I use Jetson-AGX-ORIN , two 8M cameras output YUV422-8bit data, output size is 3840*2160,in csi-5 x4 lanes, use virtual channels, one camera vc-id = 0, one camera vc-id = 1.
I can only enable any one of the two cameras to produce pictures normally. If the two cameras are enabled at the same time, the kernel will report an error and cannot obtain images.
On csi-0, csi-2, csi-4 and x4lanes interfaces, enable two channels of 8M cameras at the same time. There is no problem.
On csi-5 and x4lanes interfaces, enable two 2M cameras at the same time. There is no problem
Is there anything special about the interface of csi-5 x4lanes?
Can the csi-5 and x4lanes interfaces not support the bandwidth of two channels of 8m cameras at the same time?
Did you mean CSI6/7 aka CSI-G/H? Only able configure 4 lanes in CSI-0/1, CSI-2/3, CSI-4/5, CSI-6/7
Yes, csi-g / h is connected to two 8m cameras and cannot enable the camera to output image data at the same time.
csi-a/b-pp0 csi-0
csi-c/d-pp2 csi-2
csi-e/f-pp4 csi-4
csi-g/h-pp5 csi-5
csi-0/csi-2/csi-4 can enable two 8M cameras to output image data at the same time.
Did you boost the clocks to try?
echo 1 > /sys/kernel/debug/bpmp/debug/clk/vi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/isp/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/nvcsi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/emc/mrq_rate_locked
cat /sys/kernel/debug/bpmp/debug/clk/vi/max_rate |tee /sys/kernel/debug/bpmp/debug/clk/vi/rate
cat /sys/kernel/debug/bpmp/debug/clk/isp/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/isp/rate
cat /sys/kernel/debug/bpmp/debug/clk/nvcsi/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/nvcsi/rate
cat /sys/kernel/debug/bpmp/debug/clk/emc/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/emc/rate
I’ve tried to turn up the clock as you suggested, but the two cameras still can’t produce images at the same time.
The following trace log is the log of the output image of one of the two cameras:
# tracer: nop
# entries-in-buffer/entries-written: 870559/4756479 #P:12
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
tztek-jetson-to-10327 [006] .... 1073.595429: tegra_channel_open: vi-output, imx185 33-0021
tztek-jetson-to-10327 [006] .... 1073.623292: tegra_channel_set_power: imx185 33-0021 : 0x1
tztek-jetson-to-10327 [006] .... 1073.623306: camera_common_s_power: status : 0x1
tztek-jetson-to-10327 [006] .... 1073.624454: tegra_channel_set_power: 13e40000.host1x:nvcsi@15a00000- : 0x1
tztek-jetson-to-10327 [006] .... 1073.624457: csi_s_power: enable : 0x1
tztek-jetson-to-10327 [006] .... 1073.624542: tegra_channel_capture_setup: vnc_id 0 W 3840 H 2160 fmt 10
tztek-jetson-to-10327 [006] .... 1073.626363: tegra_channel_set_stream: enable : 0x1
##### CPU 7 buffer started ####
tztek-jetson-to-10327 [007] .... 1073.648617: tegra_channel_set_stream: 13e40000.host1x:nvcsi@15a00000- : 0x1
tztek-jetson-to-10327 [007] .... 1073.648621: csi_s_stream: enable : 0x1
tztek-jetson-to-10327 [007] .... 1073.654819: tegra_channel_set_stream: imx185 33-0021 : 0x1
##### CPU 4 buffer started ####
vi-output, imx1-10329 [004] .... 1073.822174: tegra_channel_capture_frame: sof:1089.205301376
vi-output, imx1-10329 [004] .... 1073.822177: tegra_channel_capture_frame: eof:1089.237293472
##### CPU 1 buffer started ####
vi-output, imx1-10329 [001] .... 1076.456091: tegra_channel_capture_setup: vnc_id 0 W 3840 H 2160 fmt 10
vi-output, imx1-10329 [001] .... 1076.655171: tegra_channel_capture_frame: sof:1092.38565568
vi-output, imx1-10329 [001] .... 1076.655173: tegra_channel_capture_frame: eof:1092.70557888
vi-output, imx1-10329 [001] .... 1079.256405: tegra_channel_capture_setup: vnc_id 0 W 3840 H 2160 fmt 10
vi-output, imx1-10329 [001] .... 1079.422194: tegra_channel_capture_frame: sof:1094.805168576
vi-output, imx1-10329 [001] .... 1079.422197: tegra_channel_capture_frame: eof:1094.837160544
vi-output, imx1-10329 [001] .... 1082.089136: tegra_channel_capture_setup: vnc_id 0 W 3840 H 2160 fmt 10
##### CPU 2 buffer started ####
vi-output, imx1-10329 [002] .... 1082.289173: tegra_channel_capture_frame: sof:1097.671775680
vi-output, imx1-10329 [002] .... 1082.289176: tegra_channel_capture_frame: eof:1097.703760832
vi-output, imx1-10329 [002] .... 1084.890332: tegra_channel_capture_setup: vnc_id 0 W 3840 H 2160 fmt 10
vi-output, imx1-10329 [002] .... 1085.055162: tegra_channel_capture_frame: sof:1100.438373856
vi-output, imx1-10329 [002] .... 1085.055164: tegra_channel_capture_frame: eof:1100.470363072
vi-output, imx1-10329 [002] .... 1087.689167: tegra_channel_capture_setup: vnc_id 0 W 3840 H 2160 fmt 10
vi-output, imx1-10329 [002] .... 1087.822179: tegra_channel_capture_frame: sof:1103.204973024
vi-output, imx1-10329 [002] .... 1087.822181: tegra_channel_capture_frame: eof:1103.236964896
vi-output, imx1-10329 [002] .... 1090.523284: tegra_channel_capture_setup: vnc_id 0 W 3840 H 2160 fmt 10
vi-output, imx1-10329 [001] .... 1090.688176: tegra_channel_capture_frame: sof:1106.71572096
vi-output, imx1-10329 [001] .... 1090.688178: tegra_channel_capture_frame: eof:1106.103564000
vi-output, imx1-10329 [001] .... 1093.323221: tegra_channel_capture_setup: vnc_id 0 W 3840 H 2160 fmt 10
vi-output, imx1-10329 [001] .... 1093.455167: tegra_channel_capture_frame: sof:1108.838178368
vi-output, imx1-10329 [001] .... 1093.455169: tegra_channel_capture_frame: eof:1108.870165184
vi-output, imx1-10329 [002] .... 1096.156033: tegra_channel_capture_setup: vnc_id 0 W 3840 H 2160 fmt 10
vi-output, imx1-10329 [002] .... 1096.322174: tegra_channel_capture_frame: sof:1111.704772448
vi-output, imx1-10329 [002] .... 1096.322175: tegra_channel_capture_frame: eof:1111.736763584
