i have an xavier nx, when i reboot, system auto run jetson_clocks, then the FAN turn on with 100% speed! even there is low LOAD,
then , how can i do to make the FAN turn on automatic??
please help!
hello jcyhcs,
are you having --fan
options to enable jetson_clocks?
since jetson_clocks no longer sets maximum fan speed by default starting with L4T release 32.4.
every fan speed step is associated with the trip point temperature and corresponding hysteresis.
you may also check Fan Mode Configuration for the details
thanks
