自动升级的问题,目前刷机后 L4T package 会自动升级到6.2,这个问题应该怎么解决? 只是改source源但无法满足我下载JetPack 6.1 software的需求,正是因为会自动升级到6.2,所以导致无法下载6.1,在指定6.1版本时会出现冲突,如
我认为这个问题很好复现,请您有时间使用Devkit Orin和JetPack6.1 L4T,然后下载6.1版本的jetpack software 谢谢
mogo@mos:~$ sudo apt install nvidia-jetpack
command: apt install nvidia-jetpack
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
The following additional packages will be installed:
cuda-cccl-12-6 cuda-command-line-tools-12-6 cuda-compiler-12-6 cuda-crt-12-6 cuda-cudart-12-6 cuda-cudart-dev-12-6 cuda-cuobjdump-12-6
cuda-cupti-12-6 cuda-cupti-dev-12-6 cuda-cuxxfilt-12-6 cuda-documentation-12-6 cuda-driver-dev-12-6 cuda-gdb-12-6 cuda-libraries-12-6
cuda-libraries-dev-12-6 cuda-nsight-compute-12-6 cuda-nvcc-12-6 cuda-nvdisasm-12-6 cuda-nvml-dev-12-6 cuda-nvprune-12-6 cuda-nvrtc-12-6
cuda-nvrtc-dev-12-6 cuda-nvtx-12-6 cuda-nvvm-12-6 cuda-profiler-api-12-6 cuda-runtime-12-6 cuda-sanitizer-12-6 cuda-toolkit-12-6
cuda-toolkit-12-6-config-common cuda-toolkit-12-config-common cuda-toolkit-config-common cuda-tools-12-6 cuda-visual-tools-12-6 gds-tools-12-6
libcublas-12-6 libcublas-dev-12-6 libcudla-12-6 libcudla-dev-12-6 libcudnn9-cuda-12 libcudnn9-dev-cuda-12 libcudnn9-samples libcufft-12-6
libcufft-dev-12-6 libcufile-12-6 libcufile-dev-12-6 libcurand-12-6 libcurand-dev-12-6 libcusolver-12-6 libcusolver-dev-12-6 libcusparse-12-6
libcusparse-dev-12-6 libnpp-12-6 libnpp-dev-12-6 libnvfatbin-12-6 libnvfatbin-dev-12-6 libnvidia-container-tools libnvidia-container1
libnvinfer-bin libnvinfer-dev libnvinfer-dispatch-dev libnvinfer-dispatch10 libnvinfer-headers-dev libnvinfer-headers-plugin-dev
libnvinfer-lean-dev libnvinfer-lean10 libnvinfer-plugin-dev libnvinfer-plugin10 libnvinfer-samples libnvinfer-vc-plugin-dev
libnvinfer-vc-plugin10 libnvinfer10 libnvjitlink-12-6 libnvjitlink-dev-12-6 libnvonnxparsers-dev libnvonnxparsers10 libnvvpi3 libopencv
libopencv-dev libopencv-python libopencv-samples libtbb12 libtbbmalloc2 libxcb-cursor0 libxcb-icccm4-dev libxcb-xinerama0 libxcb-xinput0
nsight-compute-2024.3.1 nsight-graphics-for-embeddedlinux-2024.2.0.0 nsight-systems-2024.5.4 nvidia-container nvidia-container-toolkit
nvidia-container-toolkit-base nvidia-cuda nvidia-cuda-dev nvidia-cudnn nvidia-cudnn-dev nvidia-cupva nvidia-jetpack-dev nvidia-jetpack-runtime
nvidia-l4t-cudadebuggingsupport nvidia-l4t-dla-compiler nvidia-l4t-gstreamer nvidia-l4t-jetson-multimedia-api nvidia-nsight-graphics
nvidia-nsight-systems nvidia-opencv nvidia-opencv-dev nvidia-tensorrt nvidia-tensorrt-dev nvidia-vpi nvidia-vpi-dev opencv-licenses
opencv-samples-data pva-allow-2 pva-sdk-2.5-l4t python3-libnvinfer python3-libnvinfer-dev python3-libnvinfer-dispatch python3-libnvinfer-lean
python3.10-vpi3 tensorrt tensorrt-libs vpi3-dev vpi3-python-src vpi3-samples
The following NEW packages will be installed:
nvidia-container-toolkit-base nvidia-cuda nvidia-cuda-dev nvidia-cudnn nvidia-cudnn-dev nvidia-cupva nvidia-jetpack nvidia-jetpack-dev
nvidia-jetpack-runtime nvidia-l4t-cudadebuggingsupport nvidia-l4t-dla-compiler nvidia-l4t-gstreamer nvidia-l4t-jetson-multimedia-api
nvidia-nsight-graphics nvidia-nsight-systems nvidia-opencv nvidia-opencv-dev nvidia-tensorrt nvidia-tensorrt-dev nvidia-vpi nvidia-vpi-dev
opencv-licenses opencv-samples-data pva-allow-2 pva-sdk-2.5-l4t python3-libnvinfer python3-libnvinfer-dev python3-libnvinfer-dispatch
python3-libnvinfer-lean python3.10-vpi3 tensorrt tensorrt-libs vpi3-dev vpi3-python-src vpi3-samples
0 upgraded, 126 newly installed, 0 to remove and 247 not upgraded.