##### CPU 11 buffer started ####
kworker/11:3-1798 [011] .... 1098.946335: rtcpu_nvcsi_intr: tstamp:34822284654 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946335: rtcpu_nvcsi_intr: tstamp:34822284654 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946335: rtcpu_nvcsi_intr: tstamp:34822285432 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946336: rtcpu_nvcsi_intr: tstamp:34822285432 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946336: rtcpu_nvcsi_intr: tstamp:34822285432 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946336: rtcpu_nvcsi_intr: tstamp:34822285432 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946336: rtcpu_nvcsi_intr: tstamp:34822286210 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946336: rtcpu_nvcsi_intr: tstamp:34822286210 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946336: rtcpu_nvcsi_intr: tstamp:34822286210 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946337: rtcpu_nvcsi_intr: tstamp:34822286210 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946337: rtcpu_nvcsi_intr: tstamp:34822286988 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946337: rtcpu_nvcsi_intr: tstamp:34822286988 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946337: rtcpu_nvcsi_intr: tstamp:34822286988 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946337: rtcpu_nvcsi_intr: tstamp:34822286988 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946337: rtcpu_nvcsi_intr: tstamp:34822287766 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946337: rtcpu_nvcsi_intr: tstamp:34822287766 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946337: rtcpu_nvcsi_intr: tstamp:34822287766 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946338: rtcpu_nvcsi_intr: tstamp:34822287766 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946338: rtcpu_nvcsi_intr: tstamp:34822288544 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946338: rtcpu_nvcsi_intr: tstamp:34822288544 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946338: rtcpu_nvcsi_intr: tstamp:34822288544 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946338: rtcpu_nvcsi_intr: tstamp:34822288544 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946338: rtcpu_nvcsi_intr: tstamp:34822289318 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946338: rtcpu_nvcsi_intr: tstamp:34822289318 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946338: rtcpu_nvcsi_intr: tstamp:34822289318 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946339: rtcpu_nvcsi_intr: tstamp:34822289318 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946339: rtcpu_nvcsi_intr: tstamp:34822290094 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946339: rtcpu_nvcsi_intr: tstamp:34822290094 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946339: rtcpu_nvcsi_intr: tstamp:34822290094 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946339: rtcpu_nvcsi_intr: tstamp:34822290094 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946339: rtcpu_nvcsi_intr: tstamp:34822290869 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946339: rtcpu_nvcsi_intr: tstamp:34822290869 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946339: rtcpu_nvcsi_intr: tstamp:34822290869 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946340: rtcpu_nvcsi_intr: tstamp:34822290869 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946340: rtcpu_nvcsi_intr: tstamp:34822291651 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946340: rtcpu_nvcsi_intr: tstamp:34822291651 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946340: rtcpu_nvcsi_intr: tstamp:34822291651 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946340: rtcpu_nvcsi_intr: tstamp:34822291651 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946340: rtcpu_nvcsi_intr: tstamp:34822292438 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946340: rtcpu_nvcsi_intr: tstamp:34822292438 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946340: rtcpu_nvcsi_intr: tstamp:34822292438 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946341: rtcpu_nvcsi_intr: tstamp:34822292438 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946341: rtcpu_nvcsi_intr: tstamp:34822293225 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946341: rtcpu_nvcsi_intr: tstamp:34822293225 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946341: rtcpu_nvcsi_intr: tstamp:34822293225 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946341: rtcpu_nvcsi_intr: tstamp:34822293225 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946341: rtcpu_nvcsi_intr: tstamp:34822294012 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946341: rtcpu_nvcsi_intr: tstamp:34822294012 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946342: rtcpu_nvcsi_intr: tstamp:34822294012 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946342: rtcpu_nvcsi_intr: tstamp:34822294012 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946342: rtcpu_nvcsi_intr: tstamp:34822294798 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946342: rtcpu_nvcsi_intr: tstamp:34822294798 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946342: rtcpu_nvcsi_intr: tstamp:34822294798 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946342: rtcpu_nvcsi_intr: tstamp:34822294798 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946342: rtcpu_nvcsi_intr: tstamp:34822295581 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946342: rtcpu_nvcsi_intr: tstamp:34822295581 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946343: rtcpu_nvcsi_intr: tstamp:34822295581 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946343: rtcpu_nvcsi_intr: tstamp:34822295581 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946343: rtcpu_nvcsi_intr: tstamp:34822296363 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946343: rtcpu_nvcsi_intr: tstamp:34822296363 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946343: