JetPack 4.x
How can I install torchvision-0.9.0-cp36-cp36m-arrch64,I could not find this file on the Internet.
We don’t have such a prebuilt package.
Please build it from the source. You can find the building command in the below link:
I have a problem. After I run “sudo apt-get upgrade”. An error came. I don’t konw how to deal with it.
0 upgraded, 0 newly installed, 0 to remove and 8 not upgraded.
3 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up nvidia-l4t-bootloader (32.7.5-20240611161210) …
3448-300-0002–1–jetson-nano-devkit-
Starting bootloader post-install procedure.
ERROR. Procedure for bootloader update FAILED.
Cannot install package. Exiting…
dpkg: error processing package nvidia-l4t-bootloader (–configure):
installed nvidia-l4t-bootloader package post-installation script subprocess returned error exit status 1
Setting up nvidia-l4t-xusb-firmware (32.7.5-20240611161210) …
Starting xusb firmware post-install procedure.
ERROR. Procedure for xusb firmware update FAILED.
dpkg: error processing package nvidia-l4t-xusb-firmware (–configure):
installed nvidia-l4t-xusb-firmware package post-installation script subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of nvidia-l4t-initrd:
nvidia-l4t-initrd depends on nvidia-l4t-xusb-firmware (= 32.7.5-20240611161210); however:
Package nvidia-l4t-xusb-firmware is not configured yet.
dpkg: error processing package nvidia-l4t-initrd (–configure):
dependency problems - leaving unconfigured
No apport report written because the error message indicates its a followup error from a previous failure.
Errors were encountered while processing:
nvidia-l4t-initrd
E: Sub-process /usr/bin/dpkg returned an error code (1)
