We have connected the RGMII Ethernet port on the carrier board we designed for the Jetson AGX Orin to the KSZ9477 switch integrated circuit, which is controlled via FPGA, using RGMII. When we configure the Pinmux and GPIO settings according to the “.dtsi” file below, we can observe the Link status. When we toggle “link up” and “link down,” we can see that the connection through the switch on the FPGA side is being established and lost.
However, when we send a ping request from our personal computer, we do not receive a response from Orin. Yet, when we run the arp -n command on Orin, we can see the computer’s IP and MAC address. On the other hand, when we initiate a ping request from Orin and then check the arp -n command on the computer, we can see Orin’s IP address but not its MAC address.
What could be the reason for this?
Here is the device-tree files and debug outputs:
tegra234-ethernet-3737-0000.dtsi
#include <dt-bindings/gpio/tegra234-gpio.h>
/* RGMII - A */
ethernet@2310000 {
status = "okay";
phy-mode = "rgmii";
nvidia,mac-addr-idx = <0>;
nvidia,pause_frames = <0>;
phy-mode = "rgmii";
fixed-link {
speed = <1000>;
full-duplex;
tegra234-mb1-bct-pinmux-p3701-0000-a04.dtsi
/dts-v1/;
#include "pinctrl-tegra.h"
#include "tegra234-mb1-bct-gpio-p3701-0000-a04.dtsi"
pinmux@2430000 {
pinctrl-names = "default", "drive", "unused";
pinctrl-0 = <&pinmux_default>;
pinctrl-1 = <&drive_default>;
pinctrl-2 = <&pinmux_unused_lowpower>;
pinmux_default: common {
/* SFIO Pin Configuration */
shutdown_n {
nvidia,pins = "shutdown_n";
nvidia,function = "shutdown";
nvidia,pull = <TEGRA_PIN_PULL_NONE>;
nvidia,tristate = <TEGRA_PIN_DISABLE>;
nvidia,enable-input = <TEGRA_PIN_DISABLE>;
nvidia,io-high-voltage = <TEGRA_PIN_DISABLE>;
nvidia,lpdr = <TEGRA_PIN_DISABLE>;
batt_oc_pee3 {
nvidia,pins = "batt_oc_pee3";
nvidia,function = "soc";
nvidia,tristate = <TEGRA_PIN_ENABLE>;
nvidia,enable-input = <TEGRA_PIN_ENABLE>;
hdmi_cec_pgg0 {
nvidia,pins = "hdmi_cec_pgg0";
nvidia,function = "hdmi";
nvidia,io-high-voltage = <TEGRA_PIN_ENABLE>;
touch_clk_pcc4 {
nvidia,pins = "touch_clk_pcc4";
nvidia,function = "gp";
uart3_tx_pcc5 {
nvidia,pins = "uart3_tx_pcc5";
nvidia,function = "uartc";
uart3_rx_pcc6 {
nvidia,pins = "uart3_rx_pcc6";
gen2_i2c_scl_pcc7 {
nvidia,pins = "gen2_i2c_scl_pcc7";
nvidia,function = "i2c2";
gen2_i2c_sda_pdd0 {
