I’m running a 4 camera setup using 4x4 CSI-MIPI lanes on the Xavier 8GB and I’m experiencing some wierd issues.
- Connecting three cameras to any of the four CSI-MIPI connectors works fine, I’m able to stream video. However, when connecting the fourth camera i get issues on video2 and video3 with discarded frames, ex:
[ 60.636217] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 112, err_data 6291556
- Any connector configuration with 3 cameras works fine. I’m utilizing Allied Vision Alvium with an IMX264 sensor.
- Just connecting the fourth camera gives me trouble, I do not have to run the fourth camera. F.ex. streaming video0, video2 and video3 gives me discarded frames. Streaming only video0, video1 and video2 gives me discarded frames.
- The device tree should be OK as I’m able to connect any configuration of three cameras and it is working. The .dtsi is appended at the bottom.
Running a trace I get the following:
kworker/4:1-1431 [004] … 142.993844: rtcpu_nvcsi_intr: tstamp:4881946029 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:4 vc:0 status:0x00000004
kworker/4:1-1431 [004] … 142.993844: rtcpu_nvcsi_intr: tstamp:4881947794 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:4 vc:0 status:0x00000004
kworker/4:1-1431 [004] … 142.993844: rtcpu_nvcsi_intr: tstamp:4881947794 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:4 vc:0 status:0x00000004
kworker/4:1-1431 [004] … 142.993844: rtcpu_nvcsi_intr: tstamp:4881948424 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:4 vc:0 status:0x00000004
kworker/4:1-1431 [004] … 142.993844: rtcpu_nvcsi_intr: tstamp:4881948424 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:4 vc:0 status:0x00000004
kworker/4:1-1431 [004] … 142.993844: rtcpu_nvcsi_intr: tstamp:4881962322 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:4 vc:0 status:0x00000004
kworker/4:1-1431 [004] … 142.993845: rtcpu_nvcsi_intr: tstamp:4881962322 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:4 vc:0 status:0x00000004
kworker/4:1-1431 [004] … 142.993845: rtcpu_vinotify_error: tstamp:4881976361 tag:CSIMUX_FRAME channel:0x00 frame:1 vi_tstamp:4881974723 data:0x00400064
kworker/4:1-1431 [004] … 142.993846: rtcpu_vinotify_event: tstamp:4881976811 tag:CHANSEL_PXL_EOF channel:0x21 frame:1 vi_tstamp:4881963090 data:0x08070002
kworker/4:1-1431 [004] … 142.993846: rtcpu_vinotify_event: tstamp:4881976985 tag:ATOMP_FRAME_DONE channel:0x21 frame:1 vi_tstamp:4881963112 data:0x00000000
kworker/4:1-1431 [004] … 142.993846: rtcpu_vinotify_event: tstamp:4881977131 tag:RESERVED_19 channel:0x21 frame:1 vi_tstamp:5898965504 data:0x020200c4
kworker/4:1-1431 [004] … 142.993847: rtcpu_vinotify_event: tstamp:4881977301 tag:CSIMUX_FRAME channel:0x00 frame:1 vi_tstamp:4881974723 data:0x00400064
kworker/4:1-1431 [004] … 142.993847: rtcpu_vinotify_event: tstamp:4881977452 tag:ATOMP_FE channel:0x00 frame:1 vi_tstamp:4881974723 data:0x00000000
kworker/4:1-1431 [004] … 142.993849: rtos_queue_send_from_isr_failed: tstamp:4881985062 queue:0x0bcb41f8
kworker/4:1-1431 [004] … 142.993849: rtos_queue_send_from_isr_failed: tstamp:4881985227 queue:0x0bcb8a60
kworker/4:1-1431 [004] … 142.993850: rtos_queue_send_from_isr_failed: tstamp:4881985391 queue:0x0bcba5e0
kworker/4:1-1431 [004] … 142.993850: rtos_queue_send_from_isr_failed: tstamp:4881985548 queue:0x0bcbb3a0
kworker/4:1-1431 [004] … 142.993850: rtos_queue_send_from_isr_failed: tstamp:4881985705 queue:0x0bcbc160
kworker/4:1-1431 [004] … 142.993851: rtcpu_vinotify_event: tstamp:4882305456 tag:RESERVED_19 channel:0x21 frame:1 vi_tstamp:5899342304 data:0x000200c4
kworker/4:1-1431 [004] … 142.993853: rtcpu_vinotify_event: tstamp:4882305630 tag:RESERVED_19 channel:0x21 frame:0 vi_tstamp:5899347840 data:0x070200c5
kworker/4:1-1431 [004] … 142.993853: rtcpu_vinotify_event: tstamp:4882305804 tag:RESERVED_18 channel:0x21 frame:0 vi_tstamp:5899387104 data:0x10000000
kworker/4:1-1431 [004] … 142.993853: rtcpu_vinotify_event: tstamp:4882305950 tag:RESERVED_18 channel:0x21 frame:0 vi_tstamp:5899395584 data:0x310000c6
DTSI file:
* Copyright © 2012 - 2019 Allied Vision Technologies. All Rights Reserved.