rtcpu_nvcsi_intr: tstamp:34822296363 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946343: rtcpu_nvcsi_intr: tstamp:34822296363 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946343: rtcpu_nvcsi_intr: tstamp:34822297145 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946343: rtcpu_nvcsi_intr: tstamp:34822297145 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946344: rtcpu_nvcsi_intr: tstamp:34822297145 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946344: rtcpu_nvcsi_intr: tstamp:34822297145 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946344: rtcpu_nvcsi_intr: tstamp:34822297932 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946344: rtcpu_nvcsi_intr: tstamp:34822297932 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946344: rtcpu_nvcsi_intr: tstamp:34822297932 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946344: rtcpu_nvcsi_intr: tstamp:34822297932 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946344: rtcpu_nvcsi_intr: tstamp:34822298719 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946344: rtcpu_nvcsi_intr: tstamp:34822298719 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946345: rtcpu_nvcsi_intr: tstamp:34822298719 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946345: rtcpu_nvcsi_intr: tstamp:34822298719 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946345: rtcpu_nvcsi_intr: tstamp:34822299506 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946345: rtcpu_nvcsi_intr: tstamp:34822299506 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946345: rtcpu_nvcsi_intr: tstamp:34822299506 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946345: rtcpu_nvcsi_intr: tstamp:34822299506 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946345: rtcpu_nvcsi_intr: tstamp:34822300293 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946345: rtcpu_nvcsi_intr: tstamp:34822300293 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946346: rtcpu_nvcsi_intr: tstamp:34822300293 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946346: rtcpu_nvcsi_intr: tstamp:34822300293 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946346: rtcpu_nvcsi_intr: tstamp:34822301091 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946346: rtcpu_nvcsi_intr: tstamp:34822301091 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946346: rtcpu_nvcsi_intr: tstamp:34822301091 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946346: rtcpu_nvcsi_intr: tstamp:34822301091 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946346: rtcpu_nvcsi_intr: tstamp:34822301872 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946346: rtcpu_nvcsi_intr: tstamp:34822301872 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946346: rtcpu_nvcsi_intr: tstamp:34822301872 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946347: rtcpu_nvcsi_intr: tstamp:34822301872 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946347: rtcpu_nvcsi_intr: tstamp:34822302652 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946347: rtcpu_nvcsi_intr: tstamp:34822302652 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946347: rtcpu_nvcsi_intr: tstamp:34822302652 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946347: rtcpu_nvcsi_intr: tstamp:34822302652 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946347: rtcpu_nvcsi_intr: tstamp:34822303430 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946347: rtcpu_nvcsi_intr: tstamp:34822303430 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946348: rtcpu_nvcsi_intr: tstamp:34822303430 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946348: rtcpu_nvcsi_intr: tstamp:34822303430 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946348: rtcpu_nvcsi_intr: tstamp:34822304217 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946348: rtcpu_nvcsi_intr: tstamp:34822304217 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946348: rtcpu_nvcsi_intr: tstamp:34822304217 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946348: rtcpu_nvcsi_intr: tstamp:34822304217 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946348: rtcpu_nvcsi_intr: tstamp:34822304999 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946349: rtcpu_nvcsi_intr: tstamp:34822304999 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946349: rtcpu_nvcsi_intr: tstamp:34822304999 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946349: rtcpu_nvcsi_intr: tstamp:34822304999 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946349: rtcpu_nvcsi_intr: tstamp:34822305778 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946349: rtcpu_nvcsi_intr: tstamp:34822305778 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946349: rtcpu_nvcsi_intr: tstamp:34822305778 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946349: rtcpu_nvcsi_intr: tstamp:34822305778 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946349: rtcpu_nvcsi_intr: tstamp:34822306586 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946350: rtcpu_nvcsi_intr: tstamp:34822306586 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946350: rtcpu_nvcsi_intr: tstamp:34822306586 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946350: rtcpu_nvcsi_intr: tstamp:34822306586 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946350: rtcpu_nvcsi_intr: tstamp:34822307381 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946350: rtcpu_nvcsi_intr: tstamp:34822307381 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946351: rtcpu_nvcsi_intr: tstamp:34822307381 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946351: rtcpu_nvcsi_intr: tstamp:34822307381 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946351: rtcpu_nvcsi_intr: tstamp:34822308173 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946351: rtcpu_nvcsi_intr: tstamp:34822308173 