nvidia,pins = "gen2_i2c_sda_pdd0";
gen8_i2c_scl_pdd1 {
nvidia,pins = "gen8_i2c_scl_pdd1";
nvidia,function = "i2c8";
gen8_i2c_sda_pdd2 {
nvidia,pins = "gen8_i2c_sda_pdd2";
can0_stb_paa4 {
nvidia,pins = "can0_stb_paa4";
nvidia,function = "tsc_edge_out2";
nvidia,pull = <TEGRA_PIN_PULL_DOWN>;
can0_err_paa7 {
nvidia,pins = "can0_err_paa7";
nvidia,function = "tsc_edge_out3";
soc_gpio50_pbb2 {
nvidia,pins = "soc_gpio50_pbb2";
nvidia,function = "tsc_edge_out0";
gp_pwm2_px2 {
nvidia,pins = "gp_pwm2_px2";
gp_pwm3_px3 {
nvidia,pins = "gp_pwm3_px3";
uart2_tx_px4 {
nvidia,pins = "uart2_tx_px4";
nvidia,function = "uartb";
uart2_rx_px5 {
nvidia,pins = "uart2_rx_px5";
uart2_rts_px6 {
nvidia,pins = "uart2_rts_px6";
uart2_cts_px7 {
nvidia,pins = "uart2_cts_px7";
uart5_tx_py5 {
nvidia,pins = "uart5_tx_py5";
nvidia,function = "uarti";
uart5_rx_py6 {
nvidia,pins = "uart5_rx_py6";
extperiph1_clk_pp0 {
nvidia,pins = "extperiph1_clk_pp0";
nvidia,function = "extperiph1";
extperiph2_clk_pp1 {
nvidia,pins = "extperiph2_clk_pp1";
nvidia,function = "extperiph2";
cam_i2c_scl_pp2 {
nvidia,pins = "cam_i2c_scl_pp2";
nvidia,function = "i2c3";
cam_i2c_sda_pp3 {
nvidia,pins = "cam_i2c_sda_pp3";
soc_gpio24_pp5 {
nvidia,pins = "soc_gpio24_pp5";
pwr_i2c_scl_pp7 {
nvidia,pins = "pwr_i2c_scl_pp7";
nvidia,function = "i2c5";
pwr_i2c_sda_pq0 {
nvidia,pins = "pwr_i2c_sda_pq0";
soc_gpio29_pq2 {
nvidia,pins = "soc_gpio29_pq2";
nvidia,function = "nv";
soc_gpio32_pq5 {
nvidia,pins = "soc_gpio32_pq5";
nvidia,function = "extperiph3";
soc_gpio37_pr0 {
nvidia,pins = "soc_gpio37_pr0";
uart1_tx_pr2 {
nvidia,pins = "uart1_tx_pr2";
nvidia,function = "uarta";
uart1_rx_pr3 {
nvidia,pins = "uart1_rx_pr3";
nvidia,pull = <TEGRA_PIN_PULL_UP>;
uart1_rts_pr4 {
nvidia,pins = "uart1_rts_pr4";
uart1_cts_pr5 {
nvidia,pins = "uart1_cts_pr5";
dp_aux_ch0_hpd_pm0 {
nvidia,pins = "dp_aux_ch0_hpd_pm0";
nvidia,function = "dp";
dp_aux_ch1_hpd_pm1 {
nvidia,pins = "dp_aux_ch1_hpd_pm1";
nvidia,function = "eth3";
dp_aux_ch2_hpd_pm2 {
nvidia,pins = "dp_aux_ch2_hpd_pm2";
dp_aux_ch3_p_pn7 {
nvidia,pins = "dp_aux_ch3_p_pn7";
nvidia,function = "i2c9";
dp_aux_ch3_n_pn0 {
nvidia,pins = "dp_aux_ch3_n_pn0";
dp_aux_ch3_hpd_pm3 {
nvidia,pins = "dp_aux_ch3_hpd_pm3";
nvidia,function = "eth2";
soc_gpio55_pm4 {
nvidia,pins = "soc_gpio55_pm4";
soc_gpio36_pm5 {