* This program is free software; you may redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; version 2 of the License.
* THE SOFTWARE IS PRELIMINARY AND STILL IN TESTING AND VERIFICATION PHASE AND IS PROVIDED ON AN “AS IS” AND “AS AVAILABLE” BASIS AND IS BELIEVED TO CONTAIN DEFECTS.
* A PRIMARY PURPOSE OF THIS EARLY ACCESS IS TO OBTAIN FEEDBACK ON PERFORMANCE AND THE IDENTIFICATION OF DEFECT SOFTWARE, HARDWARE AND DOCUMENTATION.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
* EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF
* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND
* NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS
* BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN
* ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN
* CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
* SOFTWARE.
#include "dt-bindings/clock/tegra194-clock.h"
#define CAM0_RST_L TEGRA194_MAIN_GPIO(H, 3)
#define CAM0_PWDN TEGRA194_MAIN_GPIO(H, 6)
#define CAM1_RST_L TEGRA194_MAIN_GPIO(T, 6)
#define CAM1_PWDN TEGRA194_MAIN_GPIO(T, 5)
#include "tegra194-agx-cti-camera-base.dtsi"
gpio@2200000 {
camera-control-output-low {
gpio-hog;
output-low;
gpios = <CAM0_RST_L 0 CAM0_PWDN 0
CAM1_RST_L 0 CAM1_PWDN 0>;
label = "cam0-rst", "cam0-pwdn",
"cam1-rst", "cam1-pwdn";
host1x {
vi@15c10000 {
num-channels = <4>;
status = "okay";
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
status ="okay";
reg = <0>;
avt_csi2_vi_in0: endpoint {
status = "okay";
port-index = <0>;
bus-width = <4>;
remote-endpoint = <&avt_csi2_csi_out0>;
port@1 {
status ="okay";
reg = <1>;
avt_csi2_vi_in1: endpoint {
status = "okay";
port-index = <2>;
bus-width = <4>;
remote-endpoint = <&avt_csi2_csi_out1>;
port@2 {
status ="okay";
reg = <2>;
avt_csi2_vi_in2: endpoint {
status = "okay";
port-index = <4>;
bus-width = <4>;
remote-endpoint = <&avt_csi2_csi_out2>;
port@3 {
status ="okay";
reg = <3>;
avt_csi2_vi_in3: endpoint {
status = "okay";
port-index = <5>;
bus-width = <4>;
remote-endpoint = <&avt_csi2_csi_out3>;
nvcsi@15a00000 {
status = "okay";
num-channels = <4>;
#size-cells = <0>;
channel@0 {
status = "okay";
reg = <0>;
ports {
#size-cells = <0>;
port@0 {
status = "okay";
reg = <0>;
avt_csi2_csi_in0: endpoint@0 {
status = "okay";
port-index = <0>;
bus-width = <4>;
remote-endpoint = <&avt_csi2_out0>;
port@1 {
status = "okay";
reg = <1>;
avt_csi2_csi_out0: endpoint@1 {
status = "okay";
