Jetson agx orin devkit clone fails
I want to get a clone of the target to create a cross compile environment, but it doesn’t work
sudo ./flash.sh -r -k APP -G clone_orin.img jetson-agx-orin-devkit mmcblk0p1
I get the following results
Copying nv_boot_control.conf to rootfs
Skip generating system.img
Existing tbcfile(/home/myuser/nvidia/nvidia_sdk/JetPack_5.0.1_DP_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/uefi_jetson.bin) reused.
Skip generating EFI system partition image.
EFI system partition image (esp.img) not found.
What should I do to solve this problem?
Your command is likely correct, but it is a developer preview. The full release should come out in a day or so (no guarantee that will do what you want, but it might be worth waiting a day or 2).
Thank you for your reply.
i will wait for the full release.
The JetPack 5.0.2 GA release has been published, please get it a try. Thanks