nvidia,pins = "soc_gpio36_pm5";
nvidia,function = "eth0";
soc_gpio53_pm6 {
nvidia,pins = "soc_gpio53_pm6";
soc_gpio38_pm7 {
nvidia,pins = "soc_gpio38_pm7";
nvidia,function = "eth1";
soc_gpio40_pn2 {
nvidia,pins = "soc_gpio40_pn2";
soc_gpio19_pg6 {
nvidia,pins = "soc_gpio19_pg6";
gen1_i2c_scl_pi3 {
nvidia,pins = "gen1_i2c_scl_pi3";
nvidia,function = "i2c1";
gen1_i2c_sda_pi4 {
nvidia,pins = "gen1_i2c_sda_pi4";
soc_gpio07_pi6 {
nvidia,pins = "soc_gpio07_pi6";
sdmmc1_clk_pj0 {
nvidia,pins = "sdmmc1_clk_pj0";
nvidia,function = "sdmmc1";
nvidia,loopback = <TEGRA_PIN_ENABLE>;
sdmmc1_cmd_pj1 {
nvidia,pins = "sdmmc1_cmd_pj1";
sdmmc1_dat0_pj2 {
nvidia,pins = "sdmmc1_dat0_pj2";
sdmmc1_dat1_pj3 {
nvidia,pins = "sdmmc1_dat1_pj3";
sdmmc1_dat2_pj4 {
nvidia,pins = "sdmmc1_dat2_pj4";
sdmmc1_dat3_pj5 {
nvidia,pins = "sdmmc1_dat3_pj5";
qspi0_sck_pc0 {
nvidia,pins = "qspi0_sck_pc0";
nvidia,function = "qspi0";
qspi0_cs_n_pc1 {
nvidia,pins = "qspi0_cs_n_pc1";
qspi0_io0_pc2 {
nvidia,pins = "qspi0_io0_pc2";
qspi0_io1_pc3 {
nvidia,pins = "qspi0_io1_pc3";
qspi0_io2_pc4 {
nvidia,pins = "qspi0_io2_pc4";
qspi0_io3_pc5 {
nvidia,pins = "qspi0_io3_pc5";
soc_gpio59_pac6 {
nvidia,pins = "soc_gpio59_pac6";
nvidia,function = "aud";
soc_gpio45_pad0 {
nvidia,pins = "soc_gpio45_pad0";
nvidia,function = "i2s1";
soc_gpio46_pad1 {
nvidia,pins = "soc_gpio46_pad1";
soc_gpio47_pad2 {
nvidia,pins = "soc_gpio47_pad2";
soc_gpio48_pad3 {
nvidia,pins = "soc_gpio48_pad3";
ufs0_ref_clk_pae0 {
nvidia,pins = "ufs0_ref_clk_pae0";
nvidia,function = "ufs0";
ufs0_rst_n_pae1 {
nvidia,pins = "ufs0_rst_n_pae1";
pex_l1_clkreq_n_pk2 {
nvidia,pins = "pex_l1_clkreq_n_pk2";
nvidia,function = "pe1";
pex_l1_rst_n_pk3 {
nvidia,pins = "pex_l1_rst_n_pk3";
pex_l4_clkreq_n_pl0 {
nvidia,pins = "pex_l4_clkreq_n_pl0";
nvidia,function = "pe4";
pex_l4_rst_n_pl1 {
nvidia,pins = "pex_l4_rst_n_pl1";
dap4_sclk_pa4 {
nvidia,pins = "dap4_sclk_pa4";
nvidia,function = "i2s4";
dap4_dout_pa5 {
nvidia,pins = "dap4_dout_pa5";
dap4_din_pa6 {
nvidia,pins = "dap4_din_pa6";
dap4_fs_pa7 {
nvidia,pins = "dap4_fs_pa7";
pex_l5_clkreq_n_paf0 {
nvidia,pins = "pex_l5_clkreq_n_paf0";
nvidia,function = "pe5";
pex_l5_rst_n_paf1 {
nvidia,pins = "pex_l5_rst_n_paf1";
emmc_clk {
nvidia,pins = "emmc_clk";
nvidia,function = "emmc";
emmc_cmd {
nvidia,pins = "emmc_cmd";
nvidia,loopback = <TEGRA_PIN_DISABLE>;
emmc_dat0 {
nvidia,pins = "emmc_dat0";
emmc_dat1 {
nvidia,pins = "emmc_dat1";
emmc_dat2 {
nvidia,pins = "emmc_dat2";
emmc_dat3 {
nvidia,pins = "emmc_dat3";
emmc_dat4 {
nvidia,pins = "emmc_dat4";
emmc_dat5 {
nvidia,pins = "emmc_dat5";
emmc_dat6 {
nvidia,pins = "emmc_dat6";
emmc_dat7 {
nvidia,pins = "emmc_dat7";
emmc_dqs {
nvidia,pins = "emmc_dqs";
/* GPIO Pin Configuration */
soc_gpio26_pee5 {
nvidia,pins = "soc_gpio26_pee5";
nvidia,function = "rsvd0";
soc_gpio27_pee6 {
nvidia,pins = "soc_gpio27_pee6";
ao_retention_n_pee2 {
nvidia,pins = "ao_retention_n_pee2";
nvidia,function = "rsvd2";
power_on_pee4 {
nvidia,pins = "power_on_pee4";
spi2_sck_pcc0 {
nvidia,pins = "spi2_sck_pcc0";
nvidia,function = "rsvd1";
spi2_miso_pcc1 {
nvidia,pins = "spi2_miso_pcc1";
spi2_mosi_pcc2 {
nvidia,pins = "spi2_mosi_pcc2";
spi2_cs0_pcc3 {
nvidia,pins = "spi2_cs0_pcc3";
can0_dout_paa0 {
nvidia,pins = "can0_dout_paa0";
can0_din_paa1 {
nvidia,pins = "can0_din_paa1";
can1_dout_paa2 {
nvidia,pins = "can1_dout_paa2";
can1_din_paa3 {
nvidia,pins = "can1_din_paa3";
can1_stb_pbb0 {
nvidia,pins = "can1_stb_pbb0";
can1_en_pbb1 {
nvidia,pins = "can1_en_pbb1";
can1_err_pbb3 {
nvidia,pins = "can1_err_pbb3";
soc_gpio08_pb0 {
nvidia,pins = "soc_gpio08_pb0";
gpu_pwr_req_px0 {
nvidia,pins = "gpu_pwr_req_px0";
cv_pwr_req_px1 {
nvidia,pins = "cv_pwr_req_px1";
spi3_sck_py0 {
nvidia,pins = "spi3_sck_py0";
spi3_miso_py1 {
nvidia,pins = "spi3_miso_py1";
spi3_mosi_py2 {
nvidia,pins = "spi3_mosi_py2";
spi3_cs0_py3 {
nvidia,pins = "spi3_cs0_py3";
spi3_cs1_py4 {
nvidia,pins = "spi3_cs1_py4";
uart5_rts_py7 {
nvidia,pins = "uart5_rts_py7";
uart5_cts_pz0 {
nvidia,pins = "uart5_cts_pz0";
usb_vbus_en0_pz1 {
nvidia,pins = "usb_vbus_en0_pz1";
usb_vbus_en1_pz2 {
nvidia,pins = "usb_vbus_en1_pz2";
spi1_sck_pz3 {
nvidia,pins = "spi1_sck_pz3";
spi1_miso_pz4 {
nvidia,pins = "spi1_miso_pz4";
spi1_mosi_pz5 {
nvidia,pins = "spi1_mosi_pz5";
spi1_cs0_pz6 {
nvidia,pins = "spi1_cs0_pz6";
spi1_cs1_pz7 {
nvidia,pins = "spi1_cs1_pz7";
soc_gpio23_pp4 {
nvidia,pins = "soc_gpio23_pp4";
nvidia,function = "vi0";
soc_gpio25_pp6 {
nvidia,pins = "soc_gpio25_pp6";
soc_gpio28_pq1 {
nvidia,pins = "soc_gpio28_pq1";
soc_gpio31_pq4 {
nvidia,pins = "soc_gpio31_pq4";
soc_gpio33_pq6 {
nvidia,pins = "soc_gpio33_pq6";
soc_gpio35_pq7 {
nvidia,pins = "soc_gpio35_pq7";
soc_gpio56_pr1 {