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946352: rtcpu_nvcsi_intr: tstamp:34822308173 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946352: rtcpu_nvcsi_intr: tstamp:34822308173 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946352: rtcpu_nvcsi_intr: tstamp:34822308964 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946352: rtcpu_nvcsi_intr: tstamp:34822308964 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946352: rtcpu_nvcsi_intr: tstamp:34822308964 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946352: rtcpu_nvcsi_intr: tstamp:34822308964 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946353: rtcpu_nvcsi_intr: tstamp:34822309751 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946353: rtcpu_nvcsi_intr: tstamp:34822309751 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946353: rtcpu_nvcsi_intr: tstamp:34822309751 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946353: rtcpu_nvcsi_intr: tstamp:34822309751 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946353: rtcpu_nvcsi_intr: tstamp:34822310537 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946354: rtcpu_nvcsi_intr: tstamp:34822310537 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946354: rtcpu_nvcsi_intr: tstamp:34822310537 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946354: rtcpu_nvcsi_intr: tstamp:34822310537 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946354: rtcpu_nvcsi_intr: tstamp:34822311319 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946354: rtcpu_nvcsi_intr: tstamp:34822311319 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946355: rtcpu_nvcsi_intr: tstamp:34822311319 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946355: rtcpu_nvcsi_intr: tstamp:34822311319 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946355: rtcpu_nvcsi_intr: tstamp:34822312111 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946355: rtcpu_nvcsi_intr: tstamp:34822312111 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946356: rtcpu_nvcsi_intr: tstamp:34822312111 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946356: rtcpu_nvcsi_intr: tstamp:34822312111 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946356: rtcpu_nvcsi_intr: tstamp:34822312893 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946357: rtcpu_nvcsi_intr: tstamp:34822312893 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946357: rtcpu_nvcsi_intr: tstamp:34822312893 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946357: rtcpu_nvcsi_intr: tstamp:34822312893 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946357: rtcpu_nvcsi_intr: tstamp:34822313680 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946357: rtcpu_nvcsi_intr: tstamp:34822313680 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946357: rtcpu_nvcsi_intr: tstamp:34822313680 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946357: rtcpu_nvcsi_intr: tstamp:34822313680 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946357: rtcpu_nvcsi_intr: tstamp:34822314466 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946358: rtcpu_nvcsi_intr: tstamp:34822314466 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946358: rtcpu_nvcsi_intr: tstamp:34822314466 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946358: rtcpu_nvcsi_intr: tstamp:34822314466 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946358: rtcpu_nvcsi_intr: tstamp:34822315253 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946358: rtcpu_nvcsi_intr: tstamp:34822315253 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946358: rtcpu_nvcsi_intr: tstamp:34822315253 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946359: rtcpu_nvcsi_intr: tstamp:34822315253 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946359: rtcpu_nvcsi_intr: tstamp:34822316039 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946359: rtcpu_nvcsi_intr: tstamp:34822316039 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946360: rtcpu_nvcsi_intr: tstamp:34822316039 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946360: rtcpu_nvcsi_intr: tstamp:34822316039 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946360: rtcpu_nvcsi_intr: tstamp:34822316823 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946360: rtcpu_nvcsi_intr: tstamp:34822316823 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946360: rtcpu_nvcsi_intr: tstamp:34822316823 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946360: rtcpu_nvcsi_intr: tstamp:34822316823 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946360: rtcpu_nvcsi_intr: tstamp:34822317596 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946361: rtcpu_nvcsi_intr: tstamp:34822317596 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946361: rtcpu_nvcsi_intr: tstamp:34822317596 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946361: rtcpu_nvcsi_intr: tstamp:34822317596 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946361: rtcpu_nvcsi_intr: tstamp:34822318371 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946361: rtcpu_nvcsi_intr: tstamp:34822318371 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946361: rtcpu_nvcsi_intr: tstamp:34822318371 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946361: rtcpu_nvcsi_intr: tstamp:34822318371 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946361: rtcpu_nvcsi_intr: tstamp:34822319147 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946362: rtcpu_nvcsi_intr: tstamp:34822319147 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946362: rtcpu_nvcsi_intr: tstamp:34822319147 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946362: rtcpu_nvcsi_intr: tstamp:34822319147 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946362: rtcpu_nvcsi_intr: tstamp:34822319925 