Has anyone had success with installing JAX with GPU support on the Orin? I have followed steps for other Jetson devices from this thread, but have had no luck. Building from source with and without cuda results in the error messages attached.
Any help would be greatly appreciated
jax_build_log_cuda.txt (13.0 KB)
jax_build_log_cpu.txt (12.2 KB)
Based on the below error:
ERROR: ... Compiling tensorflow/compiler/xla/service/cpu/runtime_fp16.cc failed: (Exit 1): crosstool_wrapper_driver_is_not_gcc failed: error executing command
It seems there are some issues in the bazel setting.
Could you share the configuration you used with us as well?
