Related to Read Xavier Fan Speed on Jetpack 5.1
Several of the previously available pwm-fan attributes are no longer present, JP 4.6 vs JP 5.1 outputs below.
Have these attributes been depreciated / moved, if so can someone please let me know how to retrieve similar information?
JP 4.6 L4T 34.6.1
test@linux:~$ find /sys/devices -name '*pwm*'
/sys/devices/generic_pwm_tachometer
/sys/devices/pwm-fan
/sys/devices/pwm-fan/target_pwm
/sys/devices/pwm-fan/pwm_cap
/sys/devices/pwm-fan/hwmon/hwmon2/target_pwm
/sys/devices/pwm-fan/hwmon/hwmon2/pwm_cap
/sys/devices/pwm-fan/hwmon/hwmon2/cur_pwm
/sys/devices/pwm-fan/hwmon/hwmon2/pwm_rpm_table
/sys/devices/pwm-fan/hwmon/hwmon2/pwm_state_map
/sys/devices/pwm-fan/cur_pwm
/sys/devices/pwm-fan/pwm_rpm_table
/sys/devices/pwm-fan/pwm_state_map
JP 5.1.2 L4T 35.4.1
test@edgeai-ts1:~$ find /sys/devices -name '*pwm*'
/sys/devices/platform/39c0000.tachometer/pwm
/sys/devices/platform/39c0000.tachometer/pwm/pwmchip5
/sys/devices/platform/39c0000.tachometer/pwm/pwmchip5/npwm
/sys/devices/platform/3280000.pwm
/sys/devices/platform/3280000.pwm/pwm
/sys/devices/platform/3280000.pwm/pwm/pwmchip0
/sys/devices/platform/3280000.pwm/pwm/pwmchip0/npwm
/sys/devices/platform/32d0000.pwm
/sys/devices/platform/32d0000.pwm/pwm
/sys/devices/platform/32d0000.pwm/pwm/pwmchip3
/sys/devices/platform/32d0000.pwm/pwm/pwmchip3/npwm
/sys/devices/platform/32d0000.pwm/consumer:platform:pwm-fan
/sys/devices/platform/c340000.pwm
/sys/devices/platform/c340000.pwm/pwm
/sys/devices/platform/c340000.pwm/pwm/pwmchip1
/sys/devices/platform/c340000.pwm/pwm/pwmchip1/npwm
/sys/devices/platform/32f0000.pwm
/sys/devices/platform/32f0000.pwm/pwm
/sys/devices/platform/32f0000.pwm/pwm/pwmchip4
/sys/devices/platform/32f0000.pwm/pwm/pwmchip4/npwm
/sys/devices/platform/pwm-fan
/sys/devices/platform/pwm-fan/supplier:platform:32d0000.pwm
/sys/devices/platform/pwm-fan/hwmon/hwmon4/pwm1
/sys/devices/platform/32c0000.pwm
/sys/devices/platform/32c0000.pwm/pwm
/sys/devices/platform/32c0000.pwm/pwm/pwmchip2
/sys/devices/platform/32c0000.pwm/pwm/pwmchip2/npwm
/sys/devices/virtual/devlink/platform:32d0000.pwm--platform:pwm-fan
(additional info requested in the ‘related’ ticket)
test@edgeai-ts1:~$ ls -l /sys/class/hwmon/
total 0
lrwxrwxrwx 1 root root 0 Nov 1 12:08 hwmon0 -> ../../devices/virtual/thermal/thermal_zone5/hwmon0
lrwxrwxrwx 1 root root 0 Nov 1 12:08 hwmon1 -> ../../devices/platform/d280000.soctherm-oc-event/hwmon/hwmon1
lrwxrwxrwx 1 root root 0 Nov 1 12:08 hwmon2 -> ../../devices/platform/39c0000.tachometer/hwmon/hwmon2
lrwxrwxrwx 1 root root 0 Nov 1 12:08 hwmon3 -> ../../devices/platform/3520000.xusb_padctl/usb2-0/3520000.xusb_padctl:ports:usb2-0:connector/power_supply/usb-charger/hwmon3
lrwxrwxrwx 1 root root 0 Nov 1 12:08 hwmon4 -> ../../devices/platform/pwm-fan/hwmon/hwmon4
lrwxrwxrwx 1 root root 0 Nov 1 12:08 hwmon5 -> ../../devices/platform/c250000.i2c/i2c-7/7-0040/hwmon/hwmon5
