Jetson AGX Orin Dev Kit flashed successfully but OEM password bug
I flashed AGX Orin dev kit with sdk manager since cuda has a bug.
I tried few time of the orin’s password, failed, So I set manual setup flashed it.
It’s successful, but When I try to log in from screen command or a keyboard and screen, it had changed the username but my password is wrong.
So I tried to manual flashed it again, but the username didn’t change afterwards. The software said flash successful. But it was suppose to change.
I suppose I followed the instructions in nvidia sdk, did everything from
How do you flash your device?
Do you run the l4t_create_default_user.sh before?
Through nvidia sdk manager.
  1. shell command sdk manager.
  2. select Orin, deselect host, select jetpack version.
  3. select the jetson linux. wait for the process
  4. select the “orin” flash preferences, turn orin force recovery mode then select manual setup, preconfig oem.
  5. wait for it to process
  6. the return is successful and the terminal seems alright.
  7. unplug the orin, use it as a host machine, attach a screen and keyboard and mice to it.
  8. the username left unchanged.
I’m doing reflash since I installed a wrong version of jetpack. I thought I could apt install it and making bigger mistakes.
But the first reflash is like this, so I tried multiple times.
should I change the storage device and try again? for example, turn emmc to nvme devices.
Please try other methods like manual flash.
Take JP6.2 for example,
Please download Driver Package (BSP) and Sample Root Filesystem from Jetson Linux | NVIDIA Developer.
Follow the Quick Start — NVIDIA Jetson Linux Developer Guide to flash your device.
Before flash, please refer Flashing Support — NVIDIA Jetson Linux Developer Guide 1 documentation to create default user.
sudo ./tools/l4t_create_default_user.sh -u ${username} -p ${passwd}
this time I tried to use the flash.sh to flush and it was successful in command line.
then I do : l4t_create_default_user.sh and set a new default user, successful in command line.
Then I tried to use it as a host, attached a monitor to Orin, and it is still using the last user before flashing.
I believe it is due to I flashed multiple times on nvme and emmc.
So I flashed nvme again as well, but there is more problems.
This time, after successful flash, Attaching to a screen, the Orin is not sending signal to the screen anymore.
So I guess this is the altimate failure.
Hi
I think your nvme and emmc both have ubuntu. It might be the reason still using the last user.
Try to remove nvme and boot up from emmc.
I removed the vnme, connect it to the screen, still don’t work.
The screen had the same output as above, the current input is not supported by monitor.
Do I need to flash it again on emmc?
Or multiple flashes destroyed something inside this device?
Well I tried to attach Orin to the host PC again, with usb.
But this time the Orin without the nvme, is not showing anything.
no l4t usb drive GUI,
no 7020 or 7023 result in lsusb.
Please help me with what’s happening.
One item is this is backward and perhaps why the old user was still used.
Try in this order.
  1. sudo ./tools/l4t_create_default_user.sh -u ${username} -p ${passwd}
  2. flash.sh
thank you for your patient explanation and detailed support.
But the error became more severe:
When I attatched orin to host PC with USB, it can’t detect orin anymore.
No L4T drive disk GUI,
No 7020 and 7023 (the orin device number) after command:
lsusb
the same usb cable was used for flashing but today no usb device found.
shall I try to use the serial port, USB micro-B port to check out console log? Maybe it’s cable
When I’ve forgotten to hold the middle button and then touch the power button sdkmanager or lsusb could not find the Orin.
Please try do the device in recovery mode and check with lsusb.
OK. thank you.
I solved most of the problems.
I also understand that jetson agx orin you can’t flash to nvme, only use emmc.
So what should I do to the nvme ssd that had another linux, but causing boot problems?
format the nvme ssd with host PC first, then put it into Orin?
Thank you so much.
Last time I flashed I used sdkmanager and in it I picked nvme as the drive to install to and sdkmanager successfully installed everything on to the orin agx nvme drive.
But for me, when the nvme linux and emmc linux they have conflict, caused the problem.
I read the L4T documents, it seems that flashing NVME on AGX Orin wasn’t a good idea.
So should I format the NVME ssd drive before I use this thing, to avoid conflict again?
thank you.
If you want to flash NVMe as your rootfs, you could follow UEFI Adaptation — NVIDIA Jetson Linux Developer Guide to change the boot order.
This config can make sure you boot on NVMe first.
