我想在设备树中关闭 ethernet@6800000节点,为何不能生效?
我可以确认,我修改的地方是对的,并且替换设备树也是正确的,因为我看到了增加的其他节点,但是始终无法关闭这个节点,比如我增加了test节点,都可以看到我设定的值为aaa,即便如此,status依然是okay,无法关闭掉
What is the device tree content when you convert your final dtb back to dts byusing dtc tool?
sudo dtc -I fs -O dts -o extracted_proc.dts /proc/device-tree
I tried using the above command, and found that the decompiled dts was in the same situation.
I want to disable this node, but the only way to do it is by closing this file. However, this seems illogical.
<Linux_for_Tegra\source\hardware\nvidia\t23x\nv-public\nv-platform\tegra234-p3737-0000+p3701-xxxx-nv-common.dtsi>
please check dtc tool result on your host PC right after you compile out a new dtb instead of reading runtime device tree from /proc/device-tree.
