JetPack 4 Reaches End of Life
For the past five years, JetPack 4 has been the driving force behind the success of numerous NVIDIA Jetson based products. Earlier this year, Kernel 4.9 and Ubuntu 18.04 which Jetpack 4 is based on, reached their End of Life. But we continued to roll out regular JetPack 4 updates with security patches and critical bug fixes.
As we look ahead, we are targeting final release of Jetpack 4 in Q1 2024, marking its End of Life. For continued Kernel maintenance on JetPack 4 beyond EOL, we encourage you to leverage the expertise of our ecosystem partners and reach out to TimeSys and Codethink. For products based on Jetson Xavier NX and Jetson AGX Xavier modules, we recommend transitioning to JetPack 5, ensuring seamless continuity of support.
In line with our earlier announcement this year, we’ve been channeling our efforts into integrating Jetson changes into the upstream Linux Kernel. JetPack 6, slated Nov-end 2023, will be based on an upstream kernel 5.15 and will be complemented by a small set of out-of-tree patches. This will empower Jetson developers with the freedom to choose their preferred Kernel version (any version beyond Kernel 5.15) and foster collaborations with diverse Linux distributions, broadening the spectrum of distro choices for the Jetson community.
Bad Jetpack5 nvme writing performance compared with Jetpack4
Nvv4l2decoder artifacts
OTA upgrade on devices that have secure boot and disk encryption
Decoding stops after running "00_video_decode_test" for a long time
V4l2_buffer timestamp starts at 0, not MONOTONIC_RAW
Upgrading ubuntu 18.04 LTS to 20.04 LTS in reComputer J1020v1
Upstream TF-A MMU Issues on Tegra186
Jetson TX2 Jetpack 4.3
Camera external triggering - Let us have it!
Kernel panic when trying to boot from encrypted NVME on TX2 NX without WI-FI module
Has JetPack 5 reached its end of life (EOL), or is there an EOL planned for it?
Nvarguscamerasrc stops recording - possible deadlock
Connection between a Jetson and a high resolution camera
Announcing End of Life for NVIDIA JetPackā„¢ 4 with the release of JetPack 4.6.6
No more remote development in Visual Studio Code
Jetson TX2/TX2-NX: CBoot Stuck in A/B Slot Loop After MB1 Fallback
Camera failing when secure boot enabled
Diferences status Vulkan l4t 32.7.4 vs Android stack implementation
Tx2 camera delay N+2 frame patch for jetpack4.6
Secure boot not verify initrd change
TensorRT-8.2 triggers MMU fault on a specific ONNX model
Re-Opening Jetson Nano Kernel Upgrade
Xavier NX A/B Failover not work
Upstream TF-A fails to boot on Tegra210