nvidia,pins = "soc_gpio56_pr1";
dp_aux_ch1_p_pn3 {
nvidia,pins = "dp_aux_ch1_p_pn3";
dp_aux_ch1_n_pn4 {
nvidia,pins = "dp_aux_ch1_n_pn4";
soc_gpio39_pn1 {
nvidia,pins = "soc_gpio39_pn1";
soc_gpio13_pg0 {
nvidia,pins = "soc_gpio13_pg0";
soc_gpio14_pg1 {
nvidia,pins = "soc_gpio14_pg1";
soc_gpio15_pg2 {
nvidia,pins = "soc_gpio15_pg2";
soc_gpio16_pg3 {
nvidia,pins = "soc_gpio16_pg3";
soc_gpio20_pg7 {
nvidia,pins = "soc_gpio20_pg7";
soc_gpio21_ph0 {
nvidia,pins = "soc_gpio21_ph0";
soc_gpio22_ph1 {
nvidia,pins = "soc_gpio22_ph1";
uart4_tx_ph3 {
nvidia,pins = "uart4_tx_ph3";
uart4_rx_ph4 {
nvidia,pins = "uart4_rx_ph4";
uart4_rts_ph5 {
nvidia,pins = "uart4_rts_ph5";
uart4_cts_ph6 {
nvidia,pins = "uart4_cts_ph6";
soc_gpio41_ph7 {
nvidia,pins = "soc_gpio41_ph7";
soc_gpio42_pi0 {
nvidia,pins = "soc_gpio42_pi0";
soc_gpio43_pi1 {
nvidia,pins = "soc_gpio43_pi1";
soc_gpio44_pi2 {
nvidia,pins = "soc_gpio44_pi2";
cpu_pwr_req_pi5 {
nvidia,pins = "cpu_pwr_req_pi5";
spi5_sck_pac0 {
nvidia,pins = "spi5_sck_pac0";
nvidia,function = "rsvd3";
spi5_miso_pac1 {
nvidia,pins = "spi5_miso_pac1";
spi5_mosi_pac2 {
nvidia,pins = "spi5_mosi_pac2";
spi5_cs0_pac3 {
nvidia,pins = "spi5_cs0_pac3";
soc_gpio57_pac4 {
nvidia,pins = "soc_gpio57_pac4";
soc_gpio58_pac5 {
nvidia,pins = "soc_gpio58_pac5";
soc_gpio60_pac7 {
nvidia,pins = "soc_gpio60_pac7";
pex_l0_clkreq_n_pk0 {
nvidia,pins = "pex_l0_clkreq_n_pk0";
pex_l0_rst_n_pk1 {
nvidia,pins = "pex_l0_rst_n_pk1";
pex_l2_clkreq_n_pk4 {
nvidia,pins = "pex_l2_clkreq_n_pk4";
pex_l2_rst_n_pk5 {
nvidia,pins = "pex_l2_rst_n_pk5";
pex_l3_clkreq_n_pk6 {
nvidia,pins = "pex_l3_clkreq_n_pk6";
pex_l3_rst_n_pk7 {
nvidia,pins = "pex_l3_rst_n_pk7";
pex_wake_n_pl2 {
nvidia,pins = "pex_wake_n_pl2";
soc_gpio34_pl3 {
nvidia,pins = "soc_gpio34_pl3";
pex_l7_clkreq_n_pag0 {
nvidia,pins = "pex_l7_clkreq_n_pag0";
pex_l7_rst_n_pag1 {
nvidia,pins = "pex_l7_rst_n_pag1";
pex_l8_clkreq_n_pag2 {
nvidia,pins = "pex_l8_clkreq_n_pag2";
pex_l8_rst_n_pag3 {
nvidia,pins = "pex_l8_rst_n_pag3";
pex_l9_clkreq_n_pag4 {
nvidia,pins = "pex_l9_clkreq_n_pag4";
pex_l9_rst_n_pag5 {
nvidia,pins = "pex_l9_rst_n_pag5";
pex_l10_clkreq_n_pag6 {
nvidia,pins = "pex_l10_clkreq_n_pag6";
pex_l10_rst_n_pag7 {
nvidia,pins = "pex_l10_rst_n_pag7";
dap6_sclk_pa0 {
nvidia,pins = "dap6_sclk_pa0";
dap6_dout_pa1 {
nvidia,pins = "dap6_dout_pa1";
