where is new pytorch version 2.5.1 for jetpack6.1? Download center contains just offers pytorch v2.5.0a0.
Thanks in advance!
Thanks in advance!
Does PyTorch 2.6 work for you?
The latest prebuilt for JetPack 6.1 is 2.6.0rc1:
https://pypi.jetson-ai-lab.dev/jp6/cu126
Unfortunately, v2.6 seems to be incompatible with Numpy, crashing at runtime :(.
Additionally, I see that torchvision and torchaudio seem to be incompatible with it as well.
I have the same question because when using this I found issues with the CuDNN with 2.6.0rc1 so is this actually the correct working version with Jetpack 6.1 and python 3.10?
You will have to build it your self and it does run on jp6.1
You can build all of it natively on the board, no need to CC.
We provide 2.4.0, 2.5.0, and 2.6.0rc1 for the JetPack 6.1 environment.
https://pypi.jetson-ai-lab.dev/jp6/cu126/torch
For other versions, you can build it from the source.
You can find the building command in the below topic:
