Jetpack Software installation fails on Orin NX
I am trying to install Jetson Software using the SDK manager with a VM running Ubuntu 18.04. The error occurs at the Flash Jetson Linux Step when flashing my Orin NX.
See attached the logs during the installation, please let me know what is the problem and how I can solve it.
SDKM_logs_JetPack_5.1.3_Linux_for_Jetson_Orin_NX_modules_2024-03-27_10-23-53.zip (194.2 KB)
It is normal for a VM to fail. During flash the Jetson will disconnect and reconnect. Most VMs will lose the reconnect event. Setting that up is custom to each VM, so you’d have to find a way to correctly pass through USB.
