Hi NV_Team,
When we upgrade to JetPack6.2 super mode for Orin NX/Nano.
nvidia@nvidia-desktop:~$ cat /boot/extlinux/extlinux.conf
TIMEOUT 30
DEFAULT primary
MENU TITLE L4T boot options
LABEL primary
MENU LABEL primary kernel
LINUX /boot/Image
INITRD /boot/initrd
APPEND ${cbootargs} root=PARTUUID=a19afc82-0bae-49f1-b900-b5840bf3af96 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 firmware_class.path=/etc/firmware fbcon=map:0 nospectre_bhb video=efifb:off console=tty0
Can’t use config-by-hardware.py to configure dtbo and 40Pin
sudo /opt/nvidia/jetson-io/jetson-io.py (Failed)
But we can set dtbo by manually modify extlinux.conf
Hi Luna2020,
Are you using the devkit or custom board for Orin NX/Nano?
How did you upgrade to JP6.2?
Is there any error when you run jetson-io.py?
Hi KevinFFF,
We are using devkit for Orin Nano 8GB
Whole flash JetPack6.2 on my devkit with SDKManager.
Nothing appear after run jetson-io.py, but JP6.1 jetson-io.py works fine.
Do you have SD or NVMe connected on your board?
Please share the result of following commands for further check.
$ cat /etc/nv_tegra_release
$ cat /etc/nv_boot_control.conf
$ lsblk
$ df -h
Hi KevinFFF,
Please refer the following info.
nvidia@nvidia-desktop:~$ cat /etc/nv_tegra_release
# R36 (release), REVISION: 4.3, GCID: 38968081, BOARD: generic, EABI: aarch64, DATE: Wed Jan 8 01:49:37 UTC 2025
# KERNEL_VARIANT: oot
TARGET_USERSPACE_LIB_DIR=nvidia
TARGET_USERSPACE_LIB_DIR_PATH=usr/lib/aarch64-linux-gnu/nvidia
nvidia@nvidia-desktop:~$ cat /etc/nv_boot_control.conf
TNSPEC 3767-300-0003-R.1-1-1-jetson-orin-nano-devkit-super-
COMPATIBLE_SPEC 3767--0003--1--jetson-orin-nano-devkit-super-
TEGRA_BOOT_STORAGE nvme0n1
TEGRA_CHIPID 0x23
TEGRA_OTA_BOOT_DEVICE /dev/mtdblock0
TEGRA_OTA_GPT_DEVICE /dev/mtdblock0
nvidia@nvidia-desktop:~$ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
loop0 7:0 0 16M 1 loop
zram0 252:0 0 635M 0 disk [SWAP]
zram1 252:1 0 635M 0 disk [SWAP]
zram2 252:2 0 635M 0 disk [SWAP]
zram3 252:3 0 635M 0 disk [SWAP]
zram4 252:4 0 635M 0 disk [SWAP]
zram5 252:5 0 635M 0 disk [SWAP]
nvme0n1 259:0 0 232.9G 0 disk
├─nvme0n1p1 259:1 0 231.4G 0 part /
├─nvme0n1p2 259:2 0 128M 0 part
├─nvme0n1p3 259:3 0 768K 0 part
├─nvme0n1p4 259:4 0 31.6M 0 part
├─nvme0n1p5 259:5 0 128M 0 part
├─nvme0n1p6 259:6 0 768K 0 part
├─nvme0n1p7 259:7 0 31.6M 0 part
├─nvme0n1p8 259:8 0 80M 0 part
├─nvme0n1p9 259:9 0 512K 0 part
├─nvme0n1p10 259:10 0 64M 0 part /boot/efi
├─nvme0n1p11 259:11 0 80M 0 part
├─nvme0n1p12 259:12 0 512K 0 part
├─nvme0n1p13 259:13 0 64M 0 part
├─nvme0n1p14 259:14 0 400M 0 part
└─nvme0n1p15 259:15 0 479.5M 0 part
nvidia@nvidia-desktop:~$ df -h
Filesystem Size Used Avail Use% Mounted on
/dev/nvme0n1p1 227G 20G 196G 10% /
tmpfs 3.8G 172K 3.8G 1% /dev/shm
tmpfs 1.5G 27M 1.5G 2% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
/dev/nvme0n1p10 63M 110K 63M 1% /boot/efi
tmpfs 762M 108K 762M 1% /run/user/1000
Thanks for sharing the info.
It seems you have only NVMe SSD connected.
Have you also tried using the following command to flash the devkit?
$ sudo ADDITIONAL_DTB_OVERLAY_OPT="BootOrderNvme.dtbo" ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_t234_nvme.xml -p "-c bootloader/generic/cfg/flash_t234_qspi.xml" --showlogs --network usb0 jetson-orin-nano-devkit-super internal
system
Closed
9
