您好,我这边有一块Jetson AGX Orin套件,里面的风扇配置并没有更改,温度到达60度,它的风扇一直不转,请问如何解决?
Are you using tegrastats to know it temperature?
之前用ftop是60多度,刚才用tegrastats看也是60多度,风扇依旧不转
please check the status of nvfancontrol systemd service.
现在这个要怎么处理?
Are you sure this service is running up? I didn’t ask you to check the file. I mean the systemd service state.
If the service didn’t run up, then the fan control would not run.
What is this monitoring tool you are using?
jtop
Jtop is not a tool released from us. We don’t know whether it supports Orin or not.
Please directly share me the result of
systemctl status nvfancontrol
Also, please do not keep sharing photo… try to share text file for more clear reading…
输入systemctl status nvfancontrol,输出:
nvfancontrol.service - nvfancontrol service
Loaded: loaded (/etc/systemd/system/nvfancontrol.service; enabled; vendor preset: enabled)
Active: active (running) since Tue 2022-05-17 20:41:32 CST; 16h ago
Main PID: 2014174 (nvfancontrol)
Tasks: 1 (limit: 36425)
Memory: 396.0K
CGroup: /system.slice/nvfancontrol.service
└─2014174 /usr/sbin/nvfancontrol &
5月 17 20:41:32 user-desktop systemd[1]: Started nvfancontrol service.
Is your board flashed with pure jetpack?
是的
Do you have other Orin on your side to do the cross check?
我这一块买了5块,现在就这一块出现这种情况,其他的没事,风扇正常转。
Please RMA this module.