Need to get 1,574 MB/3,786 MB of archives.
After this operation, 9,057 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 https://repo.download.nvidia.com/jetson/common r36.4/main arm64 gds-tools-12-6 arm64 1.11.1.6-1 [39.0 MB]
Get:2 https://repo.download.nvidia.com/jetson/common r36.4/main arm64 cuda-tools-12-6 arm64 12.6.11-1 [2,466 B]
Get:3 https://repo.download.nvidia.com/jetson/common r36.4/main arm64 cuda-documentation-12-6 arm64 12.6.68-1 [50.0 kB]
Get:4 https://repo.download.nvidia.com/jetson/common r36.4/main arm64 cuda-toolkit-12-6 arm64 12.6.11-1 [3,196 B]
Get:5 https://repo.download.nvidia.com/jetson/common r36.4/main arm64 nvidia-cuda-dev arm64 6.2+b77 [27.9 kB]
Get:6 https://repo.download.nvidia.com/jetson/common r36.4/main arm64 libcudnn9-cuda-12 arm64 9.3.0.75-1 [405 MB]
Get:7 https://repo.download.nvidia.cn/jetson/common r36.4/main arm64 nvidia-cudnn arm64 6.2+b77 [27.4 kB]
Get:8 https://repo.download.nvidia.cn/jetson/common r36.4/main arm64 libcudnn9-samples all 9.3.0.75-1 [1,672 kB]
Get:9 https://repo.download.nvidia.cn/jetson/common r36.4/main arm64 libcudnn9-dev-cuda-12 arm64 9.3.0.75-1 [34.1 kB]
Get:10 https://repo.download.nvidia.cn/jetson/common r36.4/main arm64 nvidia-cudnn-dev arm64 6.2+b77 [27.4 kB]
Get:11 https://repo.download.nvidia.cn/jetson/common r36.4/main arm64 pva-allow-2 all 2.0.5 [15.4 kB]
Get:12 https://repo.download.nvidia.cn/jetson/common r36.4/main arm64 pva-sdk-2.5-l4t arm64 2.5.4 [251 kB]
Get:13 https://repo.download.nvidia.cn/jetson/common r36.4/main arm64 nvidia-cupva arm64 6.2+b77 [29.3 kB]
Get:14 https://repo.download.nvidia.cn/jetson/common r36.4/main arm64 nvidia-l4t-jetson-multimedia-api arm64 36.4.3-20250107174145 [75.4 MB]
Get:15 https://repo.download.nvidia.cn/jetson/common r36.4/main arm64 nvidia-l4t-dla-compiler arm64 36.4.3-20250107174145 [2,791 kB]
Get:16 https://repo.download.nvidia.cn/jetson/common r36.4/main arm64 nvidia-l4t-gstreamer arm64 36.4.3-20250107174145 [1,413 kB]
Get:17 https://repo.download.nvidia.cn/jetson/common r36.4/main arm64 libnvinfer10 arm64 10.3.0.30-1+cuda12.5 [101 MB]
Get:18 https://repo.download.nvidia.cn/jetson/common r36.4/main arm64 libnvinfer-lean10 arm64 10.3.0.30-1+cuda12.5 [5,885 kB]
Get:19 https://repo.download.nvidia.cn/jetson/common r36.4/main arm64 libnvinfer-plugin10 arm64 10.3.0.30-1+cuda12.5 [4,951 kB]
Get:20 https://repo.download.nvidia.cn/jetson/common r36.4/main arm64 libnvinfer-vc-plugin10 arm64 10.3.0.30-1+cuda12.5 [212 kB]
Get:21 https://repo.download.nvidia.cn/jetson/common r36.4/main arm64 libnvinfer-dispatch10 arm64 10.3.0.30-1+cuda12.5 [216 kB]
Get:22 https://repo.download.nvidia.cn/jetson/common r36.4/main arm64 libnvonnxparsers10 arm64 10.3.0.30-1+cuda12.5 [815 kB]
Get:23 https://repo.download.nvidia.cn/jetson/common r36.4/main arm64 tensorrt-libs arm64 10.3.0.30-1+cuda12.5 [2,930 B]
