL
You will need some extra flag to enable docker to access the USB microphone.
Please find the topic below for more information:
