Riva throwing "Health ready failed" on Jetson Orin AGX with Jetpack 6.0DP
Hardware - Jetson Orin AGX Developer Kit with 64 GB
Operating System- Ubuntu 22.04
Riva Version - 2.14
TLT Version (if relevant)
How to reproduce the issue ? (This is for errors. Please share the command and the detailed log here)
Installing and initiating works fine. Running the “riva_start.sh” throws after quite a number retries the error message, that “Health ready check failed”.
I think I had it working on 6.0 DP (briefly, went back to 5.1.1 for troubleshooting… I was only running ASR, TTS, and NMT. it might depend on which models you are trying to run in your config, but technically it won’t be supported on anything but JP 5.1.1 according to this. Support Matrix — NVIDIA Riva
Which models are you running?
The docker is Not starting with the out-of-the-box models… forget about finetuned models
It is ashaming that Nvidia is offering a developer edition jetpack but is not able to provide the baseline tools … I mean I did not expect it at the same time as the jetpack 6.0DP was published, but that 2 month ago!
I mean the jetson devices Are used for AI apps and if their new framework is not supporting their native AI tools, this ashaming!
What is a developer edition of a framework worth, if it does Not Support the basics?
Any updates on this front? I, too, am having a similar issue.
Jetson AGX Orin 64GB
Latest Jetpack, etc.
Hi @ismet.guelkanat
Thanks for your interest in Riva
Can you share the output of command
docker logs riva-speech
Can you share with us the Jetpack Version
NVIDIA JetPack™ version 5.1 or 5.1.1 is needed
Also can you confirm You have set the default runtime to nvidia on the Jetson platform Please share output of /etc/docker/daemon.json file.
Apologies for not being as detailed as I could have.
My current setup: Jetson AGX Orin Developer Kit - Jetpack 5.1.2 (L4T 35.4.1).
See below for my /etc/docker/daemon.json file:
“runtimes”: {
“nvidia”: {
“path”: “nvidia-container-runtime”,
“runtimeArgs”:
"default-runtime": "nvidia",
"data-root": "/ssd/docker"
My problem is solved. Unfortunately, for some reason I did not document how I solved it (and, I document everything).
I believe that it had something to do with incorrect /etc/docker/daemon.json settings.
