Jetson AGX Orin Devkit, after OTA update booting problem
Hello, I’m using the Jetson OTA_tool, I have problem.
Target board : jetson-agx-orin-devkit (32GB)
BASE bsp → 35.6.1
Target bsp → 35.6.1
(just testing OTA tool)
and I used OTA Tool 35.6.1 in Target BSP.
in my Host PC, I used the command these.
export BASE_BSP=/home/myuserid/OTA/before_35.6.1/Linux_for_Tegra
TARGET_BSP=/home/myuserid/OTA/after_35.6.1/Linux_for_Tegra
sudo -E ./tools/ota_tools/version_upgrade/l4t_generate_ota_package.sh -r jetson-agx-orin-devkit R35-6
these generating ota-package command was successful, and I could get ‘ota_package’ tar.gz file.
and, I turn on my Jetson board (35.6.1) in emmc booting,
and checked /boot/extlinux/extlinux.conf.
finally, I used the trigger command
sudo ./nv_ota_start.sh /ota/ota_payload_package.tar.gz
(Ps. I moved the ota_package /ota/ directory)
and I checked ‘OTA was success. If i reboot, the updated rootfs was checkable’
but, sudo reboot was failed.
only Black screen displayed, and the cursor is existing in top-left location.
I could not use any command, so I don’t have the log.
(in starting, Nvidia Boot manager was seen, and may be recovery mod was trying to booting, but that was failed.)
Can i have the solution?
I understand that you’re experiencing an issue with the Jetson OTA tool on your Jetson AGX Orin DevKit (32GB) board. You’ve successfully generated the OTA package using the l4t_generate_ota_package.sh script and triggered the OTA update using the nv_ota_start.sh script. However, after rebooting, you’re seeing a black screen with a cursor in the top-left corner, and you’re unable to access the system or retrieve logs.
Based on the provided information, I’ll offer a comprehensive analysis and potential solutions.
Possible Causes:
  1. Incomplete or corrupted OTA update: Although you’ve confirmed that the OTA update was successful, it’s possible that the update process didn’t complete correctly or that the updated rootfs is corrupted.
  2. Bootloader or kernel issues: The Nvidia Boot Manager was seen during the boot process, but it failed to boot into the updated system. This could indicate a problem with the bootloader or kernel.
  3. System configuration or compatibility issues: The updated system might have configuration or compatibility issues that prevent it from booting correctly.
Troubleshooting Steps:
  1. Check the OTA package: Verify that the generated OTA package (ota_package.tar.gz) is correct and not corrupted. You can try re-generating the package using the l4t_generate_ota_package.sh script.
  2. Verify the update process: Double-check that the OTA update was applied correctly by inspecting the /boot/extlinux/extlinux.conf file and ensuring that the updated rootfs is present.
  3. Bootloader and kernel: Try booting the system in recovery mode or using a different bootloader to see if the issue persists. You can also try updating the bootloader or kernel separately to ensure they are compatible with the updated system.
  4. System configuration: Check the system configuration files (e.g., /etc/nv_ota.conf) to ensure that they are correct and compatible with the updated system.
  5. Logs and debugging: Try to retrieve logs from the system using a serial console or a debug tool like KGDB. This might provide more information about the boot failure.
Comparison with Similar Issues:
I couldn’t find any direct matches for this specific issue in the provided context. However, I can suggest some general troubleshooting steps that might be helpful.
Additional Information Needed:
To better assist you, I would need more information about the system configuration, the exact error messages or logs (if available), and any custom modifications made to the system.
Conclusion:
The issue you’re experiencing with the Jetson OTA tool on your Jetson AGX Orin DevKit (32GB) board is likely related to an incomplete or corrupted OTA update, bootloader or kernel issues, or system configuration or compatibility problems. By following the troubleshooting steps outlined above, you should be able to identify and potentially resolve the issue. If you’re still experiencing problems, please provide more information about your system configuration and any error messages or logs you’ve encountered.
Hi mjm2129,
Please refer to above methods for troubleshooting.
You can also refer to NVIDIA Jetson Orin AGX - In Board - Getting in Board - Serial Console to capture and provide serial console log at this moment for further check.
