I would like to use CUDA (CUBLAS) in order to get product of :
C = A * B
, where:
Input matrix A:
3.000 1.000 2.000
1.000 2.000 3.000
Input matrix B:
0.000 1.000
2.000 1.000
2.000 3.000
Here is an implementation using JCuda
import java.util.Arrays;
/* Imports, JCublas */
import jcuda.*;
import jcuda.jcublas.*;
class JCublasSample
/* Main */
public static void main(String args[])
float h_A[];
float h_B[];
float h_C[];
Pointer d_A = new Pointer();
Pointer d_B = new Pointer();
Pointer d_C = new Pointer();
float alpha = 1.0f;
float beta = 0.0f;
/* Initialize JCublas */
JCublas.cublasInit();
/* Allocate host memory for the matrices */
// 3 columns, 2 rows
h_A = new float[] {3, 1, 2,
1, 2, 3};
// 2 columns, 3 rows
h_B = new float[] {
0, 1,
2, 1,
2, 3};
// 2 columns, 2 rows
h_C = new float[2*2];
/* Allocate device memory for the matrices */
JCublas.cublasAlloc(3*2, Sizeof.FLOAT, d_A);
JCublas.cublasAlloc(2*3, Sizeof.FLOAT, d_B);
JCublas.cublasAlloc(2*2, Sizeof.FLOAT, d_C);
/* Initialize the device matrices with the host matrices */
JCublas.cublasSetVector(3*2, Sizeof.FLOAT, Pointer.to(h_A), 1, d_A, 1);
JCublas.cublasSetVector(2*3, Sizeof.FLOAT, Pointer.to(h_B), 1, d_B, 1);
JCublas.cublasSetVector(2*2, Sizeof.FLOAT, Pointer.to(h_C), 1, d_C, 1);
int m = 2; // A.numRows();
int n = 2; // B.numColumns();
int k = 3; // A.numColumns();
int lda = 2; // A.numRows();
int ldb = 3; // B.numRows();
int ldc = 2; // C.numRows();
/* Performs operation using JCublas */
JCublas.cublasSgemm('n', 'n', m, n, k, alpha,
d_A, lda, d_B, ldb, beta, d_C, ldc);
/* Read the result back */
JCublas.cublasGetVector(2*2, Sizeof.FLOAT, d_C, 1, Pointer.to(h_C), 1);
/* Memory clean up */
JCublas.cublasFree(d_A);
JCublas.cublasFree(d_B);
JCublas.cublasFree(d_C);
/* Shutdown */
JCublas.cublasShutdown();
System.out.println(Arrays.toString(h_C));
Maven dependencies:
<dependency>
<groupId>org.jcuda</groupId>
<artifactId>jcuda</artifactId>
<version>0.8.0</version>
</dependency>
<dependency>
<artifactId>jcublas</artifactId>
</dependency>
<dependency>
<artifactId>jcufft</artifactId>
</dependency>
<dependency>
<artifactId>jcusparse</artifactId>
</dependency>
<dependency>
<artifactId>jcusolver</artifactId>
</dependency>
<dependency>
<artifactId>jcurand</artifactId>
</dependency>
<dependency>
<artifactId>jnvgraph</artifactId>
</dependency>
Problem:
Matrix product C = A*B should be:
6.000 10.000
10.000 12.000
But CUDA provides this (wrong) result:
6.0, 7.0,
13.0, 12.0
Any help would be very appreciated.