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946362: rtcpu_nvcsi_intr: tstamp:34822319925 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946362: rtcpu_nvcsi_intr: tstamp:34822319925 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946362: rtcpu_nvcsi_intr: tstamp:34822319925 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946362: rtcpu_nvcsi_intr: tstamp:34822320702 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946362: rtcpu_nvcsi_intr: tstamp:34822320702 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946363: rtcpu_nvcsi_intr: tstamp:34822320702 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946363: rtcpu_nvcsi_intr: tstamp:34822320702 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946363: rtcpu_nvcsi_intr: tstamp:34822321485 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946363: rtcpu_nvcsi_intr: tstamp:34822321485 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946363: rtcpu_nvcsi_intr: tstamp:34822321485 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946363: rtcpu_nvcsi_intr: tstamp:34822321485 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946364: rtcpu_nvcsi_intr: tstamp:34822322263 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946364: rtcpu_nvcsi_intr: tstamp:34822322263 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946364: rtcpu_nvcsi_intr: tstamp:34822322263 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946364: rtcpu_nvcsi_intr: tstamp:34822322263 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946364: rtcpu_nvcsi_intr: tstamp:34822323037 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946364: rtcpu_nvcsi_intr: tstamp:34822323037 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946364: rtcpu_nvcsi_intr: tstamp:34822323037 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946365: rtcpu_nvcsi_intr: tstamp:34822323037 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946365: rtcpu_nvcsi_intr: tstamp:34822323810 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946365: rtcpu_nvcsi_intr: tstamp:34822323810 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946365: rtcpu_nvcsi_intr: tstamp:34822323810 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946365: rtcpu_nvcsi_intr: tstamp:34822323810 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946365: rtcpu_nvcsi_intr: tstamp:34822324580 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946366: rtcpu_nvcsi_intr: tstamp:34822324580 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946366: rtcpu_nvcsi_intr: tstamp:34822324580 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946366: rtcpu_nvcsi_intr: tstamp:34822324580 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946366: rtcpu_nvcsi_intr: tstamp:34822325353 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946366: rtcpu_nvcsi_intr: tstamp:34822325353 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946366: rtcpu_nvcsi_intr: tstamp:34822325353 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946366: rtcpu_nvcsi_intr: tstamp:34822325353 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946367: rtcpu_nvcsi_intr: tstamp:34822326136 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946367: rtcpu_nvcsi_intr: tstamp:34822326136 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946367: rtcpu_nvcsi_intr: tstamp:34822326136 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946367: rtcpu_nvcsi_intr: tstamp:34822326136 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946367: rtcpu_nvcsi_intr: tstamp:34822326918 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946368: rtcpu_nvcsi_intr: tstamp:34822326918 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946368: rtcpu_nvcsi_intr: tstamp:34822326918 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946368: rtcpu_nvcsi_intr: tstamp:34822326918 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946368: rtcpu_nvcsi_intr: tstamp:34822327700 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946368: rtcpu_nvcsi_intr: tstamp:34822327700 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946369: rtcpu_nvcsi_intr: tstamp:34822327700 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946369: rtcpu_nvcsi_intr: tstamp:34822327700 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946369: rtcpu_nvcsi_intr: tstamp:34822328482 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946369: rtcpu_nvcsi_intr: tstamp:34822328482 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946369: rtcpu_nvcsi_intr: tstamp:34822328482 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946369: rtcpu_nvcsi_intr: tstamp:34822328482 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946370: rtcpu_nvcsi_intr: tstamp:34822329261 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946370: rtcpu_nvcsi_intr: tstamp:34822329261 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946370: rtcpu_nvcsi_intr: tstamp:34822329261 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946370: rtcpu_nvcsi_intr: tstamp:34822329261 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946370: rtcpu_nvcsi_intr: tstamp:34822330035 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946370: rtcpu_nvcsi_intr: tstamp:34822330035 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946371: rtcpu_nvcsi_intr: tstamp:34822330035 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946371: rtcpu_nvcsi_intr: tstamp:34822330035 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946371: rtcpu_nvcsi_intr: tstamp:34822330813 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946371: rtcpu_nvcsi_intr: tstamp:34822330813 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946371: rtcpu_nvcsi_intr: tstamp:34822330813 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946371: rtcpu_nvcsi_intr: tstamp:34822330813 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946372: rtcpu_nvcsi_intr: tstamp:34822331591 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946372: rtcpu_nvcsi_intr: tstamp:34822331591 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946372: rtcpu_nvcsi_intr: tstamp:34822331591 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946372: rtcpu_nvcsi_intr: tstamp:34822331591 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946372: rtcpu_nvcsi_intr: tstamp:34822332373 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946373: rtcpu_nvcsi_intr: tstamp:34822332373 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946373: rtcpu_nvcsi_intr: tstamp:34822332373 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946373: rtcpu_nvcsi_intr: tstamp:34822332373 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946373: rtcpu_nvcsi_intr: tstamp:34822333155 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946373: rtcpu_nvcsi_intr: tstamp:34822333155 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946374: rtcpu_nvcsi_intr: tstamp:34822333155 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946374: rtcpu_nvcsi_intr: tstamp:34822333155 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946374: rtcpu_nvcsi_intr: tstamp:34822333933 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946374: rtcpu_nvcsi_intr: tstamp:34822333933 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946374: rtcpu_nvcsi_intr: tstamp:34822333933 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946374: rtcpu_nvcsi_intr: tstamp:34822333933 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946375: rtcpu_nvcsi_intr: tstamp:34822334715 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946375: rtcpu_nvcsi_intr: tstamp:34822334715 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946375: rtcpu_nvcsi_intr: tstamp:34822334715 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946375: rtcpu_nvcsi_intr: tstamp:34822334715 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946375: rtcpu_nvcsi_intr: tstamp:34822335498 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946376: rtcpu_nvcsi_intr: tstamp:34822335498 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946376: rtcpu_nvcsi_intr: tstamp:34822335498 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946376: rtcpu_nvcsi_intr: tstamp:34822335498 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946376: rtcpu_nvcsi_intr: tstamp:34822336274 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946376: rtcpu_nvcsi_intr: tstamp:34822336274 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946377: rtcpu_nvcsi_intr: tstamp:34822336274 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946377: rtcpu_nvcsi_intr: tstamp:34822336274 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946377: rtcpu_nvcsi_intr: tstamp:34822337058 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946377: rtcpu_nvcsi_intr: tstamp:34822337058 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946377: rtcpu_nvcsi_intr: tstamp:34822337058 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946377: rtcpu_nvcsi_intr: tstamp:34822337058 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946378: rtcpu_nvcsi_intr: tstamp:34822337857 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946378: rtcpu_nvcsi_intr: tstamp:34822337857 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946378: rtcpu_nvcsi_intr: tstamp:34822337857 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946378: rtcpu_nvcsi_intr: tstamp:34822337857 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946378: rtcpu_nvcsi_intr: tstamp:34822338636 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946378: rtcpu_nvcsi_intr: tstamp:34822338636 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946379: rtcpu_nvcsi_intr: tstamp:34822338636 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946379: rtcpu_nvcsi_intr: tstamp:34822338636 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946379: rtcpu_nvcsi_intr: tstamp:34822339414 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946379: rtcpu_nvcsi_intr: tstamp:34822339414 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946379: rtcpu_nvcsi_intr: tstamp:34822339414 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946380: rtcpu_nvcsi_intr: tstamp:34822339414 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946380: rtcpu_nvcsi_intr: tstamp:34822340195 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946380: rtcpu_nvcsi_intr: tstamp:34822340195 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946380: rtcpu_nvcsi_intr: tstamp:34822340195 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946380: rtcpu_nvcsi_intr: tstamp:34822340195 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946380: rtcpu_nvcsi_intr: tstamp:34822340976 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946381: rtcpu_nvcsi_intr: tstamp:34822340976 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946381: rtcpu_nvcsi_intr: tstamp:34822340976 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946381: rtcpu_nvcsi_intr: tstamp:34822340976 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946381: rtcpu_nvcsi_intr: tstamp:34822341760 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946381: rtcpu_nvcsi_intr: tstamp:34822341760 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946381: rtcpu_nvcsi_intr: tstamp:34822341760 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946381: rtcpu_nvcsi_intr: tstamp:34822341760 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946381: rtcpu_nvcsi_intr: tstamp:34822342542 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946382: rtcpu_nvcsi_intr: tstamp:34822342542 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946382: rtcpu_nvcsi_intr: tstamp:34822342542 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946382: rtcpu_nvcsi_intr: tstamp:34822342542 