remote-endpoint = <&avt_csi2_vi_in0>;
channel@1 {
status = "okay";
reg = <1>;
ports {
#size-cells = <0>;
port@0 {
status = "okay";
reg = <0>;
avt_csi2_csi_in1: endpoint@2 {
status = "okay";
port-index = <2>;
bus-width = <4>;
remote-endpoint = <&avt_csi2_out1>;
port@1 {
status = "okay";
reg = <1>;
avt_csi2_csi_out1: endpoint@3 {
status = "okay";
remote-endpoint = <&avt_csi2_vi_in1>;
channel@2 {
status = "okay";
reg = <2>;
ports {
status = "okay";
#size-cells = <0>;
port@0 {
status = "okay";
reg = <0>;
avt_csi2_csi_in2: endpoint@4 {
status = "okay";
port-index = <4>;
bus-width = <4>;
remote-endpoint = <&avt_csi2_out2>;
port@1 {
status = "okay";
reg = <1>;
avt_csi2_csi_out2: endpoint@5 {
status = "okay";
remote-endpoint = <&avt_csi2_vi_in2>;
channel@3 {
status = "okay";
reg = <3>;
ports {
status = "okay";
#size-cells = <0>;
port@0 {
status = "okay";
reg = <0>;
avt_csi2_csi_in3: endpoint@6 {
status = "okay";
port-index = <6>;
bus-width = <4>;
remote-endpoint = <&avt_csi2_out3>;
port@1 {
status = "okay";
reg = <1>;
avt_csi2_csi_out3: endpoint@7 {
status = "okay";
remote-endpoint = <&avt_csi2_vi_in3>;
tegra-camera-platform {
compatible = "nvidia, tegra-camera-platform";
status = "okay";
* Physical settings to calculate max ISO BW
* num_csi_lanes = <>;
* Total number of CSI lanes when all cameras are active
* max_lane_speed = <>;
* Max lane speed in Kbit/s
* min_bits_per_pixel = <>;
* Min bits per pixel
* vi_peak_byte_per_pixel = <>;
* Max byte per pixel for the VI ISO case
* vi_bw_margin_pct = <>;
* Vi bandwidth margin in percentage
* max_pixel_rate = <>;
* Max pixel rate in Kpixel/s for the ISP ISO case
* isp_peak_byte_per_pixel = <>;
* Max byte per pixel for the ISP ISO case
* isp_bw_margin_pct = <>;
* Isp bandwidth margin in percentage
num_csi_lanes = <16>;
max_lane_speed = <1500000>;
min_bits_per_pixel = <8>;
vi_peak_byte_per_pixel = <2>;
vi_bw_margin_pct = <25>;
max_pixel_rate = <160000>;
isp_peak_byte_per_pixel = <5>;
isp_bw_margin_pct = <25>;
* The general guideline for naming badge_info contains 3 parts, and is as follows,
* The first part is the camera_board_id for the module; if the module is in a FFD
* platform, then use the platform name for this part.
* The second part contains the position of the module, ex. “rear” or “front”.
* The third part contains the last 6 characters of a part number which is found
* in the module's specsheet from the vender.
