Hi to everyone,
I am trying to use riva on my jetson orin nano ( the 4gb module ), I have followed the quick start guide. However once i try to start via the “riva_start.sh” script, the associated riva_speech container stops as i cannot connect to a server on 127.0.0.1:8001.
So the scripts just waits until it stops.
I also attached riva_speech container logs and config.sh.
Thank you in advance for your help!
riva_speech.txt (96 Bytes)
config.sh (13.3 KB)
HI @mattsays
Thanks for your interest in Riva
Apologies you are facing issue
Request to kindly share details on
- Jetpack version used and verify Jetpack is installed correct, The Version needed for Riva 2.11.0 is
- JetPack 5.1.1
- JetPack 5.1
- Verify the runtime is set to Nvidia
You have set the default runtime to nvidia on the Jetson platform by adding the following line in the /etc/docker/daemon.json file. Restart the Docker service using sudo systemctl restart docker after editing the file.
"default-runtime": "nvidia"
Please let me know if the above are set correct and still not working
Yes I am sure that I have the latest versions of Riva and JetPack and I also doublechecked the daemon.json option. However it still doesn’t work.
