Thx… at least I know I’m not completely missing something.
I think this also confirms no need at all for /boot on /dev/nvme0n1p1 when using the chroot method in rootOnNVMe.
Yeah, I think root= might need to be changed, but only because editing the /etc/fstab didn’t work.
I can’t figure out why editing the fstab wouldn’t effectively be the same thing.
I’m just speculating, but I suspect that the boot chain is sufficiently different than that on a PC that the bootloader software reads only from “extlinux.conf” and/or the initrd. In other words, a limitation of the bootloader chain (which is quite different than that of a PC using GRUB).
TIMEOUT 30
DEFAULT primary_nvme
MENU TITLE L4T boot options
LABEL primary_nvme
MENU LABEL primary_nvme kernel
LINUX /boot/Image
INITRD /boot/initrd
APPEND ${cbootargs} quiet root=/dev/nvme0n1p1 rw rootwait rootfstype=ext4
console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4
LABEL bakup_emmc
MENU LABEL bakup_emmc kernel
LINUX /boot/Image
INITRD /boot/initrd
APPEND ${cbootargs} quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4
reboot.
the system will boot from nvme
PS: if something goes wrong, I interrupt the CBoot boot and enter commad “setvar boot-order emmc” to boot AGX from emmc.
enter cmmand “boot”.
the system 1 time will boot from emmc.
Your solution looks just perfect, if that’s the place you do it that’s good info!
Can you only break cboot in a debug console session or can that be done directly?
There are many options (if you have specified boot from available media in extlinux.conf. Just take into account the default check order
This is my CBoot output in the console (for example)
[0002.384] I> 1.sd
[0002.386] I> 2.usb
[0002.388] I> 3.nvme
[0002.390] I> 4.emmc
[0002.392] I> 5.net
[0002.393] I> Hit any key to stop autoboot: 4 3 2 1
[0004.401] initializing target
CBoot selection of extlinux.conf are only accessible for picking (during boot) via serial console. Systems which use the desktop PC architecture use GRUB instead and can pick a menu item directly from the monitor/keyboard, but the boot mechanics using extlinux.conf cannot display to the regular monitor (thus the mandatory requirement for serial console).
