Thank you for your reply. According to the logs, the second camera encountered a timeout error:
Mar 18 15:05:31 ubuntu nvargus-daemon[1255]: === gst-launch-1.0[3403]: Connection established (FFFFAAA8B840)
Mar 18 15:05:31 ubuntu nvargus-daemon[1255]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
Mar 18 15:05:31 ubuntu nvargus-daemon[1255]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module1
Mar 18 15:05:31 ubuntu nvargus-daemon[1255]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module2
Mar 18 15:05:31 ubuntu nvargus-daemon[1255]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module3
Mar 18 15:05:31 ubuntu nvargus-daemon[1255]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module4
Mar 18 15:05:31 ubuntu nvargus-daemon[1255]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module5
Mar 18 15:05:31 ubuntu nvargus-daemon[1255]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module6
Mar 18 15:05:31 ubuntu nvargus-daemon[1255]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module7
Mar 18 15:05:31 ubuntu nvargus-daemon[1255]: NvPclHwGetModuleList: WARNING: Could not map module to ISP config string
Mar 18 15:05:31 ubuntu nvargus-daemon[1255]: NvPclHwGetModuleList: No module data found
Mar 18 15:05:31 ubuntu nvargus-daemon[1255]: OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
Mar 18 15:05:31 ubuntu nvargus-daemon[1255]: (NvCamV4l2) Error ModuleNotPresent: V4L2Device not available (in /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function findDevice(), line 258)
Mar 18 15:05:31 ubuntu nvargus-daemon[1255]: (NvCamV4l2) Error ModuleNotPresent: (propagating from /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function initialize(), line 62)
Mar 18 15:05:31 ubuntu nvargus-daemon[1255]: (NvOdmDevice) Error ModuleNotPresent: (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function initialize(), line 114)
Mar 18 15:05:31 ubuntu nvargus-daemon[1255]: NvPclDriverInitializeData: Unable to initialize driver v4l2_sensor
Mar 18 15:05:31 ubuntu nvargus-daemon[1255]: NvPclInitializeDrivers: error: Failed to init camera sub module v4l2_sensor
Mar 18 15:05:31 ubuntu nvargus-daemon[1255]: NvPclStartPlatformDrivers: Failed to start module drivers
Mar 18 15:05:31 ubuntu nvargus-daemon[1255]: NvPclStateControllerOpen: Failed ImagerGUID 0. (error 0xA000E)
Mar 18 15:05:31 ubuntu nvargus-daemon[1255]: NvPclOpen: PCL Open Failed. Error: 0xf
Mar 18 15:05:31 ubuntu nvargus-daemon[1255]: SCF: Error BadParameter: Sensor could not be opened. (in src/services/capture/CaptureServiceDeviceSensor.cpp, function getSourceFromGuid(), line 725)
Mar 18 15:05:31 ubuntu nvargus-daemon[1255]: SCF: Error BadParameter: (propagating from src/services/capture/CaptureService.cpp, function addSourceByGuid(), line 465)
Mar 18 15:05:31 ubuntu nvargus-daemon[1255]: SCF: Error BadParameter: (propagating from src/api/CameraDriver.cpp, function addSourceByIndex(), line 384)
Mar 18 15:05:31 ubuntu nvargus-daemon[1255]: SCF: Error BadParameter: (propagating from src/api/CameraDriver.cpp, function getSource(), line 556)
Mar 18 15:05:31 ubuntu nvargus-daemon[1255]: NvPclStateControllerOpen: Failed ImagerGUID 1. (error 0xA000E)
Mar 18 15:05:31 ubuntu nvargus-daemon[1255]: NvPclStateControllerOpen: Failed ImagerGUID 2. (error 0xA000E)
Mar 18 15:05:31 ubuntu nvargus-daemon[1255]: NvPclStateControllerOpen: Failed ImagerGUID 3. (error 0xA000E)
Mar 18 15:05:31 ubuntu nvargus-daemon[1255]: LSC: LSC surface is not based on full res!
