The CPU fan only turns on when NX turned on. Even when the CPU feels hot by hand during standby, the fan will not turn. The CPU temperature is 48 ° C, which causes me to report an error when inserting some low current devices. Excessive current causes throttling. I want to know how to adjust the CPU fan to run normally. thanks
Hi 2382972980,
Are you using the devkit or custom board for Xavier NX?
Please refer to the following instruction for nvfancontrol service.
Jetson Xavier NX Series and Jetson AGX Xavier Series — Fan Profile Control
and share /etc/nvfancontrol.conf
from your board for further check.
Thank you. It was successfully resolved