dap6_din_pa2 {
nvidia,pins = "dap6_din_pa2";
dap6_fs_pa3 {
nvidia,pins = "dap6_fs_pa3";
pex_l6_clkreq_n_paf2 {
nvidia,pins = "pex_l6_clkreq_n_paf2";
pex_l6_rst_n_paf3 {
nvidia,pins = "pex_l6_rst_n_paf3";
pinmux_unused_lowpower: unused_lowpower {
sce_error_pee0 {
nvidia,pins = "sce_error_pee0";
vcomp_alert_pee1 {
nvidia,pins = "vcomp_alert_pee1";
bootv_ctl_n_pee7 {
nvidia,pins = "bootv_ctl_n_pee7";
can0_en_paa5 {
nvidia,pins = "can0_en_paa5";
soc_gpio49_paa6 {
nvidia,pins = "soc_gpio49_paa6";
soc_gpio30_pq3 {
nvidia,pins = "soc_gpio30_pq3";
dp_aux_ch2_p_pn5 {
nvidia,pins = "dp_aux_ch2_p_pn5";
dp_aux_ch2_n_pn6 {
nvidia,pins = "dp_aux_ch2_n_pn6";
soc_gpio17_pg4 {
nvidia,pins = "soc_gpio17_pg4";
soc_gpio18_pg5 {
nvidia,pins = "soc_gpio18_pg5";
soc_gpio06_ph2 {
nvidia,pins = "soc_gpio06_ph2";
qspi1_sck_pc6 {
nvidia,pins = "qspi1_sck_pc6";
qspi1_cs_n_pc7 {
nvidia,pins = "qspi1_cs_n_pc7";
qspi1_io0_pd0 {
nvidia,pins = "qspi1_io0_pd0";
qspi1_io1_pd1 {
nvidia,pins = "qspi1_io1_pd1";
qspi1_io2_pd2 {
nvidia,pins = "qspi1_io2_pd2";
qspi1_io3_pd3 {
nvidia,pins = "qspi1_io3_pd3";
eqos_txc_pe0 {
nvidia,pins = "eqos_txc_pe0";
nvidia,function = "eqos";
eqos_td0_pe1 {
nvidia,pins = "eqos_td0_pe1";
eqos_td1_pe2 {
nvidia,pins = "eqos_td1_pe2";
eqos_td2_pe3 {
nvidia,pins = "eqos_td2_pe3";
eqos_td3_pe4 {
nvidia,pins = "eqos_td3_pe4";
eqos_tx_ctl_pe5 {
nvidia,pins = "eqos_tx_ctl_pe5";
eqos_rd0_pe6 {
nvidia,pins = "eqos_rd0_pe6";
eqos_rd1_pe7 {
nvidia,pins = "eqos_rd1_pe7";
eqos_rd2_pf0 {
nvidia,pins = "eqos_rd2_pf0";
eqos_rd3_pf1 {
nvidia,pins = "eqos_rd3_pf1";
eqos_rx_ctl_pf2 {
nvidia,pins = "eqos_rx_ctl_pf2";
eqos_rxc_pf3 {
nvidia,pins = "eqos_rxc_pf3";
can2_dout_ps0 {
nvidia,pins = "can2_dout_ps0";
can2_din_ps1 {
nvidia,pins = "can2_din_ps1";
can2_stb_ps2 {
nvidia,pins = "can2_stb_ps2";
can2_en_ps3 {
nvidia,pins = "can2_en_ps3";
can2_err_ps4 {
nvidia,pins = "can2_err_ps4";
can3_dout_ps5 {
nvidia,pins = "can3_dout_ps5";
can3_din_ps6 {
nvidia,pins = "can3_din_ps6";
can3_stb_ps7 {
nvidia,pins = "can3_stb_ps7";
can3_en_pt0 {
nvidia,pins = "can3_en_pt0";
can3_err_pt1 {
nvidia,pins = "can3_err_pt1";
soc_error_pu0 {
nvidia,pins = "soc_error_pu0";
uart7_tx_pu1 {
nvidia,pins = "uart7_tx_pu1";
uart7_rx_pu2 {
nvidia,pins = "uart7_rx_pu2";
spi7_sck_pu3 {
nvidia,pins = "spi7_sck_pu3";
spi7_miso_pu4 {
nvidia,pins = "spi7_miso_pu4";