Mar 18 15:05:31 ubuntu nvargus-daemon[1255]: NvPclStateControllerOpen: Failed ImagerGUID 5. (error 0xA000E)
Mar 18 15:05:32 ubuntu nvargus-daemon[1255]: LSC: LSC surface is not based on full res!
Mar 18 15:05:32 ubuntu nvargus-daemon[1255]: === gst-launch-1.0[3403]: CameraProvider initialized (0xffffa538d540)
Mar 18 15:05:38 ubuntu nvargus-daemon[1255]: === gst-launch-1.0[3474]: Connection established (FFFF827CB840)
Mar 18 15:05:38 ubuntu nvargus-daemon[1255]: === gst-launch-1.0[3474]: CameraProvider initialized (0xffff4c000c00)
Mar 18 15:05:38 ubuntu nvargus-daemon[1255]: LSC: LSC surface is not based on full res!
Mar 18 15:05:43 ubuntu nvargus-daemon[1255]: SCF: Error InvalidState: Timeout!! Skipping requests on sensor GUID 6, capture sequence ID = 0 draining session frameStart events 3
Mar 18 15:05:43 ubuntu nvargus-daemon[1255]: (in src/services/capture/FusaCaptureViCsiHw.cpp, function waitCsiFrameStart(), line 539)
Mar 18 15:05:43 ubuntu nvargus-daemon[1255]: SCF: Error InvalidState: Sensor GUID 6 is in error state. Skipping requests, capture sequence ID = 1 continue draining session frameStart events 2
Mar 18 15:05:43 ubuntu nvargus-daemon[1255]: (in src/services/capture/FusaCaptureViCsiHw.cpp, function waitCsiFrameStart(), line 553)
Mar 18 15:05:43 ubuntu nvargus-daemon[1255]: SCF: Error InvalidState: Sensor GUID 6 is in error state. Skipping requests, capture sequence ID = 2 continue draining session frameStart events 1
Mar 18 15:05:43 ubuntu nvargus-daemon[1255]: SCF: Error BadParameter: CC has already been disposed (in src/components/CaptureContainerManager.cpp, function dispose(), line 161)
Mar 18 15:05:43 ubuntu nvargus-daemon[1255]: SCF: Error InvalidState: Sensor 6 already in same state
Mar 18 15:05:43 ubuntu nvargus-daemon[1255]: (in src/services/capture/CaptureServiceDeviceSensor.cpp, function setErrorState(), line 100)
Mar 18 15:05:43 ubuntu nvargus-daemon[1255]: SCF: Error InvalidState: Timeout!! Skipping requests on sensor GUID 6, capture sequence ID = 0 draining session frameEnd events 3
Mar 18 15:05:43 ubuntu nvargus-daemon[1255]: (in src/services/capture/FusaCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 656)
Mar 18 15:05:43 ubuntu nvargus-daemon[1255]: SCF: Error InvalidState: Timeout!! Skipping requests on sensor GUID 6, capture sequence ID = 1 draining session frameEnd events 2
Mar 18 15:05:43 ubuntu nvargus-daemon[1255]: SCF: Error InvalidState: Timeout!! Skipping requests on sensor GUID 6, capture sequence ID = 2 draining session frameEnd events 1
Mar 18 15:05:43 ubuntu nvargus-daemon[1255]: SCF: Error Timeout: Sending critical error event for Session 6
Mar 18 15:05:43 ubuntu nvargus-daemon[1255]: (in src/api/Session.cpp, function sendErrorEvent(), line 1101)
Mar 18 15:05:43 ubuntu nvargus-daemon[1255]: Module_id 30 Severity 2 : (fusa) Error: Timeout propagating from:/capture/src/fusaViHandler.cpp 828
Mar 18 15:05:43 ubuntu nvargus-daemon[1255]: === gst-launch-1.0[3474]: CameraProvider destroyed (0xffff4c000c00)
Mar 18 15:05:44 ubuntu nvargus-daemon[1255]: === gst-launch-1.0[3474]: Connection closed (FFFF827CB840)
Mar 18 15:05:44 ubuntu nvargus-daemon[1255]: === gst-launch-1.0[3474]: Connection cleaned up (FFFF827CB840)