modules {
status = "okay";
module0 {
status = "okay";
badge = "avt_csi2_bottomleft";
position = "BottomLeft";
orientation = "1";
drivernode0 {
status = "okay";
/* Declare PCL support driver (classically known as guid) */
pcl_id = "v4l2_sensor";
/* Driver v4l2 device name */
devname = "avt_csi2 0-003a";
/* Declare the device-tree hierarchy to driver instance */
proc-device-tree = "/proc/device-tree/i2c@3180000/avt_csi2_a@3c";
module1 {
status = "okay";
badge = "avt_csi2_centerleft";
position = "CenterLeft";
orientation = "0";
drivernode0 {
status = "okay";
devname = "avt_csi2 2-003c";
proc-device-tree = "/proc/device-tree/i2c@3180000/avt_csi2_c@3e";
module2 {
status = "okay";
badge = "avt_csi2_centerright";
position = "CenterRight";
orientation = "0";
drivernode0 {
status = "okay";
devname = "avt_csi2 2-003e";
proc-device-tree = "/proc/device-tree/i2c@3180000/avt_csi2_e@38";
module3 {
status = "okay";
badge = "avt_csi2_topleft";
position = "TopLeft";
orientation = "1";
drivernode0 {
status = "okay";
devname = "avt_csi2 2-003g";
proc-device-tree = "/proc/device-tree/i2c@3180000/avt_csi2_g@34";
i2c@3180000 {
avt_csi2_a@3c {
status = "okay";
clocks = <&bpmp_clks TEGRA194_CLK_EXTPERIPH1>,
<&bpmp_clks TEGRA194_CLK_PLLP_OUT0>;
clock-names = "extperiph1", "pllp_grtba";
mclk = "extperiph1";
devnode = "video0";
compatible = "alliedvision,avt_csi2";
reg = <0x3c>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
avt_csi2_out0: endpoint {
port-index = <0>;
bus-width = <4>;
remote-endpoint = <&avt_csi2_csi_in0>;
mode0 {
num_lanes = "4";
discontinuous_clk = "no";
cil_settletime = "0";
embedded_metadata_height = "0";
/* not verified: */
mclk_khz = "24000";
phy_mode = "DPHY";
dpcm_enable = "false";
active_w = "5488";
active_h = "4112";
pixel_t = "bayer_bggr";
readout_orientation = "0";
line_length = "5488";
inherent_gain = "1";
mclk_multiplier = "31.25";
pix_clk_hz = "750000000";
gain_factor = "16";
framerate_factor = "1000000";
exposure_factor = "1000000";
min_gain_val = "16"; /* 1.0 */
max_gain_val = "256"; /* 16.0 */
step_gain_val = "1"; /* 0.125 */
min_hdr_ratio = "1";
max_hdr_ratio = "64";
min_framerate = "1500000"; /* 1.5 */
max_framerate = "30000000"; /* 30 */
step_framerate = "1";
min_exp_time = "34"; /* us */
max_exp_time = "550385"; /* us */
step_exp_time = "1";
avt_csi2_c@3e {
status = "okay";
devnode = "video1";
reg = <0x3e>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
avt_csi2_out1: endpoint {
port-index = <2>;
bus-width = <4>;
remote-endpoint = <&avt_csi2_csi_in1>;
mode0 {
num_lanes = "4";
tegra_sinterface = "serial_c";
/* not verified: */
mclk_khz = "24000";
phy_mode = "DPHY";
active_w = "5488";
active_h = "4112";
gain_factor = "16";
avt_csi2_e@38 {
status = "okay";
devnode = "video2";
reg = <0x38>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
avt_csi2_out2: endpoint {
port-index = <4>;
bus-width = <4>;
remote-endpoint = <&avt_csi2_csi_in2>;
mode0 {
num_lanes = "4";
tegra_sinterface = "serial_e";
/* not verified: */
mclk_khz = "24000";
phy_mode = "DPHY";
active_w = "5488";
active_h = "4112";
gain_factor = "16";
avt_csi2_g@34 {
status = "okay";
devnode = "video3";
reg = <0x34>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
avt_csi2_out3: endpoint {
port-index = <6>;
bus-width = <4>;
remote-endpoint = <&avt_csi2_csi_in3>;
mode0 {
num_lanes = "4";
tegra_sinterface = "serial_g";
/* not verified: */
mclk_khz = "24000";
phy_mode = "DPHY";
active_w = "5488";
active_h = "4112";
gain_factor = "16";
pinmux@2430000 {
gen8_i2c_pinctrl: gen8_i2c_pinctrl {
gen8_i2c_scl {
nvidia,pins = "gen8_i2c_scl_pdd1";
nvidia,schmitt = <TEGRA_PIN_DISABLE>;
nvidia,lpdr = <TEGRA_PIN_DISABLE>;
nvidia,enable-input = <TEGRA_PIN_ENABLE>;
nvidia,io-high-voltage = <TEGRA_PIN_DISABLE>;
nvidia,tristate = <TEGRA_PIN_DISABLE>;
nvidia,pull = <TEGRA_PIN_PULL_NONE>;
gen8_i2c_sda {
nvidia,pins = "gen8_i2c_sda_pdd2";
Thank you for any assistance :)
