Hardware - Jetson AGX Orin
Hardware - CPU
Operating System: JetPack 5.0.2
Riva Version: riva_quickstart_arm64_v2.8.1
TLT Version (if relevant)
How to reproduce the issue ? (This is for errors. Please share the command and the detailed log here)
Today I have flashed the latest JetPack 5.0.2 into the Jetson AGX Orin unit. Then I have downloaded the riva_quickstart_arm64_v2.8.1
When I run the bash riva_init.sh, it finishes without any error except the bash riva_start.sh.
Can you please give me the suggestion how to solve the problem?
Jimmy
Starting Riva Speech Services. This may take several minutes depending on the number of models deployed.
53b96b57a1999e4006324210317be0156a8a3bb9cb64bb476dc1e620468be53c
docker: Error response from daemon: failed to create shim: OCI runtime create failed: runc create failed: unable to start container process: error during container init: error running hook #0: error running hook: exit status 1, stdout: , stderr: Auto-detected mode as ‘csv’
invoking the NVIDIA Container Runtime Hook directly (e.g. specifying the docker --gpus flag) is not supported. Please use the NVIDIA Container Runtime instead.: unknown.
Error response from daemon: Container 53b96b57a1999e4006324210317be0156a8a3bb9cb64bb476dc1e620468be53c is not running
Waiting for Riva server to load all models…retrying in 10 seconds
complete log output of bash riva_init.sh and riva_start.sh
Thanks for your jist of log, i also recommend to check the NGC setup
the ngc files would be present in $HOME/.ngc
open the config file (PLEASE DO NOT EDIT THIS FILE), (PLEASE DO NOT SHARE THIS FILE AS IT CONTAINS SENSITIVE INFORMATION)
and check for format_type, if it is set as csv and not json,
Run ngc config set and change the type as json (prompted on step 3 after API key and ORG), and retry the setup again, and let us know if it works
Can you kindly verify Step 6 from the below document has been performed
You have set the default runtime to nvidia on the Jetson platform by adding the following line in the /etc/docker/daemon.json file. Restart the Docker service using sudo systemctl restart docker after editing the file. "default-runtime": "nvidia"
and perhaps try again
While first two commands has no problem, the riva_start.sh still face the same problem.
I am thinking to re-flash the JetPack5.0.2 image into my Jetson AGX Orin and then to try the Riva again. I guess that my docker may need to be downgraded?
If you have new suggestions, please let me know since I need to make the RIVA working on the Jetson Orin.
