How to turn on jetson agx xavier's fan
Hello
Jetson Xavier is overheating and I want to turn on the fan
but the fan does not turn on even when the power mode is set to 0.
How do I turn on the fan?
hello chulsub0727,
may I know which JetPack release you’re working on?
you may see-also developer guide, Fan Profile Control. it’s nvfancontrol to manages the fan speeds on the latest release version.
thank you for reply
version is 5.0.1 DP
I checked the document
What command do I need to change to cool mode?
hello chulsub0727,
please update FAN_DEFAULT_PROFILE as cool in the configuration file /etc/nvfancontrol.conf.
you may stop/re-start the nvfancontrol systemd service to apply the change, thanks
thank you! I resolved!
