did you worked with Jetson Orin NX developer kit?
please note that, there’re two camera slots, they’re J20/CAM0/CSI-B, J21/CAM1/CSI-C
so.. may I double check which camera, or, which CSI port you’re facing capture timeout errors?
according to the schematic, there’re two camera nodes, J201 (CSI-0/1) and J202 (CSI-2/3).
capture failure happened with J201 only, you’re able to fetch camera steam via J202, right?
here’s issue per checking your sensor device tree,
since it’s camera driver for Orin NX developer kit, which utilize CSI-B.
you should revise VI/NVCSI/Sensor properties that maps to your custom carrier board accordingly.
for instance,
Format Video Capture:
Width/Height : 640/480
Pixel Format : 'GREY' (8-bit Greyscale)
Field : None
Bytes per Line : 640
Size Image : 307200
Colorspace : sRGB
Transfer Function : Default (maps to sRGB)
YCbCr/HSV Encoding: Default (maps to ITU-R 601)
Quantization : Default (maps to Full Range)
Flags :
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< 60.03 fps
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< 60.04 fps
Similarly, for video1, I received:
Field : None
Size Image : 307200
Colorspace : sRGB
Flags :
As we can see the streaming still fails to work for both cameras simultaneously. With RG10 for also I am getting the same results.
let me double check your port bindings,
please execute the commands to dump device tree into dts formats for reference.
for instance, $ sudo dtc -I fs -O dts /sys/firmware/devicetree/base > /tmp/123.dts