Get:24 https://repo.download.nvidia.cn/jetson/common r36.4/main arm64 nvidia-tensorrt arm64 6.2+b77 [27.3 kB]
Get:25 https://repo.download.nvidia.cn/jetson/common r36.4/main arm64 libopencv arm64 4.8.0-1-g6371ee1 [12.6 MB]
Get:26 https://repo.download.nvidia.cn/jetson/common r36.4/main arm64 nvidia-opencv arm64 6.2+b77 [29.3 kB]
Get:27 https://repo.download.nvidia.cn/jetson/common r36.4/main arm64 libnvvpi3 arm64 3.2.4 [33.8 MB]
Get:28 https://repo.download.nvidia.cn/jetson/common r36.4/main arm64 python3.10-vpi3 arm64 3.2.4 [753 kB]
Get:29 https://repo.download.nvidia.cn/jetson/common r36.4/main arm64 nvidia-vpi arm64 6.2+b77 [29.3 kB]
Get:30 https://repo.download.nvidia.cn/jetson/common r36.4/main arm64 nvidia-jetpack-runtime arm64 6.2+b77 [29.4 kB]
Get:31 https://repo.download.nvidia.cn/jetson/common r36.4/main arm64 vpi3-dev arm64 3.2.4 [91.3 kB]
Get:32 https://repo.download.nvidia.cn/jetson/common r36.4/main arm64 vpi3-samples arm64 3.2.4 [17.2 MB]
Get:33 https://repo.download.nvidia.cn/jetson/common r36.4/main arm64 vpi3-python-src arm64 3.2.4 [706 kB]
Get:34 https://repo.download.nvidia.cn/jetson/common r36.4/main arm64 nvidia-vpi-dev arm64 6.2+b77 [29.3 kB]
Get:35 https://repo.download.nvidia.cn/jetson/common r36.4/main arm64 libnvinfer-bin arm64 10.3.0.30-1+cuda12.5 [415 kB]
Get:36 https://repo.download.nvidia.cn/jetson/common r36.4/main arm64 libnvinfer-headers-dev arm64 10.3.0.30-1+cuda12.5 [108 kB]
Get:37 https://repo.download.nvidia.cn/jetson/common r36.4/main arm64 libnvinfer-dev arm64 10.3.0.30-1+cuda12.5 [112 MB]
Get:38 https://repo.download.nvidia.cn/jetson/common r36.4/main arm64 libnvinfer-lean-dev arm64 10.3.0.30-1+cuda12.5 [16.9 MB]
Get:39 https://repo.download.nvidia.cn/jetson/common r36.4/main arm64 libnvinfer-headers-plugin-dev arm64 10.3.0.30-1+cuda12.5 [6,056 B]
Get:40 https://repo.download.nvidia.cn/jetson/common r36.4/main arm64 libnvinfer-plugin-dev arm64 10.3.0.30-1+cuda12.5 [5,129 kB]
Get:41 https://repo.download.nvidia.cn/jetson/common r36.4/main arm64 libnvinfer-dispatch-dev arm64 10.3.0.30-1+cuda12.5 [114 kB]
Get:42 https://repo.download.nvidia.cn/jetson/common r36.4/main arm64 libnvinfer-vc-plugin-dev arm64 10.3.0.30-1+cuda12.5 [77.7 kB]
Get:43 https://repo.download.nvidia.cn/jetson/common r36.4/main arm64 libnvonnxparsers-dev arm64 10.3.0.30-1+cuda12.5 [1,849 kB]
Get:44 https://repo.download.nvidia.cn/jetson/common r36.4/main arm64 libnvinfer-samples all 10.3.0.30-1+cuda12.5 [187 MB]
82% [44 libnvinfer-samples 4,341 kB/187 MB 2%]
这里很显然是在下载6.2的software
请问有进展吗?
確實會抓到 36.4.3 我們正在內部討論。
如果有updated 會再通知您
謝謝
hi,
非常感谢,请问一下,Orin 32GB 大概什么时候出JetPack6.2呢
有JP6.2 請參考
这个topic上只有说Jetson Orin Nano and Jetson Orin NX modules.
Orin 32GB&64GB 也可以用吗?
是不是我理解着Orin 32GB可以用JetPack6.2,而只有Nano和NX可以用新出的supper模式吗?
Hi
對 是的
謝謝
Orin 32GB 以后会有supper模式吗?
目前暫無規劃
謝謝
好的,thanks
