Jetpack 6.0 to 6.1 Upgrade: 'upgrade-jetpack' vs 'Upgradable Compute Stack'?
Sorry, I am a beginner. I want to ask what the difference is between ‘upgrade-jetpack’ https://docs.nvidia.com/jetson/jetpack/install-setup/index.html#upgrade-jetpackand ‘Upgradable Compute Stack’ https://docs.nvidia.com/jetson/jetpack/install-setup/index.html#upgradable-compute-stack. My current Jetpack version is 6.0, and I want to upgrade to 6.1. Which method should I use? My understanding is that I should use the ‘upgrade-jetpack’ method. Is my understanding correct? And, what is the ‘Upgradable Compute Stack’ used for?
If you use AGX Orin developer kit and would like to upgrade from Jetpack 6.0GA(r36.3) to 6.1(r36.4), please run the commands:
Software Packages and the Update Mechanism — NVIDIA Jetson Linux Developer Guide 1 documentation
Thank you very much, but please forgive my over-checking, I just want to confirm one more time. My device is the Jetson AGX Orin, If I want to upgrade from Jetpack 6.0 GA (r36.3) to 6.1 (r36.4), the steps I should follow are 'Updating to a New Point Release’https://docs.nvidia.com/jetson/archives/r36.4/DeveloperGuide/SD/SoftwarePackagesAndTheUpdateMechanism.html#updating-to-a-new-point-release rather than 'Updating to a New Minor Release’https://docs.nvidia.com/jetson/archives/r36.4/DeveloperGuide/SD/SoftwarePackagesAndTheUpdateMechanism.html#updating-to-a-new-minor-release. Is my understanding correct?
Yes, r36.4 is a new point release. Please note it’s for developer kit.
Yes, My device is the Jetson AGX Orin developer kit. I followed the command of “Updating to a New Point Release”:
sudo apt update
apt list --upgradable
sudo apt upgrade
and then, I rebooted my device.
My question is: How to see whether my deivce update to 36.4 success or not. Before and after updating, I use “cat /etc/nv_tegra_release” command to check the version of the NVIDIA JetPack software, but the output both are the same:
R36 (release), REVISION: 3.0, GCID: 36923193, BOARD: generic, EABI: aarch64, DATE: Fri Jul 19 23:24:25 UTC 2024
KERNEL_VARIANT: oot
TARGET_USERSPACE_LIB_DIR=nvidia
TARGET_USERSPACE_LIB_DIR_PATH=usr/lib/aarch64-linux-gnu/nvidia
The version looked the same. So, is there anything wrong?
My apology that the description in document may be confusing. For upgrading from r36.3 to r36.4, please do
