Jetson agx orin 64gb module clone image fail
I am using the Jetson AGX orin devkit carrier board and the Jetson AGX orin 64GB module,
because I want to use a custom carrier board in the future, so I am using the jetson agx orin devkit carrier board now for testing.
Jetpack version:
cat /etc/nv_tegra_release
# R35 (release), REVISION: 3.1, GCID: 32827747, BOARD: t186ref, EABI: aarch64, DATE: Sun Mar 19 15:19:21 UTC 2023
I use the command to flash the image successfully.
command:
sudo BOARDID=3701 FAB=500 BOARDSKU=0050 BOARDREV=J.0 ./flash.sh jetson-agx-orin-devkit mmcblk0p1
I already update, upgrade and install jetpack, v4l2, etc…
I use the first command to clone the image fail, because dtb not exist.
command:
sudo BOARDID=3701 FAB=500 BOARDSKU=0050 BOARDREV=J.0 ./flash.sh -r -k APP -G backup.img jetson-agx-orin-devkit mmcblk0p1
I use the second command to clone the image also fail.
command:
sudo BOARDID=3701 FAB=500 BOARDSKU=0000 BOARDREV=J.0 ./flash.sh -r -k APP -G backup.img jetson-agx-orin-devkit mmcblk0p1
log:
[0049.632] I> MB1 (version: 0.32.0.0-t234-54845784-57325615)
[0049.637] I> t234-A01-0-Silicon (0x12347) Prod
[0049.642] I> Boot-mode : Coldboot
[0049.645] I> Emulation:
[0049.647] I> Entry timestamp: 0x00000000
[0049.651] I> last_boot_error: 0x0
[0049.654] I> BR-BCT: preprod_dev_sign: 0
[0049.658] I> rst_source: 0x0, rst_level: 0x0
[0049.662] I> Task: Bootchain select WAR set (0x5000ba65)
[0049.667] I> Task: Enable SLCG (0x5000bab1)
[0049.671] I> Task: CRC check (0x5001ea19)
[0049.675] I> Skip FUSE records CRC check as records_integrity fuse is not burned
[0049.682] I> Task: Initialize MB2 params (0x5000cb51)
[0049.688] I> MB2-params @ 0x40060000
[0049.691] I> Task: Crypto init (0x5001d981)
[0049.695] I> Task: Secure debug controls (0x5000c0a9)
[0049.700] I> Task: strap war set (0x5000ba2d)
[0049.704] I> Task: Initialize SOC Therm (0x5001bd35)
[0049.709] I> Task: Program NV master stream id (0x5000c05d)
[0049.715] I> Task: Verify boot mode (0xd4820f1)
[0049.720] I> Task: Alias fuses (0x5001095d)
[0049.725] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0049.732] I> Task: Print SKU type (0x5000f5f1)
[0049.736] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x00000000
[0049.741] I> FUSE_OPT_GPC_DISABLE = 0x00000000
[0049.745] I> FUSE_OPT_TPC_DISABLE = 0x00000000
[0049.750] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0049.754] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0049.758] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0049.763] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0049.767] I> FUSE_OPT_FSI_DISABLE = 0x00000000
[0049.771] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0049.776] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0049.780] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0049.784] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0049.788] I> FUSE_SKU_INFO_0 = 0xd0
[0049.791] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0049.795] I> FUSE_PACKAGE_INFO_0 = 0x2
[0049.799] I> SKU: Prod
[0049.801] I> Task: Boost clocks (0x500148a1)
[0049.805] I> Initializing PLLC2 for AXI_CBB.
[0049.810] I> AXI_CBB : src = 35, divisor = 0
[0049.814] I> Task: Voltage monitor (0x50014b49)
[0049.818] I> VMON: Vmon re-calibration and fine tuning done
[0049.824] I> Task: UPHY init (0x5000d065)
[0049.830] I> HSIO UPHY init done
[0049.833] E> Skipping GBE UPHY config
[0049.836] I> Task: Boot device init (0x50000be9)
[0049.841] I> Boot_device: RCM
[0049.844] I> USB configuration success
[0052.774] I> Task: TSC init (0x50020a4d)
[0052.778] I> Task: Load membct (0x50011fe9)
[0052.782] I> RAM_CODE 0x4000031
[0052.785] I> Loading MEMBCT
[0052.788] I> Slot: 0
[0052.790] I> Binary[0] block-0 (partition size: 0x40000)
[0052.795] I>  get_binary_info: Binary name: MEM-BCT-0
[0052.800] I> Size of crypto header is 8192
[0052.804] I> BCH load address is : 0x40050000
[0052.808] I> Size of crypto header is 8192
[0052.818] I> BCH of MEM-BCT-0 read from storage
[0052.823] I> BCH address is : 0x40050000
[0052.827] I> MEM-BCT-0 header integrity check is success
[0052.832] I> Binary magic in BCH component 0 is MEM0
[0052.837] I> component binary type is 0
[0052.842] I> MEM-BCT-0 binary is read from storage
[0052.847] I> MEM-BCT-0 binary integrity check is success
[0052.853] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0052.859] I> RAM_CODE 0x4000031
[0052.864] I> RAM_CODE 0x4000031
[0052.868] I> Task: Load Page retirement list (0x500115b1)
[0052.874] I> Task: SDRAM params override (0x50011fc5)
[0052.879] I> Task: Save mem-bct info (0x50014fa1)
[0052.883] I> Task: Carveout allocate (0x50015005)
[0052.888] I> ECC region[0]: Start:0x0, End:0x0
[0052.892] I> ECC region[1]: Start:0x0, End:0x0
[0052.896] I> ECC region[2]: Start:0x0, End:0x0
[0052.901] I> ECC region[3]: Start:0x0, End:0x0
[0052.905] I> ECC region[4]: Start:0x0, End:0x0
[0052.909] I> Non-ECC region[0]: Start:0x80000000, End:0x80000000
[0052.915] I> Non-ECC region[1]: Start:0x0, End:0x0
[0052.920] I> Non-ECC region[2]: Start:0x0, End:0x0
[0052.924] I> Non-ECC region[3]: Start:0x0, End:0x0
[0052.929] I> Non-ECC region[4]: Start:0x0, End:0x0
[0052.939] E> BL_CARVEOUT: Failed to allocate memory of size 0x36800000 for CO:44.
[0052.946] C> Task 0x0 failed (err: 0x49490003)
[0052.950] E> Top caller module: BL_CARVEOUT, error module: BL_CARVEOUT, reason: 0x03, aux_info: 0x00
[0052.959] C> Boot Info Table status dump :
1
[0052.963] I> Busy Spin
How can I solve this problem?
Why are you doing like this? I don’t believe this command is able to flash any devices.
BOARDSKU should be 0005 for AGX Orin 64GB; we don’t have any module that is 0050.
Normally, you don’t need all these BOARDID stuff.
Please remove them and try again.
