I’m trying to flash my Jetson Orin Nano Developer Kit, but I’m stuck finding the correct SD card image.
I already tried following NVIDIA’s JetPack / Jetson Linux links, but they all redirect me to the JetPack 7.1 page (Thor / T4000 / AGX), and I can’t find any Orin Nano SD Card Image (JetPack 6 / R36.x).
I also tried an image previously (Jetson Nano / wrong model) and obviously it doesn’t boot — the board always falls back to UEFI HTTP boot.
Could someone please share:
The exact download link for the Jetson Orin Nano Developer Kit SD image
Which JetPack / L4T version actually works
Or confirm if you had the same issue recently
I just need the real SD card image path — the current NVIDIA pages are very confusing for this Orion Nano image download.
Thanks for visiting the NVIDIA Developer Forums.
To ensure better visibility and support, I’ve moved your post to the Jetson category where it’s more appropriate
Guilherme25. I am having the same issue. Broken links… I am not off to a great start.
Where you able to find the correct Orin Nano Developer Kit SD Image?
The links I am finding only point to jetsoninstaller-r38.4.0-2025-12-30-17-00-37-arm64.iso
When I try this one I get a error in Balenetcher when it validates the image. “Something went wrong. If it is a compressed image please check that the archive is not corrupted” I downloaded it three times over the past two days they are all identical with the following SHA-256 hash.
