我现在也是这么做的呀,
That’s what I do now,
我的问题就是如何让一个安装好环境的nvme固态在一个新的未做任何处理的nx模组上使用,让它能够正常运行
My problem is how to make a nvme solid-state module installed in the environment work on a new NX module without any processing, so that it can run normally
我现在也是这么做的呀,
To flash the QSPI only, modify the NX flash xml file to “flash_l4t_t194_qspi_p3668.xml”. You can firstly locate the file you are using for flash emmc, modify the xml file name to what I just said.
If this is rel-32.6, the default bootloader supports to boot from nvme. Nothing else is needed.
thank you very much That’s what I want to ask
但是我没明白具体如何操作“请将 NX 闪存 xml 文件修改为“flash_l4t_t194_qspi_p3668.xml”。你可以先找到你用的flash emmc的文件”
我找到了您说的这个文件(flash_l4t_t194_qspi_p3668.xml),但是我该修改哪个文件,在什么地方修改呢
I found the file you said(flash_l4t_t194_qspi_p3668.xml), but which file should I modify and where
换而言之,我不懂操作的详细步骤
In other words, I don’t understand the detailed steps of the operation
Did you ever use flash.sh tool before?
是的我用过还原和备份emmc
Yes, I used restore and backup EMMC
但是我不知道具体如何修改,修改后如何使用
But I don’t know how to modify it and how to use it after modification
like next picture
jetson-xavier-nx-devkit-emmc here means jetson-xavier-nx-devkit-emmc.conf in your Linux_for_Tegra. Open that file and trace down and you will find where to modify the xml file.
Check what is under your Linux_for_Tegra.
That’s what I did
我就是这么做的
I have a typo in above comment. Correct it back.
Make it more easier to understand. What you use in flash.sh is the file name you need to find.
You said you were dizzy. I don’t know what to do, If you’d like to ask, can you give me a screenshot or an attachment
您给我说晕了,我不知道应该怎么做了,冒昧的问一下能给我截个图么,或者带个附件也行
There is a string behind flash.sh as an input. Those input represent the board config file name.
For example, flash.sh jetson-xavier-nx-devkit-emmc mmcblk0p1 represents jetson-xavier-nx-devkit-emmc.conf. This config file has the xml file you need to modify.
For Mandarin user:
flash.sh 後面有一串字串代表板子的名字
那些東西就是你的board config name. 比方說 flash.sh jetson-xavier-nx-devkit-emmc mmcblk0p1 就是代表用jetson-xavier-nx-devkit-emmc.conf這個檔案
如果我寫了一個12345.conf 那麼flash.sh也可以燒 flash.sh 12345 mmlkcb0p1.
你要改的xml就在這些board config裡面
明白了一部分,但是还是没有完全明白,应该是用这个参数吧(jetson-xavier-nx-devkit-qspi)
I understand part of it, but I still don’t fully understand it,This parameter should be added(jetson-xavier-nx-devkit-qspi)
sudo ./flash.sh jetson-xavier-nx-devkit-qspi mmcblk0p1 yes or no?
yes. You can use that to flash QSPI only.
I didn’t notice this file existed.
Thank you. A small problem that bothered me for two weeks has finally been solved