spi7_mosi_pu5 {
nvidia,pins = "spi7_mosi_pu5";
spi7_cs0_pu6 {
nvidia,pins = "spi7_cs0_pu6";
soc_gpio51_pu7 {
nvidia,pins = "soc_gpio51_pu7";
soc_gpio52_pv0 {
nvidia,pins = "soc_gpio52_pv0";
soc_gpio61_pw0 {
nvidia,pins = "soc_gpio61_pw0";
soc_gpio62_pw1 {
nvidia,pins = "soc_gpio62_pw1";
drive_default: drive {
#include "tegra234-gpio.h"
gpio@2200000 {
gpio-init-names = "default";
gpio-init-0 = <&gpio_main_default>;
gpio_main_default: default {
gpio-input = <
TEGRA234_MAIN_GPIO(B, 0)
TEGRA234_MAIN_GPIO(Y, 3)
TEGRA234_MAIN_GPIO(Y, 4)
TEGRA234_MAIN_GPIO(Z, 1)
TEGRA234_MAIN_GPIO(Z, 2)
TEGRA234_MAIN_GPIO(Z, 3)
TEGRA234_MAIN_GPIO(Z, 4)
TEGRA234_MAIN_GPIO(Z, 5)
TEGRA234_MAIN_GPIO(Z, 6)
TEGRA234_MAIN_GPIO(Z, 7)
TEGRA234_MAIN_GPIO(P, 4)
TEGRA234_MAIN_GPIO(P, 6)
TEGRA234_MAIN_GPIO(Q, 6)
TEGRA234_MAIN_GPIO(Q, 7)
TEGRA234_MAIN_GPIO(R, 1)
TEGRA234_MAIN_GPIO(N, 4)
TEGRA234_MAIN_GPIO(N, 1)
TEGRA234_MAIN_GPIO(G, 0)
TEGRA234_MAIN_GPIO(G, 1)
TEGRA234_MAIN_GPIO(G, 2)
TEGRA234_MAIN_GPIO(G, 7)
TEGRA234_MAIN_GPIO(H, 0)
TEGRA234_MAIN_GPIO(H, 7)
TEGRA234_MAIN_GPIO(I, 0)
TEGRA234_MAIN_GPIO(I, 1)
TEGRA234_MAIN_GPIO(I, 2)
TEGRA234_MAIN_GPIO(AC, 3)
TEGRA234_MAIN_GPIO(AC, 4)
TEGRA234_MAIN_GPIO(AC, 5)
TEGRA234_MAIN_GPIO(AE, 0)
TEGRA234_MAIN_GPIO(AE, 1)
TEGRA234_MAIN_GPIO(K, 0)
TEGRA234_MAIN_GPIO(K, 1)
TEGRA234_MAIN_GPIO(K, 6)
TEGRA234_MAIN_GPIO(K, 7)
TEGRA234_MAIN_GPIO(L, 2)
TEGRA234_MAIN_GPIO(L, 3)
TEGRA234_MAIN_GPIO(AG, 0)
TEGRA234_MAIN_GPIO(AG, 1)
TEGRA234_MAIN_GPIO(AG, 2)
TEGRA234_MAIN_GPIO(AG, 3)
TEGRA234_MAIN_GPIO(AG, 6)
TEGRA234_MAIN_GPIO(AG, 7)
TEGRA234_MAIN_GPIO(AF, 2)
TEGRA234_MAIN_GPIO(AF, 3)
gpio-output-low = <
TEGRA234_MAIN_GPIO(X, 0)
TEGRA234_MAIN_GPIO(X, 1)
TEGRA234_MAIN_GPIO(Q, 4)
TEGRA234_MAIN_GPIO(N, 3)
TEGRA234_MAIN_GPIO(H, 1)
TEGRA234_MAIN_GPIO(H, 3)
TEGRA234_MAIN_GPIO(H, 4)
TEGRA234_MAIN_GPIO(H, 5)
TEGRA234_MAIN_GPIO(H, 6)
TEGRA234_MAIN_GPIO(I, 5)
TEGRA234_MAIN_GPIO(AC, 0)
TEGRA234_MAIN_GPIO(AC, 1)
TEGRA234_MAIN_GPIO(AC, 2)
TEGRA234_MAIN_GPIO(A, 1)
TEGRA234_MAIN_GPIO(A, 2)
gpio-output-high = <
TEGRA234_MAIN_GPIO(Y, 0)
TEGRA234_MAIN_GPIO(Y, 1)
TEGRA234_MAIN_GPIO(Y, 2)
TEGRA234_MAIN_GPIO(Z, 0)
TEGRA234_MAIN_GPIO(Q, 1)
TEGRA234_MAIN_GPIO(G, 3)
TEGRA234_MAIN_GPIO(AC, 7)
TEGRA234_MAIN_GPIO(K, 5)
TEGRA234_MAIN_GPIO(A, 0)
TEGRA234_MAIN_GPIO(A, 3)
gpio@c2f0000 {
gpio-init-0 = <&gpio_aon_default>;