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946382: rtcpu_nvcsi_intr: tstamp:34822343325 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946382: rtcpu_nvcsi_intr: tstamp:34822343325 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946382: rtcpu_nvcsi_intr: tstamp:34822343325 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946382: rtcpu_nvcsi_intr: tstamp:34822343325 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946382: rtcpu_nvcsi_intr: tstamp:34822344107 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946383: rtcpu_nvcsi_intr: tstamp:34822344107 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946383: rtcpu_nvcsi_intr: tstamp:34822344107 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946383: rtcpu_nvcsi_intr: tstamp:34822344107 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946383: rtcpu_nvcsi_intr: tstamp:34822344894 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946383: rtcpu_nvcsi_intr: tstamp:34822344894 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946383: rtcpu_nvcsi_intr: tstamp:34822344894 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946383: rtcpu_nvcsi_intr: tstamp:34822344894 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946383: rtcpu_nvcsi_intr: tstamp:34822345681 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946384: rtcpu_nvcsi_intr: tstamp:34822345681 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946384: rtcpu_nvcsi_intr: tstamp:34822345681 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946384: rtcpu_nvcsi_intr: tstamp:34822345681 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946384: rtcpu_nvcsi_intr: tstamp:34822346468 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946384: rtcpu_nvcsi_intr: tstamp:34822346468 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946384: rtcpu_nvcsi_intr: tstamp:34822346468 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946384: rtcpu_nvcsi_intr: tstamp:34822346468 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946385: rtcpu_nvcsi_intr: tstamp:34822347255 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946385: rtcpu_nvcsi_intr: tstamp:34822347255 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946385: rtcpu_nvcsi_intr: tstamp:34822347255 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946385: rtcpu_nvcsi_intr: tstamp:34822347255 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946385: rtcpu_nvcsi_intr: tstamp:34822348041 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946385: rtcpu_nvcsi_intr: tstamp:34822348041 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946385: rtcpu_nvcsi_intr: tstamp:34822348041 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946385: rtcpu_nvcsi_intr: tstamp:34822348041 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946386: rtcpu_nvcsi_intr: tstamp:34822348823 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946386: rtcpu_nvcsi_intr: tstamp:34822348823 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946386: rtcpu_nvcsi_intr: tstamp:34822348823 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946386: rtcpu_nvcsi_intr: tstamp:34822348823 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946386: rtcpu_nvcsi_intr: tstamp:34822349602 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946386: rtcpu_nvcsi_intr: tstamp:34822349602 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946386: rtcpu_nvcsi_intr: tstamp:34822349602 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946386: rtcpu_nvcsi_intr: tstamp:34822349602 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946387: rtcpu_nvcsi_intr: tstamp:34822350384 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946387: rtcpu_nvcsi_intr: tstamp:34822350384 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946387: rtcpu_nvcsi_intr: tstamp:34822350384 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946387: rtcpu_nvcsi_intr: tstamp:34822350384 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946387: rtcpu_nvcsi_intr: tstamp:34822351171 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946388: rtcpu_nvcsi_intr: tstamp:34822351171 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946388: rtcpu_nvcsi_intr: tstamp:34822351171 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946388: rtcpu_nvcsi_intr: tstamp:34822351171 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946388: rtcpu_nvcsi_intr: tstamp:34822351962 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946389: rtcpu_nvcsi_intr: tstamp:34822351962 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946389: rtcpu_nvcsi_intr: tstamp:34822351962 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946389: rtcpu_nvcsi_intr: tstamp:34822351962 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946389: rtcpu_nvcsi_intr: tstamp:34822352750 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946390: rtcpu_nvcsi_intr: tstamp:34822352750 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946390: rtcpu_nvcsi_intr: tstamp:34822352750 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946390: rtcpu_nvcsi_intr: tstamp:34822352750 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946390: rtcpu_nvcsi_intr: tstamp:34822353535 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946390: rtcpu_nvcsi_intr: tstamp:34822353535 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946391: rtcpu_nvcsi_intr: tstamp:34822353535 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946391: rtcpu_nvcsi_intr: tstamp:34822353535 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946391: rtcpu_nvcsi_intr: tstamp:34822354322 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946391: rtcpu_nvcsi_intr: tstamp:34822354322 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946391: rtcpu_nvcsi_intr: tstamp:34822354322 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946391: rtcpu_nvcsi_intr: tstamp:34822354322 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946392: rtcpu_nvcsi_intr: tstamp:34822355109 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946392: rtcpu_nvcsi_intr: tstamp:34822355109 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946392: rtcpu_nvcsi_intr: tstamp:34822355109 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946392: rtcpu_nvcsi_intr: tstamp:34822355109 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946392: rtcpu_nvcsi_intr: tstamp:34822355897 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946393: rtcpu_nvcsi_intr: tstamp:34822355897 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946393: rtcpu_nvcsi_intr: tstamp:34822355897 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946393: rtcpu_nvcsi_intr: tstamp:34822355897 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946393: rtcpu_nvcsi_intr: tstamp:34822356691 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946393: rtcpu_nvcsi_intr: tstamp:34822356691 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946394: rtcpu_nvcsi_intr: tstamp:34822356691 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946394: rtcpu_nvcsi_intr: tstamp:34822356691 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946394: rtcpu_nvcsi_intr: tstamp:34822357477 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946394: rtcpu_nvcsi_intr: tstamp:34822357477 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946394: rtcpu_nvcsi_intr: tstamp:34822357477 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946395: rtcpu_nvcsi_intr: tstamp:34822357477 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946395: rtcpu_nvcsi_intr: tstamp:34822358260 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946395: rtcpu_nvcsi_intr: tstamp:34822358260 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946395: rtcpu_nvcsi_intr: tstamp:34822358260 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946396: rtcpu_nvcsi_intr: tstamp:34822358260 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946396: rtcpu_nvcsi_intr: tstamp:34822359042 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946396: rtcpu_nvcsi_intr: tstamp:34822359042 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946396: rtcpu_nvcsi_intr: tstamp:34822359042 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946396: rtcpu_nvcsi_intr: tstamp:34822359042 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946396: rtcpu_nvcsi_intr: tstamp:34822359825 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946397: rtcpu_nvcsi_intr: tstamp:34822359825 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946397: rtcpu_nvcsi_intr: tstamp:34822359825 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946397: rtcpu_nvcsi_intr: tstamp:34822359825 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946397: rtcpu_nvcsi_intr: tstamp:34822360616 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946397: rtcpu_nvcsi_intr: tstamp:34822360616 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946398: rtcpu_nvcsi_intr: tstamp:34822360616 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946398: rtcpu_nvcsi_intr: tstamp:34822360616 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946398: rtcpu_nvcsi_intr: tstamp:34822361403 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946398: rtcpu_nvcsi_intr: tstamp:34822361403 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946398: rtcpu_nvcsi_intr: tstamp:34822361403 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946399: rtcpu_nvcsi_intr: tstamp:34822361403 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946399: rtcpu_nvcsi_intr: tstamp:34822362193 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946399: rtcpu_nvcsi_intr: tstamp:34822362193 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946399: rtcpu_nvcsi_intr: tstamp:34822362193 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946399: rtcpu_nvcsi_intr: tstamp:34822362193 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946400: rtcpu_nvcsi_intr: tstamp:34822362980 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946400: rtcpu_nvcsi_intr: tstamp:34822362980 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946400: rtcpu_nvcsi_intr: tstamp:34822362980 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946400: rtcpu_nvcsi_intr: tstamp:34822362980 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946400: rtcpu_nvcsi_intr: tstamp:34822363766 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946400: rtcpu_nvcsi_intr: tstamp:34822363766 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946401: rtcpu_nvcsi_intr: tstamp:34822363766 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946401: rtcpu_nvcsi_intr: tstamp:34822363766 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946401: rtcpu_nvcsi_intr: tstamp:34822364547 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946401: rtcpu_nvcsi_intr: tstamp:34822364547 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946401: rtcpu_nvcsi_intr: tstamp:34822364547 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:0 status:0x00000004
kworker/11:3-1798 [011] .... 1098.946401: rtcpu_nvcsi_intr: tstamp:34822364547 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:5 vc:1 status:0x00000004
The log tell err_intr_stat_pd_crc_err_vc0 that could be the signal issue.
The same 8m camera configuration and device tree configuration can obtain image data normally on csi-a / b, csi-c / d and csi-e / f.
Can csi-g / h bandwidth enable 2 * 8m cameras?
OOPS, CSI-G/H only able support one camera for 1/2/4 lanes configure.
Csi-g / h uses virtual channel and can access two 8m cameras?
Csi-a / b, csi-c / d and csi-e / f all use virtual channels, and then access two 8m cameras
Yes, it’s able to support if it’s virtual channel.
