HELP!!!
I have been running jetpack 4.5 on NVMe ssd on my xavier NX every thing worked fine.
I tried to upgrade from 4.5 to 4.6 as a small upgrade.
I don’t have another machine running Unix so it seams there is no way I can upgrade properly.
Although some new features are working on the “UPGRADE” most are not,
ALL I WANT IS THE SYSTEM RUNNING ON XAVIER NX AS BEFORE USING JETPACK 4.6.
I have tried sd card seems to have loads of error.
~$ apt depends nvidia-jetpack | awk '{print $2}' | xargs -I {} sudo apt install -y {}
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
[sudo] password for paul:
Reading package lists... Done
Building dependency tree
Reading state information... Done
nvidia-cuda is already the newest version (4.6-b199).
0 to upgrade, 0 to newly install, 0 to remove and 0 not to upgrade.
nvidia-opencv is already the newest version (4.6-b199).
nvidia-cudnn8 is already the newest version (4.6-b199).
nvidia-tensorrt is already the newest version (4.6-b199).
nvidia-visionworks is already the newest version (4.6-b199).
The following additional packages will be installed:
docker-ce docker-ce-rootless-extras nvidia-docker2 pigz
Suggested packages:
cgroupfs-mount | cgroup-lite
Recommended packages:
slirp4netns
The following NEW packages will be installed
docker-ce docker-ce-rootless-extras nvidia-container nvidia-docker2 pigz
0 to upgrade, 5 to newly install, 0 to remove and 0 not to upgrade.
Need to get 0 B/21.2 MB of archives.
After this operation, 95.5 MB of additional disk space will be used.
debconf: Delaying package configuration, since apt-utils is not installed.
Selecting previously unselected package pigz.
(Reading database ... 158686 files and directories currently installed.)
Preparing to unpack .../archives/pigz_2.4-1_arm64.deb ...
Unpacking pigz (2.4-1) ...
Selecting previously unselected package docker-ce.
Preparing to unpack .../docker-ce_5%3a20.10.8~3-0~ubuntu-bionic_arm64.deb ...
Unpacking docker-ce (5:20.10.8~3-0~ubuntu-bionic) ...
Selecting previously unselected package nvidia-docker2.
Preparing to unpack .../nvidia-docker2_2.2.0-1_all.deb ...
Unpacking nvidia-docker2 (2.2.0-1) ...
Selecting previously unselected package nvidia-container.
Preparing to unpack .../nvidia-container_4.6-b199_arm64.deb ...
Unpacking nvidia-container (4.6-b199) ...
Selecting previously unselected package docker-ce-rootless-extras.
Preparing to unpack .../docker-ce-rootless-extras_5%3a20.10.8~3-0~ubuntu-bionic_arm64.deb ...
Unpacking docker-ce-rootless-extras (5:20.10.8~3-0~ubuntu-bionic) ...
Setting up docker-ce (5:20.10.8~3-0~ubuntu-bionic) ...
Job for docker.service failed because the control process exited with error code.
See "systemctl status docker.service" and "journalctl -xe" for details.
invoke-rc.d: initscript docker, action "start" failed.
● docker.service - Docker Application Container Engine
Loaded: loaded (/lib/systemd/system/docker.service; enabled; vendor preset: enabled)
Active: activating (auto-restart) (Result: exit-code) since Thu 2021-09-02 12:18:55 BST; 15ms ago
Docs: https://docs.docker.com
Process: 12497 ExecStart=/usr/bin/dockerd -H fd:// --containerd=/run/containerd/containerd.sock (code=exited, status=1/FAILURE)
Main PID: 12497 (code=exited, status=1/FAILURE)
Sep 02 12:18:55 xavier systemd[1]: Failed to start Docker Application Container Engine.
dpkg: error processing package docker-ce (--configure):
installed docker-ce package post-installation script subprocess returned error exit status 1
Setting up docker-ce-rootless-extras (5:20.10.8~3-0~ubuntu-bionic) ...
Setting up pigz (2.4-1) ...
dpkg: dependency problems prevent configuration of nvidia-docker2:
nvidia-docker2 depends on docker-ce (>= 18.06.0~ce~3-0~ubuntu) | docker-ee (>= 18.06.0~ce~3-0~ubuntu) | docker.io (>= 18.06.0); however:
Package docker-ce is not configured yet.
Package docker-ee is not installed.
Package docker.io is not installed.
dpkg: error processing package nvidia-docker2 (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of nvidia-container:
nvidia-container depends on nvidia-docker2 (= 2.2.0-1); however:
Package nvidia-docker2 is not configured yet.
dpkg: error processing package nvidia-container (--configure):
Processing triggers for man-db (2.8.3-2ubuntu0.1) ...
No apport report written because the error message indicates it's a follow-up error from a previous failure.
Processing triggers for systemd (237-3ubuntu10.51) ...
Errors were encountered while processing:
docker-ce
nvidia-docker2
nvidia-container
E: Sub-process /usr/bin/dpkg returned an error code (1)
nvidia-vpi is already the newest version (4.6-b199).
3 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Active: activating (auto-restart) (Result: exit-code) since Thu 2021-09-02 12:19:05 BST; 19ms ago
Process: 13229 ExecStart=/usr/bin/dockerd -H fd:// --containerd=/run/containerd/containerd.sock (code=exited, status=1/FAILURE)
Main PID: 13229 (code=exited, status=1/FAILURE)
Sep 02 12:19:05 xavier systemd[1]: Failed to start Docker Application Container Engine.
docker-ce
nvidia-docker2
nvidia-container
^C
