Hello
I exploring Jetson AGX xavier series SOM and carrier board, the stack up details in the carrier board shows only 85 and 90 ohm impedances in the layer, then how the ethernet and Sata traces are routed?
Hello
The impedance is SEZ 50ohm, DEZ 85/90/95 ohm, +/-10% tolerance. It fits requests of ethernet and sata.
Thank you for your response,
What is the cpu speed for jetson AGX xavier module?
2.26GHz in max.
