Jetson AGX Orin Industrial - custom board mini PCIe
Hello!
In my custom board design, I would like to use PCIe C1 lane on a mini PCIe connector on the following way:
From AGX Orin Industrial side:
This lane was used on an M2 E connector on the the devkit (so I use the default pinmux and gpio and device tree nodes). In my use case I would like to connect it to a Epix Pixci H2FL (this is a commonly used frame grabber, from its data sheet it does not require power on the pcie port side, I supply the grabber by a 12V from an other PSU). When I debug it from my custom linux the following messages appeared in the log.
[ 8.522707] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 8.530726] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
[ 8.537905] tegra194-pcie 14100000.pcie: IO 0x0036100000…0x00361fffff → 0x0036100000
[ 8.554361] tegra194-pcie 14100000.pcie: MEM 0x2428000000…0x242fffffff → 0x0040000000
[ 8.563046] tegra194-pcie 14100000.pcie: MEM 0x2140000000…0x2427ffffff → 0x2140000000
[ 9.680713] tegra194-pcie 14100000.pcie: Phy link never came up
For the sake of hardware debug I try to measure the clk on the pcie clk lane p and n in this case the frame grabber its never showed 100 MHz. On the other hand I get a wifi card too for testing mini PCIe hardware side (intel centrino advanced-N 6205). This wifi module came up automatically in the slot and I could program it and try to join to wifi network (lspcie showed up and i can start config wlan0). In this case I could measure the 100 MHz on the PCIe CLK N lane.
I don’t really get it where my project fail. In case of wifi modul its appears as a working hardware and Linux OS. In case of the frame grabber its nothing (with the same setup). Also we test this frame grabber with an AGX Orin devkit with PCIe to mini PCIe adapter and its working fine (with and without powering the PCIe port).
Could you help me debug this problem?
Thanks,
Dominik
Is it on rel-35 or rel-36?
Hello!
We are on rel-35.
refer to this debug tips
https://docs.nvidia.com/jetson/archives/r35.6.0/DeveloperGuide/HR/JetsonModuleAdaptationAndBringUp/JetsonAgxOrinSeries.html?highlight=pcie#debug-pcie-link-up-failure
Hi!
We tried these debug methods already, could you help me locate the problematic part? Is it in hardware or in Linux configuration side? We already tried this frame grabber with the Orin devkit-s 16x pcie slot (with a PCIe to mini PCIEe adapter) and we think about presence signals. Or maybe the difference betwen normal PCIe and mini PCIe.
And when we pluged in a wifi modul, its worked fine too! (so maybe the hardver is right??)
Thanks,
Dominik
Just to make sure I understand the situation.
Are you talking about same design can detect another wifi card? what is not able to get detected here?
As I wrote in the main article above, we test the same from port (mini PCIe on carrier) with a wifi modul from intel and its came up on the PCIe bus and we can program it. But with a Epix frame grabbers mini PCIE port we could achieve this. I wrote this down in the first part please refer to that.
“For the sake of hardware debug I try to measure the clk on the pcie clk lane p and n in this case the frame grabber its never showed 100 MHz. On the other hand I get a wifi card too for testing mini PCIe hardware side (intel centrino advanced-N 6205). This wifi module came up automatically in the slot and I could program it and try to join to wifi network (lspcie showed up and i can start config wlan0). In this case I could measure the 100 MHz on the PCIe CLK N lane.”
Sorry, I am no hardware guy and only software folk.
Not quite sure what is changed here. Is it kind of form factor change? Or you change the PCIe device? Wifi card can work but frame grabber can’t?
So it is a PCIe modul change. I put the wifi modul in the mini PCIe port and its working with the linux… Frame grabber DOES NOT working currently.
On the other hand could you find some one who is coming from hardware side? And maybe put it on this thread?
From software aspects, this means software side is correctly configured.
I think from hardware aspect they would say the same too.
I also wonder what did you try from the debug tips in document. There were also cases that some users told us “yeah I tried”, but turned out they tried nothing because they don’t know how to….
It is common that specific pcie devices fail to get enumerated. There are always lots of such cases.
The most precise way may be using analyzer to dump LA trace.