gpio_aon_default: default {
gpio-input = <
TEGRA234_AON_GPIO(EE, 5)
TEGRA234_AON_GPIO(EE, 6)
TEGRA234_AON_GPIO(EE, 2)
TEGRA234_AON_GPIO(EE, 4)
TEGRA234_AON_GPIO(CC, 0)
TEGRA234_AON_GPIO(CC, 1)
TEGRA234_AON_GPIO(CC, 2)
TEGRA234_AON_GPIO(CC, 3)
TEGRA234_AON_GPIO(AA, 0)
TEGRA234_AON_GPIO(AA, 1)
TEGRA234_AON_GPIO(AA, 2)
TEGRA234_AON_GPIO(AA, 3)
TEGRA234_AON_GPIO(BB, 0)
TEGRA234_AON_GPIO(BB, 1)
gpio-output-low = <
TEGRA234_AON_GPIO(BB, 3)
gpio@9250000 {
gpio-init-0 = <&gpio_fsi_default>;
gpio_fsi_default: default {
gpio-input = <
gpio-output-low = <
dmesg output
root@jetson:/home/orin# dmesg | grep eth
[ 0.000000] psci: probing for conduit method from DT.
[ 4.549676] usbcore: registered new interface driver cdc_ether
[ 6.610639] optee: probing for conduit method.
[ 12.460987] nvethernet 2310000.ethernet: Adding to iommu group 51
[ 12.468076] nvethernet 2310000.ethernet: failed to read skip mac reset flag, default 0
[ 12.476849] nvethernet 2310000.ethernet: failed to read MDIO address
[ 12.484012] nvethernet 2310000.ethernet: setting to default DMA bit mask
[ 12.491508] nvethernet 2310000.ethernet: max-platform-mtu DT entry missing, setting default 1500
[ 12.502933] nvethernet 2310000.ethernet: missing nvidia,pad_auto_cal_pu_offset, setting default 0
[ 12.512668] nvethernet 2310000.ethernet: missing nvidia,pad_auto_cal_pd_offset, setting default 0
[ 12.522446] nvethernet 2310000.ethernet: failed to get phy reset gpio error: -2
[ 12.533600] nvethernet 2310000.ethernet: Ethernet MAC address: 48:b0:2d:ed:87:40
[ 12.542117] nvethernet 2310000.ethernet: macsec param in DT is missing or disabled
[ 12.550504] nvethernet 2310000.ethernet: Macsec not supported/Not enabled in DT
[ 12.559940] nvethernet 2310000.ethernet: eth0 (HW ver: 53) created with 8 DMA channels
[ 16.391370] using random self ethernet address
[ 16.396501] using random host ethernet address
[ 16.915713] nvethernet 2310000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[ 17.278650] using random self ethernet address
[ 17.283897] using random host ethernet address
re
arp -n (PC to Orin (Orin Shell))
root@jetson:/home/orin# arp -n
Address HWtype HWaddress Flags Mask Iface
12.18.1.10 ether 48:22:54:42:c5:0f C eth0
arp -n (Orin to PC (PC Shell))
ibrahim@pc:~$ arp -n
12.18.1.99 (incomplete) enx48225442c50f
Orin and Switch connection
