hello~ I have some trouble about xavier agx.
Fan is not running…
input : sudo cat /sys/devices/pwm-fan/target_pwm
output : 255
but fan is not running…
input : sensors
output :
iwlwifi -virtual -0
adapter : virtual device
temp 1: +51.0 degree
thermal -fan -virtual - 0
temp 1: + 60.1 degree
how can i solve this probelm…?
Did you already check out the fan mode control options?
Thank you for your reply.
I changed my fan mode by referring to the site you linked me to. But this error occurred.
~$ sudo /usr/sbin/nvpmodel -d cool
/usr/sbin/nvpmode : invalid option – ‘d’
Nvidia Power model Tool Version 1.1.2
~$ sudo /usr/sbin/nvpmodel -q
NV Power Mode:MAXN
0
and According to the site,
To change the default fan mode
Set the default fan mode by putting the following property in nvpmodel.conf:
<FAN_CONFIG DEFAULT=<fan_mode> >
but i can’t find <FAN_CONFIG DEFAULT = <fan_mode> >
hello xmfxhddl,
may I know what’s the software modification you had done,
could you please verify fan functionality with the default JetPack release image?
thanks
