jdsb
October 18, 2021, 7:28am
1
I want to use 40-headers pins. the steps is
sudo /opt/nvidia/jetson-io/jetson-io.py
Configure Jetson 40pin Header
Configure header pins manually
enter char * in spi1, spi3 or i2s5. Any of them will do
save pin changes
save an reboot to reconfigure pins
reboot
sudo modprobe spidev
Q, There is no spidev1.0 or spidev3.0 . It only have spidev0.0 and spidev2.0. also no i2s
I check extlinux/extlinux.conf, it seems ok.
FDT path is /boot/kernel_tergra194-p3668-all-p3509-0000-user-custom.dtb
dmesg |grep dtb. it is no output.
dmesg |grep dts. print
DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t19x/jakku/kernel-dts/tergra194-p3668-all-p3509-0000.dts
jetPack4.5 have the same problem.
I open jetson-io.py again. It display ok.
hello jdsb,
it’s tegra-spidev according to device tree sources.
could you please try modify the string as spidev for testing?
for example,
spi@3210000{ /* SPI1 in 40 pin conn */
status = "okay";
spi@0 { /* chip select 0 */
compatible = "tegra-spidev";
jdsb
October 18, 2021, 9:15am
4
thank you to reply.
I use dtc tools to check the dts which recomple from dtb.
It display a lot of warnning.
There is something different.
I enable spi1 spi3 i2s.
but
dts only have spi1’s address.
spi1 have not spi@0 and spi@1, so I copy them from spi0.
It does not work.
hello jdsb,
are you able to execute the loopback test for confirmation.
please also refer to Topic 177675 for the NX SPI pin configuration.
thanks
The SPI1 is map to spidev0.x and SPI3 map to spidev2.x
SPI1 is HW name start from 1 and spidev0 is software name start from 0,
So
SPI1 = spi0 = spidev0.x = “spi@3210000”
SPI3 = spi2 = spidev2.x = “spi@3230000”
jdsb
October 20, 2021, 3:52am
7
no,I test spidev0 and spidev2,There are no any signal output.
I upboard the uart debug message.
It tells me
OEM authentication of kernel-dtb header failed
Failed to validate kernel-dtb binary from rootfs
spi1.txt (26.6 KB)
[0014.770] I> rootfs path: /sd/boot/kernel_tegra194-p3668-all-p3509-0000-user-custom.dtb
[0014.806] I> Loading kernel-dtb sig file from rootfs …
[0014.807] I> rootfs path: /sd/boot/kernel_tegra194-p3668-all-p3509-0000-user-custom.dtb.sig
[0014.824] I> ext2_walk:142: ‘kernel_tegra194-p3668-all-p3509-0000-user-custom.dtb.sig’ lookup failed
[0014.824] I> ext4_open_file:666: ‘/boot/kernel_tegra194-p3668-all-p3509-0000-user-custom.dtb.sig’ lookup failed
[0014.825] E> file /sd/boot/kernel_tegra194-p3668-all-p3509-0000-user-custom.dtb.sig open failed!!
[0014.826] W> Failed to load kernel-dtb sig file (err=202113041)
[0014.832] I> Validate kernel-dtb …
[0014.836] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0014.842] E> Stage2Signature validation failed with SHA2!!
[0014.848] C> OEM authentication of kernel-dtb header failed!
[0014.853] W> Failed to validate kernel-dtb binary from rootfs (err=1077936152, fail=1)
[0014.861] W> Security fuse not burned, ignore validation failure
Using jetson-io to enable SPI have verified working without problem.
Please using jetson-io and try the loopback test to confirm it.
Reference to below topic.
Hello
I want to run spi test by connecting spi1 and spi3 of jetson xavier nx board.
Before connecting spi1-spi3, I connected spi1’s MOSI-MISO (spi3’s MOSI-MISO) and tested with the spidev_test.c example to confirm that tx rx works well for both spi1 and spi3.
(Currently jetson xavier nx board has jetpack4.4 version installed.)
Here I have some questions.
How to set the master mode and slave mode when connecting spi1 and spi3? (Should I update pinmux? or
https://www.jetsonhacks.com/2020/0…
jdsb
October 20, 2021, 9:16am
9
Thank you! You are right.
Now header-SPI1(spidev0.0 &0.1) is work ok!
