When I run the Collision Avoidance - Train Model (ResNet18) the Jetson Nano screen freezes. It’s at the last part of the code (blue highlighted section):
Any help would be appreciated, thanks!
Could you monitor the system with tegrastats in another console as well?
Usually, screen freeze is caused by running out of memory or high GPU utilization.
$ sudo tegrastats
I’m closing this topic due to there is no update from you for a period, assuming this issue was resolved.
If still need the support, please open a new topic. Thanks
Could you lower the batch_size value to see if it helps?
