根据温度控制风扇自动调整转速
您好,我的agx orin开机后风扇是全速运行的,我想让它可以根据温度自动调整转速,我该怎么做
Please refer to Jetson Orin Nano Series, Jetson Orin NX Series and Jetson AGX Orin Series — Jetson Linux Developer Guide documentation (nvidia.com)
I will add that if you use a third party carrier board, then the device tree probably has an effect on fan speed, and would likely need to be edited for that carrier board.
