I’ve followed the instructions on GitHub - NVIDIA-AI-IOT/jetracer: An autonomous AI racecar using NVIDIA Jetson Nano and successfully run the training as well as roadfollowing with default resnet18. I noticed that there are some more models to choose. For some need, I’d like to try other models that take less system memory. As far as I know, Alexnet and squeezenet are lighter than resnet18. However, when I run training with these models, system will be out of memory and crashed. What’s the problem?Did I miss some settings?
Here are parts of the code about training.
import torch
import torchvision
device = torch.device('cuda')
output_dim = 2 * len(dataset.categories) # x, y coordinate for each category
# ALEXNET
# model = torchvision.models.alexnet(pretrained=True)
# model.classifier[-1] = torch.nn.Linear(4096, output_dim)
# SQUEEZENET
# model = torchvision.models.squeezenet1_1(pretrained=True)
# model.classifier[1] = torch.nn.Conv2d(512, output_dim, kernel_size=1)
# model.num_classes = len(dataset.categories)
# RESNET 18
model = torchvision.models.resnet18(pretrained=True)
model.fc = torch.nn.Linear(512, output_dim)
# RESNET 34
# model = torchvision.models.resnet34(pretrained=True)
# model.fc = torch.nn.Linear(512, output_dim)
# DENSENET 121
# model = torchvision.models.densenet121(pretrained=True)
# model.classifier = torch.nn.Linear(model.num_features, output_dim)
model = model.to(device)
model_save_button = ipywidgets.Button(description='save model')
model_load_button = ipywidgets.Button(description='load model')
model_path_widget = ipywidgets.Text(description='model path', value='road_following_model.pth')
def load_model(c):
model.load_state_dict(torch.load(model_path_widget.value))
model_load_button.on_click(load_model)
def save_model(c):
torch.save(model.state_dict(), model_path_widget.value)
model_save_button.on_click(save_model)
model_widget = ipywidgets.VBox([
model_path_widget,
ipywidgets.HBox([model_load_button, model_save_button])
display(model_widget)
BATCH_SIZE = 8
optimizer = torch.optim.Adam(model.parameters())
# optimizer = torch.optim.SGD(model.parameters(), lr=1e-3, momentum=0.9)
epochs_widget = ipywidgets.IntText(description='epochs', value=1)
eval_button = ipywidgets.Button(description='evaluate')
train_button = ipywidgets.Button(description='train')
loss_widget = ipywidgets.FloatText(description='loss')
progress_widget = ipywidgets.FloatProgress(min=0.0, max=1.0, description='progress')
def train_eval(is_training):
global BATCH_SIZE, LEARNING_RATE, MOMENTUM, model, dataset, optimizer, eval_button, train_button, accuracy_widget, loss_widget, progress_widget, state_widget
try:
train_loader = torch.utils.data.DataLoader(
dataset,
batch_size=BATCH_SIZE,
shuffle=True
state_widget.value = 'stop'
train_button.disabled = True
eval_button.disabled = True
time.sleep(1)
if is_training:
model = model.train()
else:
model = model.eval()
while epochs_widget.value > 0:
i = 0
sum_loss = 0.0
error_count = 0.0
for images, category_idx, xy in iter(train_loader):
# send data to device
images = images.to(device)
xy = xy.to(device)
if is_training:
# zero gradients of parameters
optimizer.zero_grad()
# execute model to get outputs
outputs = model(images)
# compute MSE loss over x, y coordinates for associated categories
loss = 0.0
for batch_idx, cat_idx in enumerate(list(category_idx.flatten())):
loss += torch.mean((outputs[batch_idx][2 * cat_idx:2 * cat_idx+2] - xy[batch_idx])**2)
loss /= len(category_idx)
if is_training:
# run backpropogation to accumulate gradients
loss.backward()
# step optimizer to adjust parameters
optimizer.step()
# increment progress
count = len(category_idx.flatten())
i += count
sum_loss += float(loss)
progress_widget.value = i / len(dataset)
loss_widget.value = sum_loss / i
if is_training:
epochs_widget.value = epochs_widget.value - 1
else:
break
except e:
pass
train_button.disabled = False
eval_button.disabled = False
state_widget.value = 'live'
train_button.on_click(lambda c: train_eval(is_training=True))
eval_button.on_click(lambda c: train_eval(is_training=False))
train_eval_widget = ipywidgets.VBox([
epochs_widget,
progress_widget,
loss_widget,
ipywidgets.HBox([train_button, eval_button])
display(train_eval_widget)
Hope for replies, thanks.
