Issues with Speaker Diarization in Riva ASR - All Audio Segments Tagged as Person 0
I am encountering an issue while using speaker diarization with Riva ASR. When running the transcribe_file_offline.py script with diarization enabled, the audio is not being properly diarized. Instead of segmenting the audio by speaker, all segments are labeled as Person 0.
Steps Taken:
  1. I followed the tutorial provided in the Riva ASR Speaker Diarization Guide.
  2. I ensured that speaker diarization was enabled in the config.sh file by uncommenting the line for the rmir_diarizer_offline model.
  3. The Riva Speech Skills server has been deployed and is running.
  4. I installed the required Riva client library and have successfully connected to the server.
Command Used:
The command I am using to run the transcription with diarization enabled is:
bash
Copy
python3 transcribe_file_offline.py --input-file file_path --server localhost:50051 --language-code en-US --speaker-diarization --diarization-max-speakers 2
Expected Result:
The expectation is that the audio would be segmented by speaker, and each word in the transcript would be tagged with the appropriate speaker ID.
Actual Result:
Instead of properly segmenting the audio, the diarization process labels all segments as Person 0. This issue persists despite following all setup instructions and verifying the configuration.
What I Have Tried:
  • Double-checked the speaker diarization setup, including ensuring the diarization model is enabled.
  • Verified that the transcribe_file_offline.py script is executing correctly.
  • Tested with multiple audio files to confirm it isn’t specific to a particular file.
Questions:
  • Is there a specific issue with how the speaker diarization feature is being initialized or configured?
  • Could this be related to an issue with the model or an unsupported format?
  • Are there any additional debugging steps I should follow to resolve the issue?
Have you checked the following documentation:
The Riva documentation related to SD
Tutorial Example
Which Riva version are you using and which model are you trying?
Riva Version : riva_quickstart_arm64_v2.19
Docker Version : 28.0.4.5 LTS
OS : ubuntu 22.04
Model : jetson orin nano developer kit
Hey @satish.rathod.ov it looks like you’re using the older, offline diarization model. Is it possible for you to use the latest release streaming diarizer (details here ASR Overview — NVIDIA Riva) or do you have a specific offline usecase?
